Glass, Glass, Glass!!!
Old 03-17-2008, 07:42 PM   #1
Jay22's Avatar
Trade: Tilesetter
Hey guys,
I was asked to do a job that involved glass tiles. Was wondering if my Sigma tile cutter could cut glass tiles?
If not, What do I do??
Jay22 is offline
Old 03-17-2008, 08:00 PM   #2
Its all ball bearings
angus242's Avatar
Trade: Tile
Re: Glass, Glass, Glass!!!
How thick is the tile? A glass scoring tool can be used if it's thin enough, say > 4mm. If it's thicker or textured, a wet saw with a diamond blade will work.
angus242 is offline
Old 03-17-2008, 09:20 PM   #3
orson's Avatar
Trade: Kitchen & Bath
Just don't try a dry blade on a grinder or saw, glass will melt.
orson is offline
Old 03-17-2008, 10:29 PM   #4
Remodeling GC
kevjob's Avatar
good tile saw with little vibration and a good glass tile blade MK makes them and you may have to flip them and cut really slow and use megaflex white mortar and use redgard if it is over drywall glass tile expands more than ceramic and leave expansion joints.
kevjob is offline
Old 03-18-2008, 04:00 PM   #5
Tile Contractor
Bud Cline's Avatar
At what temperature does glass tile melt under these circumstances?
In all my years I can honestly say I have never melted glass using a dry grinder or a dry diamond blade. I have increased its temperature too rapidly when causing friction on the glass and the glass has fractured as a result, but never melted.
Bud Cline is offline
Old 03-18-2008, 08:25 PM   #6
orson's Avatar
Not sure Bud, I was too busy gaping at it to stick a thermometer in it.
Schwind, Arlene Palmer M.A. "Glass" Microsoft® Encarta® Online Encyclopedia. 2002: May 29, 2002"Depending on it's composition, some glass will melt at temperatures as low as 500 °C (900 °F), others melt at 1650 °C (3180 °F)"1650 °C
orson is offline
Old 03-18-2008, 08:35 PM   #7
Teetorbilt's Avatar
Gauge the job to the tile size. You're opening yourself into a world of hurt, I did it ONCE. When you open the block, all bets are off. Best to go to the manuf. with dimensions and have it made.
Albert Einstein
Teetorbilt is offline
glass coated steel haskl33 Excavation & Site Work 3 10-23-2007 11:33 AM
Shower Glass atipton Remodeling 3 10-17-2007 08:50 PM
Glass Block Transition Paul_NJ Ceramic & Stone Tile 0 03-15-2007 08:14 AM
Broken Sliding glass door sprinklerguy Windows, Siding and Doors 10 01-04-2006 04:58 PM
I can cut glass! Teetorbilt General Discussion 9 11-24-2005 05:42 AM
