How To Handle A Hump In The Wall - Tiling - Contractor Talk
Old 05-30-2018, 10:24 PM   #1
AustinDB's Avatar
Rewards Points: 876
MBA with a 9 shower/drying area with an adjacent 11 vanity and one piece mirror to the left.
The white line represents a high spot due to construction where the wall juts into the room by 3/8. The wall to the left and to the right are fairly in plane, meaning that single jack/king stud isnt proud, its like a pivot point.
Wondering what other strategies are out there to deal with this.
The tile on this wall is a 3x5 subway, so I can lose the difference gradually. If it were a 24 wide running bond, it would need to be a flat wall.
AustinDB is offline
Old 05-30-2018, 10:47 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 3,592
Re: How To Handle A Hump In The Wall
Plane the offending stud down to plane either with a power planer or some type of saw you are comfortable with.
griz is offline
The Following 9 Users Say Thank You to griz For This Useful Post:
B.D.R. (06-02-2018), B.Johnson (05-31-2018), hdavis (05-31-2018), Jaws (05-31-2018), Robie (05-31-2018), Sir Mixalot (05-31-2018), tang (06-01-2018), Texas Wax (05-30-2018), Youngin' (05-31-2018)
Old 05-30-2018, 11:11 PM   #3
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,296
I would use cardboard drywall shims.
Start with one shim (about 1/16" thick at the stud close to the pivot point then two at the next stud 16" away etc. you would end up only about 1/8" out of plane by the time you are done then use the board you intended to on the wall for the tile.
If you are not using board and you are floating the wall then, why are you bothering us? Haha.
Andy.
ScipioAfricanus is offline
The Following 4 Users Say Thank You to ScipioAfricanus For This Useful Post:
Californiadecks (06-02-2018), Sir Mixalot (05-31-2018), TheConstruct (05-30-2018), TNTSERVICES (09-19-2018)
Old 05-31-2018, 06:27 AM   #4
t.carpenter00's Avatar
Trade: excavating/ drywall/ currently remodeling
Rewards Points: 230
I agree with Andy. Except, I would probably shim the 1st stud left to the same plane as the offending jack stud, maybe a 1/16 th less. Then I'd stim the last 2 very slightly , leaving a deep recess where the old an new rock come together. I'd fill that recessed butt joint full. And the I would hop it would get lost in the mirrors shadow line. Because any arc in the subway tile is going to show from the counter, no matter what.
Sent from my VS988 using Tapatalk
t.carpenter00 is offline
The Following User Says Thank You to t.carpenter00 For This Useful Post:
ScipioAfricanus (05-31-2018)
Old 05-31-2018, 06:32 AM   #5
jeffmattero76's Avatar
Trade: Property Manager
Rewards Points: 48
If it is just one stud, I would agree with griz and plane it down with a power planer (my cheap Robin works very well at this task).
Otherwise, I would suggest ripping some 1 1/2" or 2 inch wide strips of plywood of different thicknesses. Put a long level horizontally across the studs and "pack-out" each of the adjacent studs so that you get a flat plane. I rehab my rental properties, and always have cutoffs of plywood left at the end. For the ones that are 4 foot long or longer, I rip them into strips, specifically for this purpose, rather than throwing them away. To me, this is better and easier than cardboard shims.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is offline
Old 05-31-2018, 07:02 AM   #6
tjbnwi's Avatar
Rewards Points: 5,400
Sounds like it’s the areas to either side of the lines that are off from each other, not one stud.
If the area to the right of the line is the high area shim the area to the left of the line to be on plane with it. Work to get the wall on plane to the high area, it is much easier than trying to get the high area back to the low area.
Use a vertical plane laser aligned to the high area. Place screws in the top and bottom plates aligned to the laser plane, shim between the screws. Other option is wet shimming the board.
Is that large window in the shower area? Appears to me it will be with the mixing valve location.
tjbnwi is online now
Old 05-31-2018, 10:36 AM   #7
AustinDB's Avatar
Rewards Points: 876
Its not one stud, more like two straight walls that meet at the white marked stud. The header is straight.
I tried to talk him out of a window or at least putting a window high on the wall. An acrylic glass block window is going in place of the picture window.
AustinDB is offline
Old 05-31-2018, 10:50 AM   #8
hdavis's Avatar
Rewards Points: 3,793
3/8 inch out on one stud, studs exposed as shown, I'd plane that wall with a sledgehammer.
hdavis is online now
The Following 3 Users Say Thank You to hdavis For This Useful Post:
AustinDB (05-31-2018), rblakes1 (05-31-2018), SmallTownGuy (05-31-2018)
Old 05-31-2018, 03:24 PM   #9
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,252
Its one stud. If you cant plane it, cut the nails top and bottom with a sawzall, cut the stud in half and replace it.
sparehair is offline
The Following User Says Thank You to sparehair For This Useful Post:
Old 05-31-2018, 06:22 PM   #10
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,868
Is this a reading comprehension test? Because the results are not that good.
It's a bit unusual for a wall to be this way. Both the top and bottom plates change direction at the same spot? If so, shimming backer is your best bet.
Golden view is offline
Old 05-31-2018, 06:26 PM   #11
Renaissance Man
superseal's Avatar
Rewards Points: 5,628
How about a wet bed wall? 3/8" is nothing to get flat as a pancake.
supersealconstruction.com
superseal is online now
The Following 3 Users Say Thank You to superseal For This Useful Post:
Golden view (05-31-2018), Rio (05-31-2018), tang (06-01-2018)
Old 05-31-2018, 07:26 PM   #12
rblakes1's Avatar
Rewards Points: 2,016
I was thinking that, but the window being there would make me a little nervous
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
Old 05-31-2018, 08:10 PM   #13
AustinDB's Avatar
Rewards Points: 876
Im sure someone noticed the 2 vent pipe in the 2x4 wall. I typically see the wall jacked up around vent pipes coming out of concrete, dont think thats the issue on the second floor.
Kerdi Board is up and I got it pretty flat considering. Another example of the screwed up framing: the closet wall next to my board is 5/8 out in 8. Since its going to have the edge of my tile Ill reset the door and float the wall.
Yes, I double checked my jamber to ensure it wasnt screwed up
AustinDB is offline
Old 05-31-2018, 08:17 PM   #14
hdavis's Avatar
LOL, I don't get nervous that easy. Windows aren't usually that fragile.
Old 05-31-2018, 08:48 PM   #15
rblakes1's Avatar
I said it would make me a little nervous, not a lot nervous lol
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
hdavis (05-31-2018)
Old 05-31-2018, 09:01 PM   #16
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 3
I would just shim the whole wall.
cedarboarder is online now
Old 05-31-2018, 11:14 PM   #17
rblakes1's Avatar
Out of curiosity, what's with the sleepers?
rblakes1 is offline
Old 06-01-2018, 08:09 AM   #18
AustinDB's Avatar
Rewards Points: 876
Lowered the floor by 3/4 and extra bracing was installed. Wont get me zero access, but a 1-1/4 closer to floor height.
AustinDB is offline
The Following User Says Thank You to AustinDB For This Useful Post:
rblakes1 (06-01-2018)
Old 06-01-2018, 11:10 AM   #19
madmax718's Avatar
Trade: General
Rewards Points: 3,252
Im with the planing idea as well. What was there before? Cement board or a mud wall?
madmax718 is offline
Old 06-02-2018, 10:53 AM   #20
AustinDB's Avatar
Rewards Points: 876
32 shower on the left with a 72 tub on the right. I think this corner of the house got racked during framing.
AustinDB is offline
Off Center Bearing Wall Milhaus Framing 2 02-11-2016 05:54 PM
Retaining Wall Rebuild Dovetailed Landscaping 22 03-31-2012 08:02 PM
New furred 2 x 6 wall infront of concrete block wall. huntch3 Construction 11 03-27-2012 06:39 AM
Shoring Exterior Load Bearing Wall for Beam insertion larch General Discussion 4 01-27-2012 07:47 PM
Couple questions on Double Stud Wall duburban Green Building 10 01-06-2012 09:46 PM
