How Long To Tile 100 Sq/ft
Old 02-08-2007, 10:59 PM   #1
crankin's Avatar
I'm trying to really break down my cost per hour. I'm wondering how long should it take to lay on average 100 square feet of ceramic tile. Not including tearing up the old floors and all that. Just to lay the tile. I've been hearing 1 hour per 100 square feet, and I've heard 10 hours per 100 square feet. What's right?
crankin is offline
The Following User Says Thank You to crankin For This Useful Post:
superior1 (05-21-2009)
Old 02-08-2007, 11:23 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: How Long To Tile 100 Sq/ft
You mean like get ready, get set, go...
Not including any time for setting up the saw, mixing thinset, measuring and laying out to decide your layout? There's a lot more that goes into it. Like asking how long does would it take you to lay 1 tile? about 25 seconds to lay the tile and 45 for everything else.
I used to be able to lay out about 100 square feet including set up and everything inbetween lay the tile and clean up and break down in about 4 hours. Probably 1/2 of that time was everything other than laying the tile.
Mike Finley is offline
Old 02-09-2007, 08:19 AM   #3
SAGE
sage's Avatar
Trade: Remodeler and Finish Carpenter
That's not right, assuming there are no special circumstances.
-Lead from the front, or dont lead at all-
sage is offline
Old 02-09-2007, 09:32 AM   #4
Thom
thom's Avatar
Doing two 50 square foot bathrooms is going to take just a bit longer than 1/10th of a 1000 sq ft room.
Cuts, especially where the cut is more than a single slice, take time. Cutting a nice circle in tile around a commode flange takes a lot of time. Taking a U out of a tile where it wraps around a wall at a door takes a bit of time. It takes longer to do a walk in pantry (tight working conditions and lots of cuts, than an open room.
So, the answer is, there is no correct answer to the question you asked.
thom is online now
Old 02-09-2007, 12:31 PM   #5
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
$125.95
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 02-09-2007, 03:12 PM   #6
R&D Tile's Avatar
Trade: Tile installations
Originally Posted by ron schenker View Post
$125.95
$500 minimum, figure it's a days pay either way.
Ron, you want a job?
R&D Tile is offline
Old 02-09-2007, 05:14 PM   #7
I was kidding. The thread isn't even about money
But you're right, I charge 5 bucks/sq.ft. to tile, grout and seal if it's a small straight forward job.
Old 02-09-2007, 06:31 PM   #8
R&D Tile's Avatar
I knew you where kidding.
How anyone can tell someone else what to charge and without seeing it or not knowing their situation is beyond me.
R&D Tile is offline
Old 02-09-2007, 06:53 PM   #9
Professional Remodeler
firemike's Avatar
Union job??????
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 07-21-2007, 07:08 PM   #10
superboy's Avatar
i can set 250-300 sq.ft floor tiles(12x12) a day.
superboy is offline
quarry tile to quarry tile rservices Flooring 8 01-15-2010 12:37 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Bad tile job AAPaint General Discussion 9 07-26-2006 04:56 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
