Ice Removal Question
Old 01-10-2009, 04:24 PM   #1
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
What would be the safest ice removal product to use on exterior slate walks and patios? Salt has destroyed my side walk over the years and once I get it repaired I'd like to have it last a little longer than 4 years.
Thanks,
Jason
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 01-10-2009, 05:26 PM   #2
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Re: Ice Removal Question
Salt is cheap, but destroys almost anything it comes in contact with. You should use a non salt ice melter. I think they're made with Potassium Chloride or Magnesium Chloride? Even then it would be best if any concrete product cure for about 1 year before using these better ice melters. Maybe use sand the first year?
Jaz
Tile 4 You llc
KERDI Shower
specialist...DITRA Installs...
www.tile4you.com
JazMan is offline
Old 01-10-2009, 05:37 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Radiant heat after you tear it out.
WarnerConstInc. is online now
Old 01-10-2009, 05:49 PM   #4
Handle It!
MALCO.New.York's Avatar
Jaz
^^^^BOTH Salts. And VERY reactive and corrosive!^^^^
HALITE, the most common Ice Breaker, is Sodium Chloride, NaCl, Table Salt!
Salt is a Generic term for an Anonic and Cationic union of elements. Most commonly Meltal Chlorides. And YES!!! Calcium IS a Metal!
http://en.wikipedia.org/wiki/Salt_(chemistry)#Nomenclature
Metal Chlorides raise the Boiling temperature of Water and Lower the Freezing point of Water and that is how they work. HALITE and Ice Melters do NOT work in EXTREME temps.!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 01-10-2009, 05:54 PM   #5
Mellison's Avatar
Trade: Home Improvement General Contractor
Calcium Chloride.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Old 01-10-2009, 05:59 PM   #6
Steve
OCRS's Avatar
Yep
OCRS is offline
Old 01-10-2009, 06:02 PM   #7
nlgutters's Avatar
Trade: seamless gutters
The wife with a hair dryer. They love to feel needed.
nlgutters is offline
Old 01-11-2009, 01:02 AM   #8
olzo55's Avatar
Trade: flooring
don't use slate again. choose a frostproof porcelain. slate seems like a poor choice for an exterior application in your neck of the woods.
olzo55 is offline
Old 01-11-2009, 05:08 PM   #9
Restoration Crazy
That's going to be a tough one. I live in an area called "Slate Valley" Everything around here seems to be made from slate. Roofs, sidewalks, chimney's, even cladding for buildings. Some work is over 200 years old and all is well.
I'd be hard pressed to tell anyone it's no good for our area when theirs proof everywhere that it is. I do need to give them a clue as to how they can avoid these types of problems by useing an alternate method of ice removal.
Facebook | Twitter
Old 01-11-2009, 06:05 PM   #10
Trailer park boy
shanekw1's Avatar
Maybe this?
www.organicmelt.com
shanekw1 is online now
Old 01-11-2009, 10:55 PM   #11
olzo55's Avatar
Trade: flooring
Jason, not trying to be arguementative but you have all of those examples around you so maybe you could ask someone there what they use on their sidewalk to keep the ice off. could their be some grout/thinset/sealer they used and you didn't? seems like you're in the right place (slate valley) to ask a manufacturer what they recommend.
olzo
olzo55 is offline
Old 01-12-2009, 12:05 AM   #12
Handle It!
HALITE has been the New England Standard for 100 years. Taint nothin new about it. Maybe it is the CaCl that is causing the problems??? It is "Newer".
Old 01-12-2009, 07:23 AM   #13
DavidC
DavidC's Avatar
A rock is a bad choice for outdoors????
Maybe I missed the punchline.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 01-15-2009, 06:21 PM   #14
Warmsmeallup's Avatar
Trade: Sales/Distribution/Installation of low or line voltage radiant heating and snow melting systems
You could definitly install an electric radiant system directly under the slate. It will keep all ice/snow from building and the low voltage elements last 25 years.
This is a driveway in Colchester with low voltage in the asphalt.
(for those who are bound to ask...$1.30 per running hour for this job)
Warmsmeallup is offline
Old 01-19-2009, 10:25 AM   #15
olzo55's Avatar
Trade: flooring
Dave C, not all rock is a great product for outdoor walks. there are slates not as dense as a Vermont slate (if that was indeed used)that spall more than others.
Called Vermont Structual Slate because i want to know the answer to this question. they said it didn't matter what type of salt you used as it is going to wear the surface prematurely. they didn't recommend using a sealer either.
olzo55 is offline
Quick weather question Just-In-Time Masonry 9 11-19-2008 06:38 AM
Answer a Question with a Question Nathan Off Topic (Non Trade) 151 10-07-2008 03:07 PM
wallpaper removal question rocco Wallpaper 3 01-30-2006 03:19 PM
