Grouting Tile With Two Different Color Grouts
Old 07-30-2008, 10:39 PM   #1
KYRemodeler's Avatar
I'm currently tiling a bathroom that has dark tile on the floor and 5 feet up the walls, then a 4 inch wide band of glass tiles then a lighter tile on top of that all the way to the ceiling. However, the bottom and the top have two different color grouts. My plan of attack was to grout the bottom (darker color) let it set then come back and grout the top and just be careful to cover the bottom half. My main question is right where the grout lines meet, what should I do to get the cleanest line. Painters tape? Just looking for suggestions, Thanks
KYRemodeler is offline
Old 08-01-2008, 02:08 PM   #2
R&D Tile's Avatar
Trade: Tile installations
Rewards Points: 250
Re: Grouting Tile With Two Different Color Grouts
Sure, why not, then take it off while the grout is still wet and clean any that bled onto the one that was set already.
R&D Tile is offline
Old 08-01-2008, 04:54 PM   #3
Tile Contractor
Bud Cline's Avatar
Rewards Points: 518
It's important to allow plenty of time for the first grout application to dry thoroughly. It makes the second application a lot easier to clean off of the first. In fact sealing the first application would also be a good idea before applying the second grout.
Bud Cline is offline
Old 08-01-2008, 06:20 PM   #4
Steve
OCRS's Avatar
I had a shower/floor w/3 color grout and that's what I did. Make sure you staighten out the first color (I use a little flat screwdriver) and stick the tape into all the crevices before starting subsequent colors.
OCRS is offline
Old 08-01-2008, 10:51 PM   #5
Okay, I'll make sure everything is cleaned up and dried beforehand on the first color and try the painters tape. Thanks for the input. Just never had different grout colors together before and wanted to make sure I did this right.
Old 08-02-2008, 06:50 AM   #6
Steve
OCRS's Avatar
Post some pics when you're done, or at least tell us how it went.
OCRS is offline
Old 08-02-2008, 06:37 PM   #7
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
This was done using painters tape the next day for the second color. I know it's a smaller scale, but it just happens to the only time I've thought to get pictures of grout color changes:
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 08-02-2008, 11:03 PM   #8
That looks nice. I feel a lot more confident about my painters tape method now. I should have pictures by the end of the week. Thanks again.
Grouting tile that is pitted... bbravo Kitchens & Baths 11 03-19-2009 09:09 PM
Seal marble before grouting? constrkings Tiling 13 04-14-2008 09:02 PM
tile demo HomeSolutions Tiling 6 04-07-2008 07:26 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 07:01 PM
Ceramic Floor tile grouting John Walls Flooring 9 05-18-2007 06:42 AM
