Remodeling Professionals
Hardibacker Down, Ready For Tile-wait?
I just finished up laying the 1/4" backerboard at 7 pm, bedded down in mortar over 3/4" plywood.. Should it sit for a day or can I start tiling in the morning?
Its all ball bearings
Trade: Tile
Re: Hardibacker Down, Ready For Tile-wait?
It's kinda hard to go against manufactures recommendations. If you follow them, chances are very little for something to go wrong.
OK, I know if I don't ask someone else will.......you did screw it down (or nail), right?...
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
You can start installing the tiles as soon as you've finished fastening the CBU. Don't forget the mesh tape on all seams.
Jaz |
Yes, I used 1 1/2" ring shank nails in my Hitachi coil nailer. Worked like a charm! I tried using the backer screws but they were splitting the edges of the boards when I tried to screw them down flush.
I don't know how you tile guys do this day in and day out. Is that why tilesetters retire so young? I'm whooped! Well, I did put in a 12 hour day, laying all the 3/4 ply then all the cbu. Last edited by buildenterprise; 03-11-2008 at 09:10 PM. |
Extra Ordinary
Trade: Remodeling - Specializing in tile
up and down, up and down - I'm getting bionic knees installed next month!
Trade: custom home building
The biatch about floors is that they are down so close to the ground.
#7 | |
Tile & Marble Contractor
Trade: Tampa Tile Contractor
Re: Hardibacker Down, Ready For Tile-wait?Quote:
-Brian- Brandon Lutz Bradenton Tampa Oldsmar Westchase New Port Richey Seminole St. Pete Wesley Chapel Sarasota website: www.ceramictec.com |
tile contractor
Ummmmm, you might want to rethink using ringshank nails in the future. Them little bitty heads on those nails aren't hardly enough for holding down CBU.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
Ummmm, ok.
Remodeling GC
hardy backer wants either the screws or galvanized roofing nails because the of the head size.
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
I understand, but where is it going to go? It's mudded down to the subfloor. I can see the necessity of using screws on wallboard.
Took me all day but I got 'r done. ![]()
tile contractor
Keep in mind-- the mortar between the CBU and the subfloor isn't there to bond the two surfaces together, nor is it expected to. It's there as a cushion.
Nice looking floors, though.
I know you didn't mean to say cushion. Also, most CBU makers recommend using modified thinset, and so it does bond the CBU to the subfloor.
Jaz |
tile contractor
Actuallly, I DID mean to say cushion, and regardless of whether it's modified or not-- I don't know about your area, but around here, most of the subfloors are Advantec. K/K won't stick to it, much less anything else. It's not there to bond one surface to the other. Ask your area rep. Just for the record, TCNA recommends UNmodified, even if they qualify it by deferring to manufacturer's recommendations.
Re: Hardibacker Down, Ready For Tile-wait? |
and i forgot to ask for a clarification of 'cushion'?
Should I bother sealing the tile before grouting? I'll be using a pretty neutral color grout, something light gray or ivory to blend with the tile.
#18 |
tile contractor
If you go to the article you cited, you could use it as a substitute where they use the word "bedding".
You're already holding one panel to the other by means of screws or nails. The thinset is to eliminate the paper thin void that would otherwise exist between the layers, causing a minute vinbration that would shorten the life of the floor. The very last thing you want to do is bond one layer to the other. Do that, and you've basically created a single layer, and eliminated all the benefits of a multi-layered floor, which is why TCNA goes against manufacturer's specs recommending the unmodified thinset. Over at John Bridge's site, someone put it very well-- screws hold the cement board down, while the thinset holds it up. ![]() BE-- it depends on how absorbant the stone is. Polished stone usually doesn't need to be presealed.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com Last edited by Bill_Vincent; 03-12-2008 at 11:42 PM. |
| Getting ready to launch a new concept - haters get ready, you'll love this one! | Mike Finley | Business | 97 | 11-03-2008 07:55 AM |
| Wait to paint ceiling texture: How long?? | steve-in-kville | Painting & Finish Work | 7 | 06-15-2007 08:39 PM |
| Customer Wait Time | NickofTime | General Discussion | 14 | 03-18-2007 02:34 AM |
| Paint Ready? | Smoothy | Painting & Finish Work | 13 | 01-14-2007 05:47 PM |
| hardibacker over linoleum | A.W.Davis | Flooring | 6 | 10-22-2006 03:19 AM |
