Hardwood Tile Grout Help
Old 12-30-2017, 06:03 PM   #1
chillaggie's Avatar
Trade: reno
Rewards Points: 2
I searched the subject but didn't see specifics so if I am repeating please pardon me. Had hardwood tile laid by a friend of a friend in October and then again 3 weeks ago to finish project by a professional sub. In both cases the tobacco brown grout is lighter than advertised dry, but when wet is the right color. Have mopped immediately on first installation and waited 72 hours on second, both with same result(water only at first). Tried vinegar solution scrubbing and mopping to no avail. Am I crazy? Do I need to leave it alone and wait to use enhanced sealer or regular sealer? None of the grout has been sealed yet so want to make sure I do the right thing first. Also had 16X16 tile installed in different location and it stayed same color. Know there are grout stains and multiple options but the wifey is on me to fix it since it doesn't look like hardwood. Any help would be greatly appreciated.
chillaggie is offline
Old 12-30-2017, 06:54 PM   #2
avenge's Avatar
Rewards Points: 2,568
Re: Hardwood Tile Grout Help
Are you a contractor? How is grout supposed to look like hardwood?
avenge is online now
Old 12-31-2017, 06:04 PM   #3
rblakes1's Avatar
Rewards Points: 1,000
Too much water in the original mix? Sponge too wet when wiping? If you scrape it, is it darker underneath than on the surface?
The grouts I have used say not to expose to water for usually like a week, so your mopping might be having an adverse effect
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
Old 12-31-2017, 06:56 PM   #4
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,058
So you've come here looking for a new wife?
Inner10 is online now
Old 01-01-2018, 08:02 AM   #5
claycarson's Avatar
Trade: Tile, Marble, Polished Concrete
Rewards Points: 56
Tile that looks like hardwood is becoming more popular.
When it comes to darkening grout, you have options: either stone color enhancing sealer, kinda makes it look like it's wet, which you indicated is what you like.
The other option is to individually recoloring each grout line with grout color sealer, also called grout staining or grout dyeing. That's a slower process, but might not matter if it's just a small floor.
They are mutually exclusive, meaning you can use one or the other, but not both. Do a small sample area first to make sure which look you prefer. The color enhancing sealer is simpler to apply, wipe on, leave for 2 minutes or so then vigorously wipe all off the tile surface. The color sealer is trickier to use, best to watch the video at thisoldgrout.com for a good approach.
Sent from my SM-G920T using Tapatalk
claycarson is offline
The Following User Says Thank You to claycarson For This Useful Post:
MarkJames (01-01-2018)
Old 01-02-2018, 11:52 AM   #6
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,624
Not a contractor. They called it hardwood tile instead of plank tile. And the friend of a friend is a dead giveaway.
Also, they would know that any grout bag will state, color may vary from bag or sample.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
The Following User Says Thank You to TNTSERVICES For This Useful Post:
KAP (01-02-2018)
How to properly seal tile and grout in a Tile soaking tub mdinnocenzo Tiling 6 10-03-2017 07:38 AM
Ready for Tile Bob. Tiling 1 11-18-2012 06:30 PM
Grout in Textured Tile Tips DemRem Tiling 28 07-16-2012 06:58 PM
Different size tile in the same lot HandyHails Tiling 69 02-10-2011 08:40 PM
Tile or Hardwood in Kitchen Bastien1337 Flooring 35 01-13-2011 08:04 PM
