Installing Tile Baseboard
Old 11-17-2011, 12:24 AM   #1
PiersonPainting's Avatar
Rewards Points: 14
Just finished laying 12x12 porcelain tile in bathroom. Is there any reason why I cant put up 4x12 tile baseboard and grout everything at the same time?
PiersonPainting is offline
Old 11-17-2011, 12:26 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Installing Tile Baseboard
No but you don't grout the joint from the wall to the floor. That gets caulked.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
J L (11-17-2011), PiersonPainting (11-17-2011)
Old 11-17-2011, 01:08 AM   #3
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
I have to do that tomorrow.. I will post some pictures.. Its a laundry area
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 11-17-2011, 08:14 AM   #4
Rewards Points: 14
I've got matching caulk to do the top of the tile against the wall and seam at the floor. I'll put them on this morning.
Old 11-17-2011, 08:27 AM   #5
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
That is a personal peeve of mine. I believe it should be a finished edge (bullnose, etc) of use a profile. Bare tile edge with caulk looks tacky at best.
Profiles are my choice as they offer multiple shapes, colors and options. They are usually much cheaper than bullnose pieces too.
Angus
angus242 is offline
Old 11-17-2011, 09:50 AM   #6
Orlando Car
This bullnose is what I'm using ..
Goood morning Vietnam !!!!
6:49 a.m. california time..
( 510 ) 760 - 6810
Old 11-17-2011, 09:55 PM   #7
Rewards Points: 14
Say Angus242, am I understanding your post where you said not to grout the spaces between the tile base, 1/4" but instead caulk these spaces? If so, why? I would think you would grout the tile base and the floor at the same time.
Old 11-17-2011, 09:59 PM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
You never grout a change of plane or butting to dissimilar materials.
The walls and floor will move in 2 different directions (therefore are a change of plane). Cementitious grout will crack. Silicone is flexible to about 25% (if I'm not mistaken) and will absorb the differential movement.
Angus
angus242 is offline
Old 11-17-2011, 10:10 PM   #9
Rewards Points: 14
Ok, bear with me. I know not to grout the seam between the floor and base tile. But the vertical spaces between each base tile would get grouted to match the floor, yes?
Old 11-17-2011, 10:12 PM   #10
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Yep!
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
Old 11-19-2011, 06:01 PM   #11
UrbanTile's Avatar
Trade: Tile and Stone Installation
I think 3 inch bullnose looks funny as base trim. I get the finished edge thing but almost every tile has one good painted edge and as long as that is faced up then I think it looks good. I like trim more 5 or 6 inches than the 3 inches though.
On grouting...why don't you just grout between the floor and the base and on top of the base and then color caulk it or clear silicone it after it is dry? That is what I do and I just use my margin trowel to square off the grout in both areas.
UrbanTile is offline
Old 11-19-2011, 06:34 PM   #12
Tile & Marble Contractor
Ceramictec's Avatar
Trade: Tampa Tile Contractor
Rewards Points: 250
yikes !
-Brian-
Brandon Lutz Bradenton Tampa Oldsmar Westchase New Port Richey Seminole St. Pete Wesley Chapel Sarasota
website: www.ceramictec.com
Ceramictec is offline
Old 11-19-2011, 06:49 PM   #13
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
ohiohomedoctor is offline
Old 11-19-2011, 07:01 PM   #14
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,912
Most base tiles that I have laid were travertine, so they looked too nice to cover with a finished edge. As for ceramic, I have used a nice edge. On only a few have I just caulked it. The HO didn't want to spend any more $. They just wanted me to cut the tile to 4" and run with it.
Angus, don't you caulk the finished edge? If not, how do you deal with wavy walls?
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
Old 11-19-2011, 07:13 PM   #15
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I use a profile. Has a very small "lip" on the back. I will use painters caulk to fill that and the painters follows me and does his thing. Nice transition from the paint to the profile. Looks great.
I understand HO's have budgets. However, unfinished tile is not an option for me. It's my name on the install. Just like I wouldn't "cheapen" what's under the tile, I won't do it for the finish either. Just how I roll....
Angus
angus242 is offline
katoman (11-19-2011)
Old 11-19-2011, 07:31 PM   #16
I use whatever the customer can afford.
Old 11-19-2011, 07:39 PM   #17
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Originally Posted by UrbanTile View Post
OThat is what I do and I just use my margin trowel to square off the grout in both areas.
True tile professionals stop using their margin trowel because their fingernail squares off at the tip. That's how you can tell a pro from a handyman/DIY. With painters, it's slightly different, but that's a professional secret I can't divulge on the internet unless I post it.
CO762 is offline
Old 11-19-2011, 07:49 PM   #18
CO762's Avatar
There are different grades of travertine. I have a love/hate relationship with the tumbled stuff. When I do that, I'm referred to as "tile slayer" because with those, you can get away with murder. Some people like that look. But then again, some folks like rough tile and way wide joints.
Heck, some folks like un/semi gauged stuff. Must be art.
CO762 is offline
Old 11-19-2011, 07:52 PM   #19
CO762's Avatar
Did you tell the customer beforehand you were a painter and don't know a lot about tile?
CO762 is offline
Old 11-19-2011, 11:21 PM   #20
Rewards Points: 14
Yep, but I've done alot of other things for them besides painting, so they didn't have a problem with me laying the tile. You"ve got to start somewhere and theres people like you and others that replied to this post with all the answers, Thanks
Bought a new Ridgid tile saw...any reviews here? IHI Tiling 45 11-24-2012 01:03 PM
Tile Over Gypcrete Golden Rule Tiling 6 11-26-2010 04:00 PM
how to install tile baseboard AustinDB Tiling 11 02-06-2009 09:47 PM
installing tile under cabinet AustinDB Tiling 3 09-23-2007 12:27 AM
