Kerdi Shower Q.
Old 05-23-2009, 06:48 PM   #1
mdshunk's Avatar
Kerdi Shower Q.
If an existing drain rough opening in a shower is about 18" from one end of the shower (offset), can a person use the 32x60 offset shower kit and saw 8" of the base foam off one end and add it to the other to get the drain offset at about 18". Or, is there a better way to do this?
mdshunk is offline
Old 05-23-2009, 08:14 PM   #2
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Re: Kerdi Shower Q.
MD-
the foam floors work fine when they match the existing shower size and drain location... They're level around the perimeter and pitch towards the drain hole, so sawing off a section a moving it elsewhere will throw off the slope of the floor.
Use mud.. Doing a small area like a shower floor is not difficult for an amateur mudman...
- Alex
Long Island Remodeling Contractor
Splinter is offline
Old 05-23-2009, 08:59 PM   #3
orson's Avatar
Trade: Kitchen & Bath
Re: Kerdi Shower Q.
The drain needs to be pretty much dead center to use the kerdi pan. If you cut one end off and add to the other you will not have a level line where the pan meets the wall.
It could be less work to move the drain to the center than to mud a pan.
Of course, mudding a pan is damn hard work and that always brings a certain satisfaction...
orson is offline
Old 05-24-2009, 12:48 PM   #4
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Re: Kerdi Shower Q.
Yep, mud the pan or move the drain. Which one is easier or more cost effective depends on the situation. Personally I like a centered drain if at all possible, gives you a lot more options when it's time to tile. As a side note, you can cut the Kerdi pans down, provided you take an even amount from both sides. That doesn't help in this situation, but just an fyi.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 05-24-2009, 01:05 PM   #5
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: Kerdi Shower Q.
or you could cut the foam and continue the slope with mud where you have to extend.
naptown CR is offline
Old 05-24-2009, 01:21 PM   #6
Tech Geek
WarriorWithWood's Avatar
Trade: Property Management/Facilities Manager
Re: Kerdi Shower Q.
This or a mud pan would get my vote.
-Dennis
www.bowmanch.com
WarriorWithWood is offline
Old 05-24-2009, 03:44 PM   #7
I builds'em
Winchester's Avatar
Trade: Renovations & Decks
Re: Kerdi Shower Q.
This is what I do when I have to. (Depends on the job and what the customer wants to pay for)
Keep in mind if you do it this way, the lines where the 4 floor planes intersect will not run to the corners anymore, but once you tile it is not really noticeable.
Winchester is online now
Old 05-24-2009, 04:38 PM   #8
72chevy4x4's Avatar
Re: Kerdi Shower Q.
will the 72"x72" kit give you enough room?
If you put the 8" onto the other side, it will be at the same eight but sloping down. Would make sense to lay an 8" wide mud bed about 1/8-1/4" thick, let it set up and then come back and lay the 8" strip while using a level to keep the slope going. The downside is that end of the shower tray will be slope up to ~1/4" higher then the rest of the tray-using a 12" wall tile you could probably get away without noticing a small sliver taken off the wall.
72chevy4x4 is offline
Old 05-24-2009, 05:59 PM   #9
bathroom guru
jarvis design's Avatar
Re: Kerdi Shower Q.
I always use mud for pans and have a pretty easy way to maintain a level perimeter. I always carry 3/4" plywood strips - 1 1/2" wide by 48" long.
Make a form (a box) approx. 4-6" less than the width and depth.
(ie. if you have a 36x36 shower make your form 30x30 or 32x32)
Center the form in your base area, level it with shims, and pack with mud until level. Remove forms, fill in area between perimeter and flange, and use straight edge(s) to slope your base from your froms to the kerdi drain.
It normally takes about an hour to do a base.
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 05-25-2009, 08:25 AM   #10
orson's Avatar
Re: Kerdi Shower Q.
That's impressive.
I've only done a couple bases and the last one I did was a 3x5.5 that took me about 4 hours. Do you have someone mixing the mud for you or are you mixing yourself?
orson is offline
Old 05-25-2009, 08:28 AM   #11
orson's Avatar
Re: Kerdi Shower Q.
How are you guys dealing with the floor perimeter being out of level doing it this way? Is it not enough to be noticeable in the bottom course of tile?
orson is offline
Old 05-25-2009, 09:21 AM   #12
R&D Tile's Avatar
Trade: Tile installations
Re: Kerdi Shower Q.
Doesn't matter where the drain is, the perimeter is always set level, the pitch will just be greater where the drain is closer to a wall.
Couple of hrs. to mix and place a mud pan.
R&D Tile is offline
Old 05-25-2009, 12:10 PM   #13
I builds'em
Winchester's Avatar
Re: Kerdi Shower Q.
If you use the kerdi pan and cut off a side you wouldn't be consistent the whole way around. I've never used it on a drain that was far enough off center to make it not workable and not noticeable (I don't know about 8" off though).
It's easy to convince the HOs that smaller tiles are better for shower floors for safety reasons, (but they are also more forgiving when it comes to slope changes).
Old 05-25-2009, 09:45 PM   #14
bathroom guru
Re: Kerdi Shower Q.
Originally Posted by orson View Post
That's impressive.
I normally do have a helper working with me who gets the fun job of lugging up the concrete, mixing, clean-up, etc.
I used to spend a lot more time making sure I had a level perimeter to start off with....not so anymore!!
519-495-4062
Old 07-06-2009, 01:28 AM   #15
coveinspiration's Avatar
Trade: Tile Sles and Installations
Re: Kerdi Shower Q.
I wouldnt use the kerdi pan in this case. It won drain properly as the slope will be out.
coveinspiration is offline
Tile over existing shower surface SK Builders Ceramic & Stone Tile 16 07-06-2009 01:42 AM
leaky shower head Sir Plums Alot Plumbing 3 04-07-2009 09:25 PM
care to share ideas for 2 person shower? 72chevy4x4 Ceramic & Stone Tile 12 02-24-2009 01:47 PM
Tiled shower leaks...Could use any advise at all... Jay22 Ceramic & Stone Tile 17 12-10-2008 07:15 PM
Questions on Tiled Shower ksensen Remodeling 10 09-10-2007 09:54 AM
