I Can't In Good Conscious Install This, Can I?
Old 09-04-2017, 06:23 PM   #1
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,302
Client picked out a shower floor tile, I sent the order to my rep and it got delivered. I hadn't seen it in person before placing the order. Turns out it's a highly polished porcelain 24x24 tile. I'm thinking way too slippery.
Golden view is offline
Old 09-04-2017, 06:28 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 9,134
Re: I Can't In Good Conscious Install This, Can I?
That sounds like a recipe for disaster . Traction in shower floors is accomplished by the grout,hence mosaic tile offers the most slip resistance. The tile mentioned will be like a skating rink.
fjn is offline
Golden view (09-04-2017)
Old 09-04-2017, 07:07 PM   #3
edward trowelhands
Trade: Diplomat
I'm not even sure I'd want them on the rest of the bathroom.
Rio (09-05-2017)
Old 09-04-2017, 07:23 PM   #4
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 188
Porcelain tile has "Co-Efficient of Friction" rating. It's expressed as a decimal.
For ADA compliance, public walking surfaces need to have a COF of .50 to .90, depending on the location, just to give you an idea of the range.
Below .50 is considered slippery. I've installed quarry tile that had a COF of .95, when wet. Can't slip on that if you tried.
A lot of glazed porcelain will be well below .40.
It might be informative for them to check what the wet COF on that stuff is. Might surprise them.
Delta
I have an Edifice Complex.
The Following 5 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Jaws (09-04-2017), Metro M & L (09-04-2017), Philament (09-05-2017), Rio (09-05-2017), TNTSERVICES (09-04-2017)
Old 09-04-2017, 07:30 PM   #5
edward trowelhands
Trade: Diplomat
Delta
That's very helpful. I find it hard to believe but this says >.6 COF wet and dry. Also lists applications as interior and exterior showers in residential & commercial. Google TCR PPO WH60 and it should come right up.
Maybe we should do a dry (wet) run? Test it barefoot...
For what it's worth the shower has a linear drain and has a 3/16" per foot slope.
The Following 2 Users Say Thank You to Golden view For This Useful Post:
Rio (09-05-2017), Seven-Delta-FortyOne (09-05-2017)
Old 09-04-2017, 07:31 PM   #6
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,338
People break their necks in showers all the time. You will be held accountable if that happens.
Metro M & L is offline
Old 09-04-2017, 07:38 PM   #7
edward trowelhands
Trade: Diplomat
If I follow code, TCNA guidelines, manufacturers guidelines, and pass inspection?
Old 09-04-2017, 07:41 PM   #8
edward trowelhands
Trade: Diplomat
Read some interesting newer info from TCNA. There's a new test that makes more sense. The old test is static friction. The new test is dymanic friction. If the COF drops from .6 to .1 once you start slipping, you're screwed.
Rio (09-05-2017)
Old 09-04-2017, 08:14 PM   #9
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,654
Not if the supplied the tile and it meets standards.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
Old 09-04-2017, 08:15 PM   #10
Hair Splitter
Trade: General
The back of most tile boards will give you the pertinent information, but I always pull the spec sheet form the manufacturer.
The Following User Says Thank You to TNTSERVICES For This Useful Post:
Rio (09-05-2017)
Old 09-04-2017, 10:32 PM   #11
Particulate Filter
Trade: Flooring
Of course, but if he installs something that doesn't meet the requirements he can kiss his business goodbye in the event of a slip and fall.
Old 09-04-2017, 10:33 PM   #12
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Some days you just cannot win. This was ordered after my strong Caution that it will be dangerous.
900sf, 24x24 polished porcelain, there will be another inlay in front of the door.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
The Following User Says Thank You to charimon For This Useful Post:
Old 09-04-2017, 11:46 PM   #13
edward trowelhands
Trade: Diplomat
To be honest, I don't lose sleep over fear of lawsuits. But I would lose sleep if someone hurt themselves because of something I did.
fjn (09-05-2017)
How to properly install a light over a kitchen sink. 480sparky Electrical Picture Post 23 05-03-2015 09:00 PM
Quality fence install! BCConstruction Decks & Fencing 7 04-22-2013 12:45 PM
2-1/4" oak install glkirk Flooring 21 01-23-2013 02:45 PM
Business has been good Californiadecks Decks & Fencing 18 01-17-2013 07:05 PM
