How To Prep A Wavy Cement Slab For Tile
Old 09-24-2006, 05:16 PM   #1
Nick S.'s Avatar
Trade: handy man
I know i cannot use only adhesive to bind backer board to the slab. Should i level out the existing slab and then use masonry nails and adhesive to bind the backerboard? Any help would be greatly appreciated.
Nick S. is offline
Old 09-25-2006, 01:03 AM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: How To Prep A Wavy Cement Slab For Tile
If it is just a few places or small I would use thinset. I wouldn't be installing back board on a slab.
Mike Finley is offline
Old 09-25-2006, 01:08 AM   #3
mdshunk's Avatar
I was on a commercial job a while back where they had a use a terazzo grinder to shave off a few high spots before tiling. I'm not sure how bad your deal is or if that's even an option for you.
mdshunk is offline
Old 09-25-2006, 06:32 AM   #4
R&D Tile's Avatar
Trade: Tile installations
Once again like Mike said, No CBUs over slabs, they won't level anything either, for small depressions, maybe some modified thinset, otherwise use SLC, then a crack isolation membrane if there are cracks in the slab, also, make sure the slab isn't painted or sealed.
R&D Tile is offline
Old 09-25-2006, 07:16 AM   #5
Nick S.'s Avatar
Trade: handy man
Thank you all. After what u have told me I intend to use a chisel to bust down a high spot, and then use thinset on the low spots. Should i scar the slab up a little bit for a better bond?
Nick S. is offline
Old 09-25-2006, 07:43 AM   #6
R&D Tile's Avatar
As long as water doesn't bead up on it, you'll be fine, no cracks right?
R&D Tile is offline
Old 09-25-2006, 07:49 AM   #7
Nick S.'s Avatar
Trade: handy man
no cracks . Is it necessary to scar the slab or not?
Nick S. is offline
Old 09-25-2006, 09:19 AM   #8
Chief Toilet Mover
No.
Another issue is control joints.
Old 09-25-2006, 02:03 PM   #9
Nick S.'s Avatar
Trade: handy man
The slab is the entire bathroom floor and it is about 7x5. How many control joints should i cut? And where?
Nick S. is offline
Old 09-25-2006, 02:40 PM   #10
R&D Tile's Avatar
NONE, leave a gap around the room 1/8" for expansion and cover with tile or molding.
R&D Tile is offline
Old 09-25-2006, 06:09 PM   #11
Chief Toilet Mover
None.
I leave a 1/8 inch gap because I suck, and it's going to be covered by molding. Now I can use a real excuse, thanks R&D!
Old 09-25-2006, 07:22 PM   #12
747's Avatar
If your going to tile over that cement. You should do a old fashion mud job before you lay the tile. This way you can level it perfectly.
747 is offline
Old 09-25-2006, 07:51 PM   #13
R&D Tile's Avatar
That would be fine if they knew how, it also adds 1 1/4" height to the floor, they would also have to know how to bond it to the slab or use slip sheet and lath, for a such a small area, SLC would work better and be less labor for a first timer attempting this, yes, mud is cheaper to do, but alot more involved, just my .02 worth.
R&D Tile is offline
Old 09-25-2006, 08:59 PM   #14
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
Another technique you can use is use the modified thinset and use a skreet board as long as the room and skreet the low spots out. Kind of like smoothing out cement at first.
Eric K is offline
Old 09-25-2006, 09:06 PM   #15
747's Avatar
I was thinking more like seeing how he kind of messed the concrete up it is salvageable if he had a oldtimer come in and do a mud job. Key being oldtimer tile man. I had a tile floor put down in my bathroom got a oldtimer to do it. He did a full mud job first made it look easy
747 is offline
Old 09-28-2006, 04:29 PM   #16
Nick S.'s Avatar
Trade: handy man
when i leave the 1/8 gap do i grout that or leave it open? also what is SLC. Thanks
Nick S. is offline
Old 09-28-2006, 04:43 PM   #17
Teetorbilt's Avatar
Self Leveling Concrete. It can save a lot of grinding dust.
Albert Einstein
Teetorbilt is offline
Old 09-28-2006, 04:44 PM   #18
Chief Toilet Mover
If you are leaving it as an expansion gap then you wouldn't want to grout it right?
We silicone it as another preventative measure for water infiltration into the sub floor.
Old 09-30-2006, 09:21 PM   #19
Dan
ApgarNJ's Avatar
Send a message via AIM to ApgarNJ
i have prepped my last few shower pans with that redguard sealer that helps tile bond to concrete. homerdepot is the only place i saw it at though. not that i ever go in there or anything.......shhhhhhh.
i used two coats of it and it turned out great.
makes for a great clean surface.
ApgarNJ is offline
Old 10-01-2006, 09:50 AM   #20
R&D Tile's Avatar
Redgard is a waterproofing membrane, doesn't help in adhereing the tile, a good quality thinset does, where did you use it, on the floor of the pan?, yes, it's rated for this, but a sheet membrane or Kerdi is the way to go.
R&D Tile is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
built up slab question stampcrete Concrete & Paving 9 03-27-2008 05:24 PM
drywall mud over cement? mudgirl Construction 7 07-20-2007 08:27 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
Basement slab question n74tg Masonry 5 05-26-2006 04:38 PM
