Epoxy On Tile
Old 04-16-2007, 11:01 PM   #1
go do it's Avatar
Trade: general contracting
Epoxy On Tile
HEY ALL
WHAT IS THE BEST WAY TO GET EPOXY OFF OF FLOOR TILE?
MY WOOD FLOOR INSTALER CAME BACK TO FILL A COUPLE OF LOW SPOTS / HOLLOW AREAS WITH EPOXY THAT HE DIDN'T NOTICE ON INSTALATION, YEA RIGHT.
ANYWAY HE DRILLED A SMALL HOLE IN THE FLOORING AND FILLED THE VOID WITH EPOXY BUT HE DRIPED SOME ON A TILE FLOOR IN A WATER CLOSET NEARBY.
SO HOW CAN I GET THIS STUFF OFF!! SHORT OF USING C4
NO USE CALLING HIM HE IS FIRED
THANKS
go do it is offline
Old 04-16-2007, 11:44 PM   #2
bill r's Avatar
Trade: residential (marine) piers
Re: Epoxy On Tile
ceramic? plastic?
bill r is offline
Old 04-17-2007, 12:16 AM   #3
K_Tile's Avatar
Trade: Tile/Stone/Remodeling
Re: Epoxy On Tile
If the tile is ceramic try Aqua Mix "NanoScrub"
K_Tile is offline
Old 04-17-2007, 12:19 AM   #4
bill r's Avatar
Re: Epoxy On Tile
if plastic, forget it
bill r is offline
Old 04-17-2007, 07:53 AM   #5
R&D Tile's Avatar
Trade: Tile installations
Re: Epoxy On Tile
Heat gun and a good stiff plastic scraper, epoxy hates heat.
Only if this is ceramic though.
R&D Tile is offline
Old 04-18-2007, 07:53 PM   #6
go do it's Avatar
Re: Epoxy On Tile
thanks for the replies
i will try the heat gun first, good idea
i wanted to buy one anyway
thanks again
go do it is offline
Old 04-19-2007, 07:24 AM   #7
celtic
Taranis's Avatar
Trade: Flooring
Re: Epoxy On Tile
One way you you could remove the epoxy is to let water sit on it for a while (might take an hour, might take a day. Then you get a sharp scraper to get at the edges. It may come up as one or piece by piece but it should work.
Taranis is offline
Old 04-19-2007, 09:41 AM   #8
Teetorbilt's Avatar
Re: Epoxy On Tile
Water should not have any effect on epoxy, heat will.
Albert Einstein
Teetorbilt is offline
Old 04-20-2007, 03:31 AM   #9
celtic
Taranis's Avatar
Trade: Flooring
Re: Epoxy On Tile
water getting under epoxy will do the trick, along with gently scraping at the edges. It will get to the edges. If you use too much heat, it may take of the surface off the tile if it has bonded. I have used this method successfully. To remove spilled epoxy it is better if it is brittle.
I don't mean for the water to sit on top of the epoxy.
Taranis is offline
Old 04-28-2007, 08:34 PM   #10
R&D Tile's Avatar
Re: Epoxy On Tile
Good luck with that, epoxy is waterproof.
R&D Tile is offline
Old 04-28-2007, 09:32 PM   #11
send_it_all's Avatar
Re: Epoxy On Tile
If you could think of a way to spot freeze it, then shatter the brittle epoxy. Freon?...Co2?....I dunno...just a thought. Heat might make it gummy.
send_it_all is offline
Old 04-30-2007, 03:54 AM   #12
celtic
Taranis's Avatar
Trade: Flooring
Re: Epoxy On Tile
the water isn't meant to break down the epoxy but will break the bond with the tile. It will also help reduce the friction when using a scraper to remove the spill.
Freezing the epoxy might also do the trick. Good shout.
Taranis is offline
Old 05-01-2007, 08:16 PM   #13
R&D Tile's Avatar
Re: Epoxy On Tile
Don't know what epoxy this is, but epoxy grout is used all the time, water has NO effect on it, the tile will break before the bond from the epoxy will.
R&D Tile is offline
Old 05-02-2007, 03:46 AM   #14
celtic
Taranis's Avatar
Trade: Flooring
Re: Epoxy On Tile
from the first post, it isn't epoxy grout but a (probably) self levelling epoxy. Scraping won't break the tile. Believe me, I've done it myself over the years (22) in resin flooring.
Unless all those years have been a waste of time.
Taranis is offline
Old 05-16-2007, 09:10 PM   #15
DT Tilemaster's Avatar
Trade: Tile
Re: Epoxy On Tile
You can try an epoxy remover called Jasco. You can find it in the paint aisle at Home D. Good Luck!
DT Tilemaster is offline
epoxy grout removal reveivl Flooring 15 09-15-2009 06:57 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
SpectraLock Epoxy grout(quarry tile floor) rservices Flooring 0 03-19-2007 01:00 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
