Glass Tile Installation ?
Old 03-28-2008, 03:00 PM   #1
ruskent's Avatar
Trade: Outdoor D/B
I need to intall glass tile on the outside of a elevated spa. Is there a different type of thinset I am suppose to use because its glass tile?
ruskent is offline
Old 03-28-2008, 04:06 PM   #2
Angus
Angus's Avatar
Trade: Owner: Flooring Store
Re: Glass Tile Installation ?
Check your TCA hand book, first. This should also help.
http://www.tilemagonline.com/CDA/Art...100000f932a8c0____
Angus is offline
Old 03-28-2008, 04:08 PM   #3
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Hello Rusk...
Which glass tile are you installing? Oceanside? Bisazza? Trend? Walker-Zanger? Are they mesh backed or paper faced?
Is this a wet location or purely decorative?
For showers & wet locations I use a modified thinset like Lat. 253... For purely decorative walls over drywall, etc., I like to use a premium mastic.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 03-28-2008, 05:15 PM   #4
Tile Contractor
Bud Cline's Avatar
Better to follow the recommendations of the glass tile maker. They will tell you which products are suitable for use with their glass.
Bud Cline is offline
Old 03-29-2008, 07:53 AM   #5
R&D Tile's Avatar
Trade: Tile installations
No Mastic behind glass.
R&D Tile is offline
Old 03-29-2008, 01:18 PM   #6
tile mason
MattCoops's Avatar
You must use white thinset, especially if glass is transparent.
You shouldn't use mastic as it may discolor the tiles over time and of course the poor bond strength.
Make sure you give a finger push on each tile to squeeze out any shadow marks from troweled thinset.
Don't tell nobody, (you hardcore per instructions guys will love this)but I've acutally used non sanded white grout to install tile before. And I let the grout ooze up through the grout lines and then cleaned and Done.
MattCoops is offline
Old 03-30-2008, 12:09 AM   #7
ak_aiken's Avatar
Trade: Flooring contractor
Yes you do have to use a special thinset. The last couple of glass jobs that I did I used Ardex thinset I think it was called X 9, something, I can't remember the exact name. It was a premium white thinset that I had to pay quite a bit more than a regular polymer modified thinset but it worked very well and vertically there was almost no sag. in short it was worth the extra money.
ak_aiken is offline
Old 03-30-2008, 12:51 AM   #8
Teetorbilt's Avatar
OK, I'm old. We called it back-buttering. Applying the thinset to the tile prior to installation. Most of the installation has been covered well even if I don't agree with some of the info.
If this is your first time, spend the money and do a test in your garage/shop/basement. I don't know what you're doing but I did a job that was $64 a sq. ft. and you REALLY don't want to demo and start over.
Albert Einstein
Teetorbilt is offline
Old 03-30-2008, 01:09 AM   #9
Brock's Avatar
Trade: Residential Remodeler
Beautifull. Love it. Can't wait for my next glass job. From pain in the a$$ to easy money. All neatly presented in one gorgeous post. Life is grand. Kudos to the MattCoops.
Brock is offline
Old 03-30-2008, 01:19 PM   #10
Tile Contractor
Bud Cline's Avatar
Brock.....don't do nothin' stupid. If tile grout was intended to be used as a tile adhesive everyone would be doing it. There is no genius in that technique, only ignorance.
Old 03-30-2008, 03:53 PM   #11
Brock's Avatar
I'm so confussed. Who am I, What am I, Where am I.
Brock is offline
Old 03-30-2008, 08:00 PM   #12
Builder/Remodeler
ChrWright's Avatar
Yes, mastic can be used to install glass tile (mosaics), with the following exceptions:
NOT in wet locations
NOT with clear glass (it will yellow as mentioned)
For backsplashes and decorative walls, however, it is the least PIA method of installation.
I have installed 10s of thousands of square feet of glass mosaics. Because of the material cost and skill level required, they are one of the more expensive materials you can charge for.
Oceanside:
Bisazza:
Trend:
Old 03-30-2008, 08:05 PM   #13
Builder/Remodeler
ChrWright's Avatar
More Oceanside:
More Trend:
More Bisazza:
Walker-Zanger:
Old 03-30-2008, 08:21 PM   #14
Thom
thom's Avatar
Am I the only guy who doesn't like the look of glass tile? They seem trendy and crappy to me. I like the look of ceramic, natural stone, and porcelain better than glass.
thom is offline
Old 03-30-2008, 08:21 PM   #15
R&D Tile's Avatar
Brock, grout alone should never be used as a thinset, UNLESS you use Laticretes 1500 series grout and their 4237 Additive, then you have a grout thinset the same color as the grout so oozing isn't an issue, THEN you still have to grout it with the same grout NOW mixed with their 1776 enhancer that helps hold the color, best system for glass, I think.
And if using just white thinset, use laticretes 254.
Matt, pushing each tile by hand to get the trowel marks out????, you could be there awhile.
Use a 1/8 or 1/16" trowel, spread the thinset, then flat trowel it smooth, set the glass sheets and push them flat and even with a grout float, then if paper faced sheets, wait till it holds enough so the sheets of paper can be misted and peeled off without taking the tiles with it, now you can adjust any that might not be square to the others, with mesh backed, just cut between them with a razor knife and adjust what needs to be done.
R&D Tile is offline
Old 03-30-2008, 09:26 PM   #16
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Beautiful work there Chris!
Mike Finley is offline
Old 03-31-2008, 05:33 PM   #17
Builder/Remodeler
ChrWright's Avatar
Thanks Mike.
Old 03-31-2008, 07:39 PM   #18
Brock's Avatar
Thanks. Started a file with good tips as I run across them. This one is going in it.
Chris does some of the cleanest work I have seen. Scores a 15 on a 1-10 scale for quality of craftmanship.
Brock is offline
Old 04-05-2008, 09:32 AM   #19
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
I agree. Chris, that's some incredible work.
That said, Thom, you're not alone.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 04-21-2008, 06:04 PM   #20
Low Voltage Contractor
ChillaWatt's Avatar
Trade: C-7
What an excellent thread. I haven't done much tile work myself, surely no expert on it, but I thoroughly enjoy watching a bunch of pros battle it out with their tricks of the trade being thrown at each other.
Chilla
ChillaWatt is offline
Backer material for curved ceiling & glass tile Syborg_97 Ceramic & Stone Tile 12 12-22-2008 04:06 PM
Cement tile installation question zvwriter General Discussion 2 01-18-2008 03:58 PM
1x1 glass tile ??'s vaultf600 Ceramic & Stone Tile 7 05-12-2007 09:22 AM
Glass tile Teetorbilt Remodeling 12 01-20-2006 11:38 PM
new kind of tile installation? perth Flooring 6 01-02-2006 02:34 PM
