Trade: Remodeling contractor
Is This Guy Serious
If you remember my thread about the copper shower pan last month. The plumber
finally got around to taking out the copper pan so we could do it right. Told the HO,"all set". I got there today and this is what I found. ![]() I don't think this guy's a plumber at all. I think he's just making it up as he goes.
Complete Custom Remodeling "When Quality is Top Priority" www.completecustomremodeling.com |
Re: Is This Guy Serious
nice catch basin.
Tile Contractor
WTF are you supposed to do with that? I hope you didn't plan on using a KERDI Drain.
You could just cast a double thick shower floor and add a coupling to that mess you have there now maybe.
tile mason
What's wrong with a copper pan installation?
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
Matt, this is the pan I was asking advice about last month. I guess there isn't anything wrong with a copper pan per say. But the way the plumber installed it. ie; No preslope under the pan (in fact it was sloped away from the drain), Plus it was set directly on the cement floor without any protection barrier(Copper + bare Cement = Corrosion). Actually you, yourself, commented about the preslope being code. (unfortunately not here in MA).
At this point I think he's just F---ing with me.
#6 | |
Tile Contractor
Re: Is This Guy SeriousQuote:
Handle It!
You are a PROFESSIONAL. Handle it!
Carpenter/fencing
he made a nice piss hole
Learning without thought is labor lost; thought without learning is perilous. |
Trade: Kitchen & Bath
I think I'm tearing his plumbing out of my job too. He must be a plumbing slut, he sure gets around.
Moderator
I'm not sure what you want to see. What are you expecting?
If you're doing a particular type of drain, has that been relayed to him? Have shop drawings or specs been provided to him? I don't see a benchmark on the floor to tell him what portion of the floor to use to set drain height to. Is there a mark on the wall that we can't see? There seems to be enough PVC there to glue onto with a coupling and a short piece. If he doesn't know what height to set the drain, how can he set it, unless he leaves it long and cuts it down afterward and uses a drain that has a driven washer or a one clamped via castellated nut. Seems to be that communication has been less than stellar on this job.
Tile Contractor
DA,
I don't remember what type of floor drain CCR was going to use but if it is a KERDI Drain they have a built-on tailpiece that drops below grade. The coupling in the photo would probably interfere with the KERDI Drain and the floor would have to be built up higher than usual. Unless the entire Schluter Shower Kit was planned, in that case the piping is really screwed up. |
Moderator
Yup, I can see that he seems short of 4" below grade, but that was my question. What height was specified?
I see a pipe set below grade and a plumber getting beaten up for it. I'm asking why? What was said, when, and to whom that makes this wrong? If the plumber don't know what he don't know, then he don't know.
#13 | |
Carpenter/fencing
Who has the link with the proper way to install shower liners ? It was posted a while back, i think CCR needs it.
Learning without thought is labor lost; thought without learning is perilous. Last edited by nywoodwizard; 04-17-2008 at 09:40 PM. |
Hey DA, Bud, I told him we were going to use just a typical "2pc. drain". Ya know, he sets his drain - I do my pre slope and membrane and sandwich the membrane in the drain - then finish my shower floor. Any thoughts? This is the HO's Plumber. I did not hire him (he would have been gone already). This is why I say he's f***ing with me because he doesn't have to answer to me.
Tile Contractor
If you plan to use the "clamping drain", then what you have there should work. There is enough stub to add another 2" coupling, then a 2" stick of PVC, then your drain assembly. You'll just have to make up the difference when you cast your preslope and everything will be back in order. I think the plumber whacked and hacked to remove his copper and didn't do you any favors the way he did it but no real harm done.
Hey Thanks Bud, You're one of the few guys that I was hoping to hear from.
Thanks again.
#17 | |
![]() AND HERE WE ARE.
#18 |
Tile Contractor
Next time you need a plumber or have an opportunity to refer a plumber to someone be sure to remember him. Don't recommend him to anyone, just remember him.
| Enough Shenanigans for me...(Serious Business Question) | mahlere | Business | 41 | 10-11-2007 05:39 PM |
| Ok this is serious and not a joke. What should I do? | Grumpy | Off Topic (Non Trade) | 80 | 07-24-2006 01:51 AM |
| Getting Serious About Fishing Trip | realpurty2 | Off Topic (Non Trade) | 41 | 06-25-2006 09:44 PM |
| Could this cause serious problems? | ron schenker | Electrical | 9 | 02-18-2006 01:02 AM |
