Kerdi Tub Surround
Old 03-11-2008, 08:26 AM   #1
Extra Ordinary
Graeson's Avatar
Trade: Remodeling - Specializing in tile
Kerdi Tub Surround
Hey guys!
Using Kerdi in a tub surround -
How do I create a seal where the Kerdi meets the tub?
Also - same scenario - different job - Kerdi in a tub surround - Installing 2"x12" Island Stone Slate claddiing - read the product specs and it said it could be installed without grout joints (this is what the customer wants) BUT how do I waterproof it with no grout joints or should I use 1/16"s?
Posted in another thread and only got one reply... Don't get mad that I started another please!
G.
Graeson is offline
Old 03-11-2008, 09:54 AM   #2
Tile Contractor
Bud Cline's Avatar
Re: Kerdi Tub Surround
"Infidel!"
Tile and grout typically ARE NOT waterproof to begin with. Whether or not there is grout in a joint doesn't change anything. These guys that say their tile product can be installed without grout joints just haven't thought this through. On a dry wall as a decorative asset such as a wainscot the lack of grout in the joints would be acceptable I suppose. Using the same approach on a shower wall would be bad news in my thinking.
Even though the grout isn't waterproof it will offer a watershed, that's a good thing! Showers can be nasty environments as it is. Offer up a tile wall in a shower with butted tiles and nothing to fill the inevitable small gaps will only provide a place for mold and fungus to inhabit and thrive. If the tiles are butted tight there are still going to be voids. In some cases these voids won't allow even a small amount of grout unless they are spaced enough to create an opening for a little grout. Space the tiles and grout the spaces.
In the case of slate (especially) in some cases iron is present. To allow water to hang in open crevices and activate any iron that may be present will eventually result in runs and drip-features that will stain the wall as it descends over time.
KERDI on a surround should be installed to cover the lowest point of the wallboard. Then the remaining gap can be caulked. The tile then laps the gap and comes within 1/8" of the tub edge surface and again that gap is caulked. Simple, nothing to it!
There! That's the best I can do.
Bud Cline is offline
Old 03-11-2008, 10:35 AM   #3
Its all ball bearings
angus242's Avatar
Trade: Tile
Just so no one misses this great article in the other post:
http://www.fcimag.com/CDA/Articles/C...00000000238555
angus242 is offline
Old 03-11-2008, 10:44 AM   #4
Tile Contractor
Bud Cline's Avatar
Jheeeeezh! Does Gobis have you on retainer or does he just pay you for the times you post the article?
Old 03-11-2008, 12:54 PM   #5
Extra Ordinary
Graeson's Avatar
Bud - you confirmed exactly what I thought as far as the grout and the Kerdi go! Thank you! I definitely learned something about the iron in the slate though! Thanks for that too!
Angus - Thanks for posting the same thing in two different threads - joke - touche!
Graeson is offline
Old 03-11-2008, 12:57 PM   #6
Extra Ordinary
Graeson's Avatar
By the way - where's my main man Bill Vincent on this one?
Graeson is offline
Old 03-11-2008, 01:12 PM   #7
angus242's Avatar
Trade: Tile
Hey now....I said I had already posted the article in another thread. I admitted to that. Since the other thread was old, AND there is this current thread, I figured couldn't hurt to post again. I know I have seen this question many times recently (about groutless tile). I myself had been wondering about this. See, I just did a 300 sq ft job of rectified porcelain WITHOUT grout. Had I seen this article BEFORE I started the job, I would have NOT done it. It was a very hard job and I ran into too many problems I shouldn't have IF I had known what I do now.
Just trying to spread the good word, ya know
angus242 is offline
Old 03-11-2008, 01:33 PM   #8
Tile Contractor
Bud Cline's Avatar
You don't need him, you have us! He's going to tell you the same thing anyway. How many times does it have to be said?
Besides I heard he took a job with Sherwin Williams selling paints.
Old 03-11-2008, 06:52 PM   #9
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 03-11-2008, 06:56 PM   #10
Tile Contractor
Bud Cline's Avatar
Old 03-11-2008, 07:26 PM   #11
Moderator
Double-A's Avatar
They had to let him go. I heard he kept telling the painters they don't need no custom mixed paint, just pick one of the factory grout colors instead. They go with everything.
New York Times, July 20, 2006
Double-A is offline
Old 03-13-2008, 12:18 PM   #12
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
It should be noted that the Kerdi/tub connection for a tub surround should be make with Kerdi Fix. A silane based sealant, made by Schluter for just such an application.
A good quality urethane based sealant would also suffice.
HS345 is online now
Old 03-13-2008, 06:12 PM   #13
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
You've already got good advice, and I had nothing to add!
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Tile over brick fireplace surround John Pride Ceramic & Stone Tile 7 03-04-2008 07:47 AM
Shower Surround stl_6string Drywall 4 01-02-2007 09:23 PM
Tile bathroom surround SHAWNPAINTS Flooring 12 12-31-2006 03:00 PM
old fire surround summertime Carpentry Picture Post 3 11-21-2006 07:50 PM
installing tub and surround jcovey Plumbing 5 03-23-2006 12:29 PM
