Charles
Glass Tile 12X35" Cutting And Drilling
Hi guys, I have a bathroom to do with big glass tile on walls.
I have Felker GB-10 Glass Cutting Blade that should help with smoother cut. If there is better blade please let me know. I will have to drill 3/4" hole for toilet water supply line. I have nothing for that. I hope you can give me some suggestions what to buy. I would rather spend a little more for better product that works and lasts. I assume that only way is to go with diamond hole saw. I bet they are not all equal and not sure if glass is in same category as porcelain tile and stones. Thanks for you input.. Last edited by Charles_cz; 11-11-2009 at 05:25 PM. |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Glass Tile 12X35" Cutting And Drilling
Isn't there going to be an eschution plate? If so you can simply cut a square hole using the wet saw blade. Cut the 4 lines of the square hole as much as you can then do a X connecting the corners and you should be able to remove the glass and have your square 3/4 hole, the pipe goes through and the eschution will cover it just fine.
Its all ball bearings
Trade: Tile
I likey me some Raimondi blades:
http://www.raimondiusa.com/db_glass_2008.html Never used the Felker blade. For the water line, get a DIAMOND tip hole saw (I use Dewalt) and a Felker Water Ring!
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
| The Following User Says Thank You to angus242 For This Useful Post: | WarnerConstInc. (11-11-2009) |
bathroom guru
Angus, are those hole saws shown by dewalt?? If so, why don't we get that stuff up here - never seen them from Dewalt before
#5 | |
Trade: Tile
Re: Glass Tile 12X35" Cutting And DrillingQuote:
Can you order from here? http://www.contractorsdirect.com/Til...4Pa38Ta3aLchn0
#6 | |
Charles
Hi Mike, yes there will be eschution plate. That is what I do with tile where I have plenty of tile left. I use grinder to do that. I'm not sure if glass tile is as strong as porcelain tile and I thought that diamond hole saw would be safer way to cut the hole. It's big tile and customer will have may be two extra pieces. ( I told them to get more but they are willing to take the risk). I just do not have that much experince with glass tile.
Charles
Hi Angus, I already have Felker blade that I have used on one of my previous jobs for glass mosaic tile. I could not really tell how good or bad the blade was but I thing I will find out on this job.
I like setup with Dewalt diamond hole saw and water ring. It should do the trick and as they claim it should be good for glass too. I have noticed that hole saw doesn’t have anything to keep saw in place at the beginning of drilling. Do you use any type of guide or do you just start drilling with slight angle with edge of the hole saw and straighten up the drill once you can keep the saw from running all over the place? I assume that water ring is just to hold water and there is no way to use it as guide for the saw. Thanks Charles |
#8 | |
Chief Toilet Mover
The key is the X. It takes 6 cuts of the saw, not 4. |
| The Following User Says Thank You to Mike Finley For This Useful Post: | Charles_cz (11-12-2009) |
#9 | |
Trade: Tile
| The Following User Says Thank You to angus242 For This Useful Post: | Charles_cz (11-12-2009) |
Fisherman
Trade: Kitchen and Bath remodels
Does the glass tile have a "painted" back? You will need to completely back butter each piece to hide any trowel marks. Be careful with the painted backing when your drilling and cutting. Post up some pics when your done.
Trade: Tile
Good point Frank. Paint-backed glass tile are a little finicky when using a wet saw. The paint can chip thus making a small portion of the tile clear. You cannot use white thinset to make up for missing white paint on the tile. Worse yet if the paint is a different color than white.
It that case, a good tile cutter may be a better option.
#12 | |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
| The Following User Says Thank You to PrecisionFloors For This Useful Post: | Mike Finley (11-12-2009) |
Charles
I did not see the tile just yet but it will be white. I guess I will have to cut very carefully.
It is tile by Porcelanosa. I do not know if anyone has used it before. May be you can share experience with it. If there is chipped paint what do you fix with? Paint? I would think that it migh change color over the time… |
#14 | |
Chief Toilet Mover
Along with finding that out you can discuss with them this last issue. Believe me, no matter what you do, do not avoid contacting the manufacturer of this glass tile prior to installing it. I can't stress how important that is. |
Charles
I agree and thanks for the remainder. This tile is imported from Spain I believe. I hope they have sales rep. here that is knowledgeable enough to answer my questions.
Chief Toilet Mover
Careful, thats where we contractors get screwed. Not saying this is the case with what you are experiencing, but when a customer tries to save money or source product and comes up with some crazy product with no support, we end up try to do our best and wing it and if anything goes wrong we are the bad guys in the end most of the time. If you can't get any company support on that product I would seriously have a sit down with the customer and get things squared away with them to understand the issues they are facing now and that you as an installer will not be held liable for a product you can't get support on. Good luck with it all.
Charles
Hi Mike, I think I should be fine as far as quality and support for the product goes. It is high end tile and one of the selling points of the company is quality of the product. Porcelanosa is known for their large format tiles, both porcelain and conventional ceramic. They make some beautiful rectified tile that will look nice if installed correctly. I am looking forward to this job.
I will contact Porcelanosa with questions about installation as I have never worked with their tile. We will see if they are ready to help contractors.
| Cutting pots and Roller trays | steve-in-kville | Painting & Finish Work | 27 | 10-02-2006 06:09 PM |
