Epoxy Grout Or Urethane?
Old 07-14-2011, 09:29 PM   #1
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
I'm trying to sell urethane grout to an architect that has spect out epoxy.......what can I say to him that will make him change or open up to the idea......for u urethane grouters out there! Thanks
Groutface is offline
Old 07-14-2011, 09:33 PM   #2
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,282
Re: Epoxy Grout Or Urethane?
Although, this is true... I tell people that I'm allergic to it
Good enough reason for me... if someone really wants epoxy then I have to sub out the grouting portion to a tile friend of mine from Palmyra, Pa
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 07-14-2011, 09:47 PM   #3
Groutface
Groutface's Avatar
Rewards Points: 524
Might just use that!...hahah
Old 07-14-2011, 09:47 PM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
What's the application and why the push for urethane?
Angus
angus242 is offline
Old 07-14-2011, 09:56 PM   #5
Groutface
Groutface's Avatar
Rewards Points: 524
I've used epoxy and although the results are great...I flat out just don't like using it. Its a good size job 1900 or so sq ft. 12x24 porcelin over ditra,over heated concrete, in a new home. I've always wanted to use urethane,but availability hasn't been there. Now one of my suppliers is making a big push for it and can get it in two days,17 different colors! I've also heard its easier to work with......just fishin for some input.
Old 07-14-2011, 09:59 PM   #6
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Here's my comparative post:
http://www.contractortalk.com/f73/ur...2/#post1232415
Angus
angus242 is offline
Old 07-14-2011, 10:18 PM   #7
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
I would point out to your architect that there is always the unknown when mixing grouts. The best thing I like about Urethane Grouts is that I can work slowly and keep the job clean and tidy. With a large commercial project you will be working against the clock and each batch needs to be mixed exactly the same.
I have only worked with epoxy grouts a couple of times and an equal amount with urethane. It felt much nicer knowing I didn't need to get all the area grouted and cleaned in X amount of time.
The fact that the Quartz Lock 2 grout I used for my home does not yellow in the sunlight was the tipping point for me.
Try both if you have time and compare.
JohnFRWhipple is offline
Old 07-14-2011, 10:22 PM   #8
Groutface
Groutface's Avatar
Rewards Points: 524
Wow excellent rundown! When u say long term durability exactly what do u mean? Because of its shorter time on the market
Old 07-14-2011, 10:28 PM   #9
Groutface
Groutface's Avatar
Rewards Points: 524
Thanks John, the yellowing issue is a serious point on this one although the grout is darker, its on Riverside drive and backs up to lake st clair. Windows are almost the entire northwest side of the house!
Old 07-14-2011, 11:18 PM   #10
One of the best setters I know online is Rod from Katwyk Tile. His last two upscale projects both featured Quartz Lock 2 Grout. If Rod is using this on his jobs that tells me something.
Angus sold me on the product a year ago - I wish I listened better to Angus's cleaning process as the second time round I followed all the pointers and my production was up and the difficulty was way down.
Make sure you mix often and practice a little before going all in - the Urethane grout has a different feel and the cleaning process is a little different. I found that it doesn't kick up as quick in the joints and it is more forgiving with the "Tooling Process".
I have a White 4"x4" tile in my kitchen. Three kids. Two cats. We couldn't be happier with the end result. I love the "High White" colour and my wife thinks the 'Quartz' sparkles in just the right light and just the right angle.
JW
Old 07-15-2011, 06:55 AM   #11
Groutface
Groutface's Avatar
Rewards Points: 524
Sweet......sounds great ,I think with this rundown ill be able to convince him. Pretty pumped to use it! Thanks
Old 07-15-2011, 11:21 PM   #12
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
EPOXY is in my blood , thats why i dont crack and nothing bothers me .. haha ! SPECTRALOCK 200IG . i drink two cups every morning before heading out..
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 07-16-2011, 06:32 AM   #13
GO Remodeling's Avatar
Rewards Points: 96
Architects don't know everything??? Now, you can give him another option. Just remember the "can't get wet for 3 day" rule with urethane.
GO Remodeling is offline
Old 07-16-2011, 06:07 PM   #14
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 110
It's 7 days
http://www.starquartz.com/grout-tech...ata-sheet.html
goneelkn is offline
Old 07-16-2011, 06:24 PM   #15
Groutface
Groutface's Avatar
Rewards Points: 524
I've read 7 days also
Old 07-17-2011, 09:12 AM   #16
Rewards Points: 96
my bad.
Old 07-17-2011, 10:22 AM   #17
goneelkn's Avatar
Rewards Points: 110
my bad.
No drinks for you today!
goneelkn is offline
Urethane Grout Installation Tidbits angus242 Tiling 100 05-13-2013 03:23 PM
epoxy grout bluebird5 Tiling 17 03-31-2011 05:30 AM
How to clean epoxy grout after grouting kallo07 Tiling 16 01-14-2011 05:45 PM
Moisture Problems with Carrera Marble and Epoxy Grout Tallguy1 Tiling 4 10-13-2009 09:50 PM
Epoxy Grout rusting?? jarvis design Tiling 23 07-30-2009 12:15 AM
