Durock Is Wrong Side Up
Old 10-15-2008, 02:19 PM   #1
Preserving the Past
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Rewards Points: 2,060
Send a message via Skype™ to Jason Whipple
I'm working on my addition and have a guy here (an employee) putting down the durock in the kitchen area. When I got home this afternoon he had about 60% of the area done BUT the rough side is down
Will this affect my tile in any way? I planed on using slate for the floors. The sheets say rough side for mortar and smooth side for mastic. He was thinking since the sheets were being put down in mortar that the sheets had to go rough side down. (it's been one of those days all day today!)
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 10-15-2008, 03:38 PM   #2
Tile Pro - Consulting
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Rewards Points: 352
Re: Durock Is Wrong Side Up
Jason,
That is not a problem, thin set will stick just fine to the smooth side.
Did you happen to check the deflection rating of your subfloor though? Natural stone requires a much stiffer subfloor than ceramic or porcelain, If it's not built for natural stone spec'd at the time, it most likely will not support slate.
Jaz
TILE GUY - retired- TROY, MI - Method & Product suitability consulting.
MARBLE from ITALY & GREECE - PERLATO SICILIA - PERLATINO - BOTTICINO - THASSOS - SIVEC - VOLAKAS - NAXOS - others, Slabs - Tiles - Custom - marmo.sicilia@yahoo.com
JazMan is offline
Old 10-15-2008, 03:43 PM   #3
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,016
Send a message via Skype™ to ChrWright
I agree... It shouldn't be a problem.
But I'd still smack him around a little...
Christopher Wright, CR: President @ WrightWorks, LLC
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 10-15-2008, 04:10 PM   #4
Preserving the Past
Originally Posted by JazMan View Post
Jason,
Jaz
Should be OK for deflection. I have 2 x 10's 16 o.c. spanning 17' with a triple 9 1/2" LVL in the middle of the span. Over that I put down 3/4" t & g Advantech sub flooring
I'm going to use 1/2" thick slate because there is also a wood stove going in it for heat. I don't think 1/4 would hold up to the heat.
Facebook | Twitter
Old 10-15-2008, 04:11 PM   #5
Preserving the Past
Yeah, I busted his balls a little. He's got his wife on his mind lately, she's due any day now I have to cut him a little slack for that.
Facebook | Twitter
Old 10-15-2008, 04:13 PM   #6
Rewards Points: 2,000
Purely in the interest of science, we once did
a shower half and half.
That was 10 years ago, and no problems so far.
neolitic is offline
Old 10-15-2008, 04:17 PM   #7
Proprietor
MattCoops's Avatar
Trade: TILE!
Rewards Points: 1,060
Actually, when we used to use durock I usually installed it "upside down" because of the crowning of the sheets.
But, about this situation, I don't know if thicker slate will solve it, but around a wood stove the slate gets pretty hot. We had to rip up some a while back and replace with a ceramic "look-like" slate.
But tile around a wood stove is a great idea. Tile has great solar benefits.
Matt Cupan TileWorks:
Bathroom remodeling & custom tile projects for the Commonwealth of Massachusetts, southern New Hampshire and Union County, North Carolina.
(978) 476-0662 | cupantile@gmail.com
MattCoops is offline
Old 10-15-2008, 04:34 PM   #8
JazMan's Avatar
Rewards Points: 352
Jason,
OK, so you're saying the joists span a little over 8' right? That's fine, but do you have a single layer of 3/4" Advantech subfloor? If so, not good.
Jaz
JazMan is offline
Old 10-15-2008, 04:39 PM   #9
Builder/Remodeler
ChrWright's Avatar
Some bosses even harp on their guys for not making sure the printed labeling all faces the same direction...
Reminds me of the old Phil Hartman SNL skit "The Anal Retentive Carpenter".
Miss that guy.
Old 10-15-2008, 04:39 PM   #10
DavidC
DavidC's Avatar
Rewards Points: 2,006
And I suppose he's expecting a little time off for that to boot!
Are there no soup kitchens? :>)
Best wishes to both of them.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 10-15-2008, 04:41 PM   #11
Preserving the Past
Jason,
Jaz
Wouldn't the 3/8 durock applied w/ thin set help it? What should have been done? Not trying to argue but I've seen slate installed on less than what I'm doing it on. Do you think 1/4" slate will take the heat of the wood stove?
Facebook | Twitter
Old 10-15-2008, 04:50 PM   #12
Preserving the Past
Good Luck
I got him a box of condoms and the whole set of Gary Katz finish carpentry DVDs for his upcoming off time I hope he uses them both! He was one of our best installers on our exterior job in NY.
Facebook | Twitter
Old 10-15-2008, 04:51 PM   #13
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Durock adds no structural strength whatsoever. Its sole purpose is a surface to bond tile/stone to. You should have a minimum of 1 1/4" of plywood in addition to meeting deflection standards for the joists.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 10-15-2008, 04:58 PM   #14
DavidC
DavidC's Avatar
The job we learned this on we ended up going back and adding another 3/4" ply from underneath, screwed and glued. Pain is the ass but fixed our problem and lesson learned. TCNA handbook since then.
Good Luck
DavidC is offline
Old 10-15-2008, 04:59 PM   #15
Preserving the Past
Well that sucks! Back to the drawing board!
I was hoping to have the floor tile and counter tops made from the same stone. Their was no room for the extra layer any way.
I guess I'll be looking for porcalin now
Facebook | Twitter
Old 10-15-2008, 05:01 PM   #16
Preserving the Past
Good Luck
Now there's an option! The dream is still alive
Facebook | Twitter
Old 10-15-2008, 06:45 PM   #17
JazMan's Avatar
Rewards Points: 352
I vote for porcelain. It'll be much easier to maintained too.
Jaz
JazMan is offline
Old 10-15-2008, 06:52 PM   #18
Preserving the Past
Jaz
Would I be OK with the floor the way it is? Could it take the heat from a small wood stove over it?
BTW thanks for all the help with this everyone I want to do this right.
Facebook | Twitter
Old 10-15-2008, 07:08 PM   #19
Builder/Remodeler
ChrWright's Avatar
Do you have a picture or link to the wood stove in question?
What's your source for the slate you were going to use? What format?
Old 10-15-2008, 07:29 PM   #20
Preserving the Past
The stove is something similar to this but it's an antique that we found for half the price.
The slate is local Vermont slate. I was thinking about a 16" x 16" tile or 18" x 18" The kitchen area is roughly 16' x 15' wide open and no cabinets.
Facebook | Twitter
Help on green side of green roofs Renegade Landscaping 19 07-03-2008 07:14 PM
am i wrong here? mouse01420 Roofing 35 02-04-2008 10:15 PM
Quote and Estimate Breakdowns....what's wrong with honesty? Flikka Painting & Finish Work 39 08-21-2007 10:27 AM
Wrong address oldgoat General Discussion 2 05-06-2006 07:13 PM
