Trade: siding windows soffit fascia
Grouting Large Tile
I have some 18"x18" tile with a medium/light rough surface (not smooth) to grout and would like to get some tips on if you tile guys grout these as normal or try to avoid covering the whole piece of the tile with grout in order to save clean up time.
Tips, Ideas, time savers, etc appreciated. Thanks, Dave C
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors |
Re: Grouting Large Tile
I had seen this at a show, i know nothing about personally, but it sured demoed nicely. beyond this contraption, grout as usual..
http://thegroutrocket.com/
#3 | |
Re: Grouting Large TileQuote:
Thanks, dave c
Tile & Marble Contractor
Trade: Tampa Tile Contractor
if it isn't a big area you just need to deal with the rough surface and go at it with a float & sponge.
I have a Tile-Eze and it makes Eze work of rough surfaced tile. http://www.tile-eze.com/0101.html
-Brian- Brandon Lutz Bradenton Tampa Oldsmar Westchase New Port Richey Seminole St. Pete Wesley Chapel Sarasota website: www.ceramictec.com |
Chief Toilet Mover
Trade: Bathroom Remodeling
Back when I laid tile, any time I did large format tile I always avoided covering the entire tile with grout, it just made more sense, wasted less grout and was faster in the long run.
(That grout rocket I would be warry of based on the process of using it eliminates the step of packing the joints) |
#6 | |
Trade: Commercial Loading Dock and Door Contractor
You could try a grout bag. I like it for sanded grout on large format tiles when installed on walls, I also used one recently for a slate job, for the same reason you are concerned about, to keep the grout off of as much tile as possible. It works nicely, but does take longer than just using a float.
I like Green things
Ughhhh, I just got done with a small kitchen slate job, I still hate doing it, but a grout bag is the way. The only part I like about it is the pay!!!
The slate I was working with was not gauged very well, and when I pulled out a pieces to add thin set to level the edges, the tiles would just blow apart from the suction, leaving a bunch of debris in the thin set.
I am now charging triple for slate, after this last one. I used to charge double my ceramic rate. I also needed to get 30% extra for waste. Warner (and anyone else), how much over your Ceramic rate are you charging for slate? Is slate starting to become popular? |
#10 | |
Chief Toilet Mover
One of our tile suppliers, their slate is a nightmare, the other tile supplier their slate is completely different. When a customer wants slate we don't let them pick it from the first supplier. |
#11 | |
Handle It!
Never seen one of those before!!!! But I have seen these........
Handle It!
It is like a VERY LARGE recirculating towel. Is it not?
My previous post was mean to be somewhat "funny". Apparently I failed!
#14 | |
I will take you advice on the next one, and find a more stable product....Thanks |
#15 | |
Chief Toilet Mover
Re: Grouting Large Tile |
Handle It!
Re: Grouting Large Tile Alright WiseGuy...It is Glove Off! Gonna punchya right in the kisser!!!!!
| Grouting tile that is pitted... | bbravo | Kitchens & Baths | 11 | 03-19-2009 10:09 PM |
| Areas hardest hit by Financial Crisis | Cdat | Off Topic (Non Trade) | 9 | 10-01-2008 11:43 PM |
| information on fixing a bad tile job | bford | General Discussion | 4 | 09-30-2008 07:44 AM |
| Grouting tile with two different color grouts | KYRemodeler | Ceramic & Stone Tile | 7 | 08-03-2008 12:03 AM |
| Ceramic Floor tile grouting | John Walls | Flooring | 9 | 05-18-2007 07:42 AM |
