How Do You Install Marble Tile On The Ceiling?
Old 05-16-2008, 06:51 PM   #1
c1238's Avatar
Trade: Home Improvement
Hi guys, can anyone tell me what they believe is the best way to install 12"x12"x7/16" white marble tile to the ceiling? Thanks in advance!
c1238 is offline
The Following User Says Thank You to c1238 For This Useful Post:
tedlewis (04-10-2009)
Old 05-16-2008, 07:28 PM   #2
tile mason
MattCoops's Avatar
Re: How Do You Install Marble Tile On The Ceiling?
I'd use white Speed Set and mix it up on the sticky side. Go easy on the water. Little at a time.
MattCoops is offline
Old 05-16-2008, 08:07 PM   #3
Twust1285's Avatar
Trade: Mudset Marble, Tile, Flooring Professional
That will work for the smaller type tiles, I have used some very very heavy large stone on ceilings before and had to cut support boards to hold it up. Very time consuming because it's so hard to get the pieces even and level, but it does work if you have to do that. You could always polish some away I never had to but you could. There is also a pruduct out that i do not have much experience with, but it's called MegaLite and supposedly and can also do this, and from what i hear it's very good for holding a bed on the floor also.
Twust1285 is offline
Old 05-16-2008, 08:14 PM   #4
Dan_Watson's Avatar
With a hard hat
Dan_Watson is online now
Old 05-16-2008, 08:17 PM   #5
genecarp's Avatar
wood supports, while drying.(old school), maybe there are other ways available
genecarp is offline
Old 05-16-2008, 08:58 PM   #6
MVH's Avatar
Trade: General/Remodeling
I was going to say, "Carefully."
Mike
Mont Vista Company, LLC
Alpine, Apache Junction, Gold Canyon, and Mesa, Arizona
Apache Junction Builder
Gold Canyon Builder
MVH is offline
Old 05-16-2008, 10:23 PM   #7
tileguy51's Avatar
Trade: TILE AND HARD SURFACE FLOORING
I put a solid bead of thinset around the edge and a dot in the middle, and when you push it up it creates a suction
Pain is temporary, pride is forever
www.mccowinflooring.com
tileguy51 is offline
Old 05-16-2008, 11:29 PM   #8
c1238's Avatar
Thanks for your quick responded. I will make sure not to forget to wear a hard hat.
c1238 is offline
Old 05-16-2008, 11:42 PM   #9
Teetorbilt's Avatar
Make sure that the substrate will hold it. I screw the H out of Hardie or Durock with adhesive, then use epoxies. 5 min. quicksets to hold and E-Bond for the long term.
Albert Einstein
Teetorbilt is offline
Old 05-17-2008, 02:36 AM   #10
send_it_all's Avatar
You have to turn the house upside down until the thinset dries.
send_it_all is offline
Old 05-17-2008, 03:55 AM   #11
ddm's Avatar
Trade: home remodel/deck builder
I do what tileguy51 does, but I comb the center with the trowel, large formats on the ceiling normally takes me a half a day more or better to put in.
ddm is offline
Old 05-18-2008, 10:45 PM   #12
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Try using one of the non-sag thinsets, like Laticrete's 255 or Mapei's Ultralite. No need to do the bead around the edge or anything else. Notch trowel the ceiling, notch trowel the back of the tile, and stick it in place. No hardhat required, either. And that goes for ANY size tile. With the bigger tiles, they're heavier, granted. But the bonding area also increases proportionately. The only thing that would make a difference would be a change in thickness.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 05-19-2008, 03:28 PM   #13
Knowledge Factory
Floordude's Avatar
Never done a ceiling, but those that I have seen in progress, it looked like a forest of support sticks.
http://www.AustinFloorguy.com
Floordude is offline
Old 05-19-2008, 07:12 PM   #14
tile contractor
I might've done a couple. The only time I ever used support sticks was when the ceiling was one piece 3 cm slab.
Old 05-20-2008, 01:03 AM   #15
Tile & Marble Contractor
Ceramictec's Avatar
Trade: Tampa Tile Contractor
I'm with Bill on this...Mapei UltraLite or TEC 3N1.
-Brian-
Brandon Lutz Bradenton Tampa Oldsmar Westchase New Port Richey Seminole St. Pete Wesley Chapel Sarasota
website: www.ceramictec.com
Ceramictec is offline
Tile over Tile? ak_aiken Ceramic & Stone Tile 9 03-29-2008 11:57 PM
Marble floor tile tips? buildenterprise Ceramic & Stone Tile 11 03-02-2008 01:37 AM
Tile Over Existing Marble Tommy C Ceramic & Stone Tile 5 02-21-2008 12:18 AM
Drywall ceiling in an old house that meets tiled walls. tmt007 Drywall 16 12-11-2007 10:12 PM
Tiling over Marble??? RussellF Ceramic & Stone Tile 5 01-27-2007 08:12 PM
