Exterior Slate Tile Balconies - Need Some Advise
Old 12-12-2008, 03:07 PM   #1
NAV's Avatar
Trade: commercial building restoration
history of the property
I have a customer that has spent a lot of money with our company and has a lot more money to spend. Its a high end condominium association. In the center is what they call the Mansion, its an old mansion (early 1900's) that was converted into a hospital and then into condo units. what you see in the pictures was added on in the 1980's.
The Problem
There are a bunch of slate tile balconies that are all leaking into the condo units below. The condo owners in the building are all millionaires and a little difficult for the manager to deal with. I did some work on one floor where i pulled up 1/2 the tile and re-set it with exterior thinset. the existing thinset is deteriorating - it is pretty much just sand at this point and all of the tiles sound hollow if you tap on them. the existing waterproofing membrane is black with what appears to be a fibermesh material. Concrete under that.
I am bidding on removing the tile and membrane and installing a new system. The problem is that i dont know what system to use. i will have to run the waterproofing membrane at least 18" up the wall under the cedar siding because they can not shovel the snow off their balconies. the property is on Lake Erie in the Cleveland area so the weather is brutal.
I am thinking using a Schluter Systems or Dal-Seal TS.
Any advice would be helpful and if you are in Cleveland i will take Sub Bids.
Exterior Slate Tile Balconies - Need some advise-condo-6-20-018.jpg   Exterior Slate Tile Balconies - Need some advise-balcony-1-004.jpg   Exterior Slate Tile Balconies - Need some advise-condo-004.jpg
NAV is offline
Old 12-12-2008, 06:10 PM   #2
Tile Contractor
Bud Cline's Avatar
Re: Exterior Slate Tile Balconies - Need Some Advise
Schluter Systems makes a product for exterior balconies and decks. It is a complete waterproofing and drainage system.
Bud Cline is offline
Old 12-12-2008, 07:07 PM   #3
genecarp's Avatar
Also check out {sealoflex}.
genecarp is offline
Old 12-13-2008, 02:07 AM   #4
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
While Schluter does provide balcony specifications in their literature, they advise that balconies should be spec'd on a case by case basis.
Contact your local Schluter rep, and he will usually consult with you on the project, and even show up on the jobsite to get you rolling.
HS345 is offline
Old 12-15-2008, 08:12 AM   #5
NAV's Avatar
The sealoflex seems like it will take too long to apply, so many coats and layers.
I think i will specify the Schluter-Ditra membrane. It looks simple and the install time shouldn't be bad.
Let me know if you guys think of any better products. I don't think I am going to get a Rep involved.
NAV is offline
Old 01-06-2009, 06:36 PM   #6
bathroom guru
jarvis design's Avatar
I did my first exterior installation this last summer - used ditra in conjunction with an edge profile. So far so good!!
I still think I would bring a rep in, they can answer a lot of questions and may be able to avoid any future problems.
jarvis design is offline
Time for a new tile guy? orson Ceramic & Stone Tile 20 12-11-2008 08:38 PM
tile backer in a bath room and kitchen mikeybobo Drywall 10 12-05-2008 04:31 PM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 07:44 AM
need input on tile job bford Introductions 1 09-24-2008 11:28 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
