Grout Problems - Tiling - Contractor Talk
Grout Problems
Old 09-04-2018, 07:23 PM   #1
WalkerTC's Avatar
Rewards Points: 36
Grout Problems
We did a bathroom remodel about 6 months ago for a really awesome client. I got a call about a week ago that she was having some problems with the grout in the shower. It seems like the grout hasnít fully cured, leaving a residue in the tile after showers and when I wipe a finger down the joint it wipes pretty easy. The grout was Tec power grout.
I didnít do the install, it was my tile sub who has never had this issues before.
WalkerTC is offline
Old 09-04-2018, 07:26 PM   #2
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 5,284
Re: Grout Problems
Soap scum?
Big Johnson is offline
Old 09-04-2018, 08:15 PM   #3
avenge's Avatar
Rewards Points: 3,218
Re: Grout Problems
Did you let it cure before use according to manufacturer directions? Try sealing it.
avenge is offline
Old 09-04-2018, 08:27 PM   #4
WalkerTC's Avatar
Rewards Points: 36
Re: Grout Problems
Yes it cured for almost a week, in a climatized house and the recommendation was 72hrs.
I am going to contact manufacturer and see what their recommendation is.
WalkerTC is offline
Old 09-04-2018, 08:45 PM   #5
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 132
Re: Grout Problems
Expired grout. Check date on bag.
goneelkn is offline
Old 09-06-2018, 07:38 PM   #6
Tom M's Avatar
Rewards Points: 8,414
Re: Grout Problems
No need to seal power grout. I like it,it's all I promote.
Keep us posted if indeed it is the grout. I have never had an issue personally
Tom M is online now
Old 09-06-2018, 09:36 PM   #7
avenge's Avatar
Re: Grout Problems
No it doesn't but would you rather dig it all out or attempt a sealer first?
avenge is offline
Old 09-06-2018, 10:00 PM   #8
Allspark's Avatar
Rewards Points: 28
Re: Grout Problems
That TEC power grout is some of the best ish around. And yes u do not need to seal it. Its the only thing I use for shower areas. Ur saying 6 months later the grout is not cured???
Allspark is offline
Old 09-07-2018, 11:14 PM   #9
Tom M's Avatar
Re: Grout Problems
I can't see the grout leeching, I'm inclined to think it's iron rich water or something like that.
Tom M is online now
Old 09-09-2018, 02:16 PM   #10
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 214
Re: Grout Problems
Power Grout is the worst grout on the market (IMO). It's an SOB to work, it has a lowsy workable time and clean up is a biatch. Not to mention they have had some serious color issues as of late.
Better off with Mapei FlexColor CQ. Easy to work with. Longer workable time. No color issues. And the pigment is in the quartz so your clean up is so much easier.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
The Following User Says Thank You to TNTSERVICES For This Useful Post:
BlueRidgeGreen (09-09-2018)
Old 09-09-2018, 02:17 PM   #11
Hair Splitter
Trade: General
Rewards Points: 214
Re: Grout Problems
How about some info on the grout used? Without that it's hard to say what the issue could be.
Old 09-09-2018, 05:08 PM   #12
avenge's Avatar
Re: Grout Problems
I wasn't going to mention it but I used Power Grout once and that was enough for me.
avenge is offline
Old 09-09-2018, 05:15 PM   #13
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,492
Re: Grout Problems
Based on TNT, I've actually never used PowerGrout either...that said, it is indeed somewhat popular around here.
That looks like something to do with soap scum or minerals in the water...I tell alllllll my customers that tile is NOT the end all of looking clean easily...it takes work. I have more happy customers with one piece nicely installed cultured marble or quartz walls than I do tile.
mstrat is offline
Old 09-09-2018, 08:17 PM   #14
WalkerTC's Avatar
Rewards Points: 36
Re: Grout Problems
Thank for all the feedback. I ended up calling the fuller the manufacturer of the grout explained my problems. According to them Tec power grout has a very high color content, if you mix you grout in small batchís you can potentially get more color in some batches than other. Causing it to not cure our correctly, and allowing the color to leach out, which is what appears to happen.
This is a problem they have seen before, the have an acrylic sealer they are sending to help bond the color in. I am going to try it in a small area and see if it helps.
WalkerTC is offline
Old 09-09-2018, 11:01 PM   #15
Hair Splitter
Trade: General
Rewards Points: 214
Re: Grout Problems
Another reason to ditch bag grout and go with a single component grout. No mixing. Which means consistent color and mix. No worrying about mixing dry contents, bad mix, blah blah blah.
WalkerTC (09-16-2018)
Old 09-10-2018, 10:18 AM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,858
Re: Grout Problems
How the heck do you get the film off the tiles with CQ? I went through a dozen fresh buckets and sponges, wiping in a single direction. Then I'd put a little too much water on and it would bleed creamy white goo all over the tiles, then I'd hit it too dry and rake out a joint. Ended up using a scotch brite pad after to get the film off after.
Inner10 is online now
B.D.R. (09-19-2018)
Old 09-10-2018, 02:21 PM   #17
Hair Splitter
Trade: General
Rewards Points: 214
Re: Grout Problems
I have a system. I've spelled it out in detail a few times.
1) wipe with sponge to remove most material
2) from second bucket sponge till clean (usually 2 passes)
3) from third bucket wipe with damp microfiber
4) wipe with a dry microfiber
If any haze presents itself once dry, clean with a window cleaner with ammonia.
The Following 3 Users Say Thank You to TNTSERVICES For This Useful Post:
B.D.R. (09-19-2018), Inner10 (09-10-2018), Rio (09-10-2018)
Grout discoloring aradon86 Tiling 2 05-24-2018 12:41 PM
Grout over grout VRNorthwest Flooring 13 01-27-2018 09:36 AM
Epoxy Grout CharlieDelta Tiling 6 04-11-2017 07:28 AM
Grout in Textured Tile Tips DemRem Tiling 28 07-16-2012 05:58 PM
Moisture Problems with Carrera Marble and Epoxy Grout Tallguy1 Tiling 4 10-13-2009 09:50 PM
