Grout For Marble Tile
Old 09-30-2008, 03:32 PM   #1
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
I am going to install some polished marble tile in a small bathroom floor.
I am wondering if I can use the same sanded grout I would normally use for ceramic. I have seen mention here of epoxy and "resin" type grout but the stuff I would prefer to use is colored, just add water powder, like Polyblend.
Am I OK to use this stuff?
bert0168 is offline
Old 09-30-2008, 03:38 PM   #2
Remodeling GC
kevjob's Avatar
Re: Grout For Marble Tile
marble should be set with 1/16th or under so use non sanded so you don't scratch surface
kevjob is offline
Old 09-30-2008, 06:46 PM   #3
Tile Setter
Tileworks's Avatar
Trade: Ceramic Tile, Marble, & Stone
Originally Posted by bert0168 View Post
I am going to install some polished marble tile in a small bathroom floor... I am wondering if I can use the same sanded grout I would normally use for ceramic.
No, those sand granules will scratch and take the shine right out of your marble. Marble, set properly, should be almost butting one another, but not quite. You can use a non-sanded grout of the same color, even from Polyblend.
- Bob
Classic Tileworks
http://www.classictileworks.com
Ohio Tile and Stone Installation Contractor in the Akron area serving Summit, Portage, Medina, Stark, & Cuyahoga counties in Northeast Ohio
Tileworks is offline
Old 09-30-2008, 06:59 PM   #4
R&D Tile's Avatar
Trade: Tile installations
What do you have for a subfloor?, if wood, I would first see if it will support stone.
R&D Tile is offline
Old 09-30-2008, 08:14 PM   #5
Money Changer
bert0168's Avatar
Thanks about the sanded grout, I probably would have not thought of that. I was going to go 3/16 on the joints but now will go 1/16.
I have 3/4 subfloor with 1/2 Durock cement board so I think I am OK there
One more, I assume that since the marble is so soft, I will be wet sawing all of it.
Is it possible to score and break it?
bert0168 is offline
Old 09-30-2008, 08:21 PM   #6
Tile Setter
Tileworks's Avatar
No, you cannot score and break natural stone, only ceramic and porcelain.
Technically, according to the Marble Institute of America, you need to double that plywood. You also want to make sure that your joists are appropriately spaced and spanned. The deflection standards for stone are double that of ceramic.
I've seen marble installed short of the requirements and live, but I have a moral obligation to inform you of the facts :-)
- Bob
Classic Tileworks
Old 09-30-2008, 08:25 PM   #7
R&D Tile's Avatar
Agreed, so far that floor isn't up to spec for stone and I doubt the joists system is either, but we'll wait till you get back with the joist size, spacing and length of unsupported span.
R&D Tile is offline
Old 09-30-2008, 08:52 PM   #8
Remodeling GC
kevjob's Avatar
try here for deflection: http://www.johnbridge.com/vbulletin/deflecto.pl Have you set marble before? use medium bed.
kevjob is offline
Old 09-30-2008, 09:03 PM   #9
Money Changer
bert0168's Avatar
Thanks for the link. I get a deflection of L/818, over what is needed for marble. It's a small bathroom floor, 5' x 8' with a 12 x 12 tile.
2 x 8
16" o.c.
8' span
No I have not set any marble before, plenty of ceramic. Any more advice before I get to it?
bert0168 is offline
Old 09-30-2008, 10:39 PM   #10
Remodeling GC
kevjob's Avatar
do some searching here http://www.johnbridge.com/vbulletin/index.php?
kevjob is offline
Old 10-01-2008, 11:25 AM   #11
R&D Tile's Avatar
2 x 8
16" o.c.
8' span
Is that the size of the room or the unsupported span of the joists, those joists only run 8' till a support?, if so, you still need two layers of wood.
You want to space them 1/32 to 1/16", the floor needs to be FLAT and you don't ANY lippage.
R&D Tile is offline
Old 10-01-2008, 08:02 PM   #12
Money Changer
bert0168's Avatar
No, the span in the room is only 5'. 2nd floor over a beam on one end and near an exterior wall on the other.
I have 1 layer of 3/4" with a layer of 1/2" backer which with taped and mortared seams and nailed and glued to the subfloor. (I use ring shank drywall nails because I hate the rock on screws and can never get them sunk flush)
I know 8' sounds short but it's in a townhouse. Don't ask me why they built it that way.
bert0168 is offline
Old 10-01-2008, 08:13 PM   #13
orson's Avatar
Trade: Kitchen & Bath
1/2" backer doesn't really gain you anything but height on the floor for future reference. It isbasicaly meant for walls where you are spanning studs.
orson is offline
Old 10-01-2008, 10:45 PM   #14
Remodeling GC
kevjob's Avatar
when you say glue, do you mean thinset under cbu?
kevjob is offline
Old 10-02-2008, 07:48 AM   #15
Money Changer
bert0168's Avatar
Originally Posted by orson View Post
1/2" backer doesn't really gain you anything but height on the floor for future reference. It is basically meant for walls where you are spanning studs.
I wasn't aware of that as I have been using it on floors for a couple of years and no problems.
So other than a mud set, what are options for floor tile. I am not convinced thinset on wood is good as I have removed some tile floors set on plywood where the thinset never stuck
bert0168 is offline
Old 10-02-2008, 04:49 PM   #16
R&D Tile's Avatar
Nothing wrong with CBU on a floor, think he meant you can use 1/4" instead of the 1/2".
CBUs get set in a bed of thinset and screwed down.
You also need two layers of wood before the CBU or a membrane if installing stone.
R&D Tile is offline
Old 10-02-2008, 09:11 PM   #17
tile mason
MattCoops's Avatar
I'd stick with thinset under the backerboard. It's not meant to be an adhesive, but fill voids.
The screws are your means of "mechanical" fastening. And I'd definitely use screws instead of nails.
I don't think nails and glue meet manufacturers' specifications for installation of any kind of CBU anyway.
MattCoops is offline
Old 10-02-2008, 09:43 PM   #18
orson's Avatar
Yikes!! I didn't mean to insinuate you shouldn't use cbu on the floor, just as R&D was saying, use 1/4" instead of 1/2". Sorry for the poor wording.
I actually prefer Ditra over cbu for most floors, especially if you're only minimally meeting the framing and sheathing requirements.
orson is offline
Old 10-31-2008, 12:57 PM   #19
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
I've seen many stone tile jobs done without two layers of ply. Hardie also claims that 3/4" OSB is sufficient under the 1/4" backer for stone applications. Is that not the case?
Cache is offline
Old 10-31-2008, 10:11 PM   #20
Knowledge Factory
Floordude's Avatar
Hardie want to sell more product. They will tell you what you want to hear, so you buy their crap.
The wood subfloor needs to be a minimum of 1-1/8" thick, before any CBU or uncoupling membrane. No if's and's or but's!
http://www.AustinFloorguy.com
Floordude is offline
information on fixing a bad tile job bford General Discussion 4 09-30-2008 07:44 AM
Tile, grout and winter. ruskent Flooring 2 01-15-2008 09:31 PM
Tile grout color too light fsbr Flooring 18 11-29-2007 06:05 AM
Porcelain Floor Tile - fixing sanded grout cracks ETHICS05 Flooring 11 07-18-2007 07:43 AM
Bad tile job AAPaint General Discussion 9 07-26-2006 04:56 PM
