How To Install Tile Baseboard
Old 09-20-2007, 01:29 PM   #1
72chevy4x4's Avatar
putting together a bid for a small bathroom floor install using 13" tiles. Customer wants a 5"x13" bull nose tile used as a baseboard (instead of the a new wooden baseboard installed). Other then pulling off the old baseboard, how should a tile be laid as the baseboard? I would guess cut off the wallboard, install proper backing then tile over it-is that correct?
72chevy4x4 is offline
Old 09-20-2007, 01:54 PM   #2
tile mason
MattCoops's Avatar
Re: How To Install Tile Baseboard
Remove the old baseboard.
Cut a line through the caulking off the top of baseboard, where meets wall.
Get a 5 in 1 or small flatbar to pry the baseboard off.
Your wall should be in descent shape to install tile baseboard.
There really isn't a necessity to install backerboard down there.
You can tile over drywall in non wet areas. It's an acceptable installation method approved by TCA.
MattCoops is offline
Old 09-20-2007, 03:03 PM   #3
Knowledge Factory
Floordude's Avatar
No backer board needed. You may need to patch in some sheetrock strips or mud it in, if it is messed up down there behind the baseboards.
Remember to leave a gap and the plane change, and fill it with color matching sanded tile caulking.
http://www.AustinFloorguy.com
Floordude is offline
Old 09-20-2007, 03:04 PM   #4
HJ1's Avatar
Trade: Tile Contractor
Remove the baseboard like Matt said. If the bullnose is really 5" x 12" (doesnt sound right) you may have to rough up the paint on the wall above where the old baseboard ended. Wipe the drywall down with a sponge to remove any drywall, sanding dust etc. You can use the same modified thinset on the walls that youll be using on the floor. You need to leave a small gap between the floor tile and base tile - I like that joint to be as small as possible, 1/16" or so is good. Caulk that joint with a color matched caulk. Grout will crack if you use it there.
HJ
HJ1 is offline
Old 09-20-2007, 04:39 PM   #5
72chevy4x4's Avatar
thanks for the tips guys. I just looked up the info on the tile, it's Marazzi Vesale Stone and the trim is 3x13, not 5x13 as I previously posted. The HO claims the trim piece is a bullnose-if so is that going to be an acceptable baseboard alternative? Is there a new grout that doesn't require sealing?
Old 09-20-2007, 04:46 PM   #6
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
I have always had good luck with Marazzi products, should be good to go. Look into Laticrete's Spectra Lock grout at Lowes....fair warning it is expensive but it does work very well and doesn't require a sealer as it is an epoxy grout.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 09-21-2007, 01:05 AM   #7
Knowledge Factory
Floordude's Avatar
The last marrazi tiles I did, were junk. They varried in sizes as much as 3/16
Look how far out this tile is in the picture. No two grout lines were the same size on this job. They loved it, but I was picking it apart the whole way, in a frustrated freenzy. Took me 4 times as long as it should, because I was so picky.
Old 09-21-2007, 05:37 PM   #8
^^^ Sounds like you got ahold of some defective tiles....I thought size variance should be no more than 1/8"?
Precision Flooring
(772) 237-9900
Old 02-06-2009, 08:26 PM   #9
kart19's Avatar
Trade: Finish Carpentary
Is there anything wrong wiht Home Depot tile?
kart19 is offline
Old 02-06-2009, 08:33 PM   #10
Dufus Extrodinaire
BHR's Avatar
Not really other than HD sells it
Tile is tile really just check the side of the box for the class type number - usually 1 to 5. 1 is junk, normally you would want industrial/class 4 or 5
BHR is offline
Old 02-06-2009, 08:34 PM   #11
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
I dig the stuff, especially the selection, all 6 of them.
Mike Finley is offline
Old 02-06-2009, 09:47 PM   #12
bathroom guru
jarvis design's Avatar
3" bullnose seems a little small for baseboard? I normally use a tile edge for the top - finishes it off really nice and makes painting a lot easier
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Tile Install Price Fetam General Discussion 21 09-10-2007 09:37 AM
tape all drywall seams before ceramic tile install? zmusashi General Discussion 3 08-24-2007 09:04 PM
outdoor tile install southcoastbuild Flooring 3 01-09-2006 11:03 AM
Old home baseboard receptacle install..... toddgotfish Electrical 11 11-30-2005 07:20 PM
