Grout Color Change
Old 12-31-2008, 08:21 AM   #1
CJKarl's Avatar
Trade: Masonry
Grout Color Change
I'm a mason that did a large slate floor. 3/4" green VT slate. The grout color called for was "gray" which, on the color chart had slight brown tint to it.
Everyone loved it and upon mixing and installing it looked fine. Now a couple days out it has lightened to a truer, lighter "gray". I'm thinking of using some kind of grout stain to darken it, but still tossing ideas around. Any opinions?
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 12-31-2008, 11:25 AM   #2
Its all ball bearings
angus242's Avatar
Trade: Tile
Re: Grout Color Change
I've always found a similar situation. When a customer gets excited about a dark grout color, it never seems to dry as dark as they thought it would.
I think grout colorant would work just fine. Aqua Mix makes some. I've had to use it before and I was please with the results:
http://www.aquamix.com/products/pg_d...5042&pgid=8374
angus242 is offline
Old 12-31-2008, 11:49 AM   #3
CJKarl's Avatar
Trade: Masonry
Thanks, Ill look into it.
CJKarl is offline
Old 12-31-2008, 12:05 PM   #4
Dan_Watson's Avatar
Aqua Mix works great for going darker over sanded grout. Ive used it a couple times and it was amazing. When I have tried to use the white over epoxy it always ends with a disaster. It didnt matter how well i cleaned it it needed atleast 2 coats. The last one I did I spent 16 hrs with straight razors cleaning it off the tile. Lesson learned, only on sanded grout for me...
Dan_Watson is offline
Old 12-31-2008, 03:32 PM   #5
CJKarl's Avatar
Trade: Masonry
I have some slate and grout left over. I'll make a mock-up and do some experimenting.
CJKarl is offline
Old 01-01-2009, 06:06 AM   #6
Jerry T's Avatar
Trade: Self employed - hard surface installer
I can offer a solution for your dilemma if nothing has been sealed yet. If you wet the grout does it revert to the color the people would be happy with?
Jerry T is offline
Old 01-01-2009, 10:41 AM   #7
olzo55's Avatar
Trade: flooring
try an enhancer if it wasn't sealed already.
olzo55 is offline
Old 01-01-2009, 12:43 PM   #8
CJKarl's Avatar
Trade: Masonry
No sealer
CJKarl is offline
Old 01-02-2009, 04:12 AM   #9
Jerry T's Avatar
That's right, an enhancer should do the trick here. You can't keep it off the slate so do a test first.
Jerry T is offline
Old 01-02-2009, 08:19 AM   #10
CJKarl's Avatar
Trade: Masonry
Doing a mock up today. I'll try some kind of stain/enhancer Monday.
CJKarl is offline
Grout for marble tile bert0168 Ceramic & Stone Tile 20 11-04-2008 01:01 PM
Tile & Grout work Paddy General Discussion 2 10-14-2008 09:17 AM
Grout Width and sealing. jritkes Flooring 6 09-28-2008 08:23 PM
Stone dust for grout MinConst Kitchens & Baths 6 08-17-2008 05:17 PM
Tile grout color too light fsbr Flooring 18 11-29-2007 06:05 AM
