How Many Courses For Ceramic Tile Shower Walls?
Old 10-07-2008, 05:54 PM   #1
Bazooka Joe's Avatar
Trade: Drywall
Hi guys,
...i know, dumb question. I have a shower in my home to tile, and was wondering how many courses i could go up in one day. The shower walls are to the ceiling (8'). Would it be safe to tile the walls all the way up in a day? Im renting a saw, so im trying to get a budget idea.
Im using typical 4" ceramic tiles and thinset over tile backer board.
thanks
Bazooka Joe is offline
Old 10-07-2008, 05:59 PM   #2
Remodeling GC
kevjob's Avatar
Re: How Many Courses For Ceramic Tile Shower Walls?
depending upon layout with a cut tile as your first row set on a ledger and any borders, you can tile all the walls one day and then the pan and 1st course of wall tiles if they are cut after you remove the ledger.
kevjob is offline
Old 10-07-2008, 05:59 PM   #3
Professional Instigator
rbsremodeling's Avatar
Originally Posted by Bazooka Joe View Post
Hi guys,
thanks
Yes You can go all the way up.
rbsremodeling is offline
Old 10-07-2008, 06:28 PM   #4
Trade: Drywall
..thanks very much for the replies guys
Old 10-07-2008, 07:06 PM   #5
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Mark a level line about 6 courses above the tub / shower. Then be sure you can fit the tiles going down to the perimeter of the shower. Adjust the line accordingly. Using your notched trowel apply the thinset right to the line. Do the bottom part first. It'll set up and then do the top courses. If not the top tiles may push down and all will not look too good. Then its too late. You can also mark a vertical plumb line about 2 ft from the corner from top to bottom. Use it the same way rather than work out from the corner. You're making grid lines to work from. Measure or space some dry tiles around so you can have full / larger tiles where you want them.
We Fix Houses is online now
Old 10-07-2008, 10:33 PM   #6
tile mason
MattCoops's Avatar
That is by far the wierdest way to layout a shower wall.
Where did you get those ideas from?
MattCoops is offline
Old 10-07-2008, 10:35 PM   #7
genecarp's Avatar
for sure
genecarp is offline
Old 10-08-2008, 06:45 PM   #8
R&D Tile's Avatar
Trade: Tile installations
No comment on that, staying out of this.
R&D Tile is offline
Old 10-09-2008, 06:09 PM   #9
Tile Contractor
Bud Cline's Avatar
WOW!
For once I actually agree with Coops!!!
Bud Cline is offline
Old 10-09-2008, 10:23 PM   #10
Tiling & Bath Contractor
TileLady's Avatar
Trade: Tiling & Bathroom Remodeling
It sounds like a technique from a tiling book from HD or something.
TileLady is offline
Old 10-09-2008, 10:27 PM   #11
So you guys have never heard of the 6 tile from the bottom, level it from the corners method before??
Old 10-11-2008, 06:54 AM   #12
Jerry T's Avatar
Trade: Self employed - hard surface installer
I love this place
Jerry T is offline
Old 10-11-2008, 03:32 PM   #13
Knowledge Factory
Floordude's Avatar
This is what is wrong with the flooring trades. Most have no clue. Those that do, get told they are too high priced.
If everyone was required to have formal training and actually pass hands on tests and written test, before they were allowed to make a profit from their labor, things would be much better in meeting customers expectations, and the installations would last well beyond the one year wonder warranty.
http://www.AustinFloorguy.com
Floordude is offline
The Following User Says Thank You to Floordude For This Useful Post:
PrecisionFloors (02-14-2009)
Old 10-27-2008, 09:56 AM   #14
GRR's Avatar
Trade: Interior Renovation Specialist
Here's the thing Gentlemen..Im asuming were all gentlemen here if not im sorry..LOL This poster has tried to expalin his way of installing tiles..To each thier own right! What I dont see in the responses following were the right way to install shower wall tiles. Please advise on the correct method so we all may be as good as you fellows!
GRR is offline
Old 02-14-2009, 11:50 AM   #15
Ford Guy's Avatar
Trade: carpenter
The easiest way I have found to lay a shower wall or any wall for that matter is as follows. Start with a LEVEL ledger, Lay one wall at a time. Use tile spacers on the horizontal grout lines to stop the tile from sliding or droping. In my experience with a 4" x4" tile you can use a premixed mastic glue, as long as you read the directions and make sure that it is water and mould proof. The only time you really need thinset on a wall is when you have a large heavy tile. Also make sure your tile backer board is waterproof, if nnot you definatly need a membrane, shuch as the schluter system(Kerdi mat).
Ford Guy is offline
Old 02-14-2009, 11:51 AM   #16
Ford Guy's Avatar
Trade: carpenter
I guess there was no point in me replying. I just read the dates.
Ford Guy is offline
Old 02-14-2009, 11:55 AM   #17
Forry's Avatar
Trade: General Contractor, Remodeler
Wrong. Hi Ford Guy. First, this is a pretty old post, and I'm sure his shower is done, but never, ever. ever use mastic in a shower again. Don't do it. Guaranteed failure. Mastic is an organic compound an will over time (usually not much) get wet and melt, then mold, then tiles will come loose. Use only thinset in a shower. And never use tile directly to any type of sheetrock in a wet area either. Ok, class dismissed.
now i am scared for my future
i've got all ten
smashed a lot of them stupidly before
-john5mt
Forry is offline
The Following User Says Thank You to Forry For This Useful Post:
kevjob (02-14-2009)
Old 02-14-2009, 01:21 PM   #18
Remodeling GC
kevjob's Avatar
mastic?
kevjob is offline
Old 02-14-2009, 01:37 PM   #19
Its all ball bearings
angus242's Avatar
Trade: Tile
Originally Posted by Jerry T View Post
I love this place
Ditto!
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is offline
Old 02-14-2009, 11:06 PM   #20
bathroom guru
jarvis design's Avatar
Mastic is way too expensive these days - I have switched to peanut butter with a little elmers glue mixed in....smooooth!!
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Tile in shower? gtmstang Flooring 14 09-23-2008 09:55 PM
Tile Debate - Shower floor 1st or shower wall? Logan's Ceramic & Stone Tile 21 08-03-2008 02:27 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Subway tile Shower remodel MattCoops Ceramic & Stone Tile 20 01-05-2008 07:52 PM
Questions on Tiled Shower ksensen Remodeling 10 09-10-2007 09:54 AM
