#41 |
Trade: Natural Stone
Re: Exterior Slate Cladding
CJKarl,
I hate to play devils advocate here, and I am in no way deriding Laticrete products (we use them in a number of applications), However I would argue that using an adhesive method of application alone on this project would create some concerns. The MIA (Marble Institute of America) cautions that "individually set thin tile (nominal 1/4" thick) on vertical surfaces exceeding 8' is not recomended." Since your application is 1/2" slate and you are considering an adhesive system you may be able to avoid issues regarding the fragility of thin tile instalations, but depending on the slate you are using you open yourself to another set of issues including water intrusion. Even with a waterproffing barrier on the hydrostatic load side of the concrete wall you still have to consider water intrusion on the cladding side of the installation. All but the most dense slate is significantly more porous than other common choices for dimensional stone cladding. Laticrete's own technical design manual cautions that: • spot bonding is only suitable when resist the high unit area stressusing adhesives with very high bonding strength and flexibility such as new technology epoxies and structural silicone, and may require supplemental mechanical anchorage. • spot bonding should not be used in wet climates with cladding materials that have high water absorption or water sensitivity (Figure 7.3-2). • spot bonding is not suitable for thin cladding materials that do not have the cohesive (tensile) or shear strength to attachment. extreme climates or conditions.• back-up wall construction must make provision for waterproofing and flashing the cavity between the substrate and the cladding surface. • spot bonding may not be suitable for If Laticrete is waranting their system and you and the engineer/architect are comfortable with the installation specification than obviously I will defer to your/their expertise. However all the professionals I have talked with at our company would quote this job using a minimum 3/4" dimensional slate with a mechanical anchoring system due to the height of the project, possibility of water intrusion and freeze-thaw environment. No matter what system you choose I haven't seen any reference in the posts to weepage and control/expansion joints. Make sure that you have provided for venting or weep holes at approximately 5' horizontal and 20' vertical intervals and expansion/control joints at maximum 20' intervals. Good luck and I'll be looking forward to hearing how the project goes.
John Hughes Business Development Manager Great Lakes Granite & Marble john@greatlakesgm.com http://www.greatlakesgm.com |
#42 |
Trade: carpentry and paintingvo5
karl contact TEC and ask to be put in contact with henry the north east sales rep. he lives in CT and will set you up with the right products. i wouldn't use any type of sheet membrane. there are all kinds of liquid roll on products to give you waterproofing and crack isolations. ditra is not for vertical use.
#43 |
Its all ball bearings
Trade: Tile
Project is already under way. Products have already been chosen.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
| Residential Limestone Cladding | Vermaraj | Masonry | 17 | 09-28-2010 03:34 AM |
| How to use a Brake? | sage | Windows, Siding and Doors | 43 | 10-24-2009 09:25 AM |
| Touching up aluminum cladding? | barkocyt | General Discussion | 1 | 03-23-2009 08:55 PM |
| cladding exposed basement walls on exterior | dakzaag | Masonry | 20 | 02-22-2009 10:23 PM |
| Windows: Rotten Sill | bdubbs | Windows, Siding and Doors | 38 | 01-08-2009 10:21 PM |
