Durock Vs Hardibacker
Old 09-08-2012, 10:15 AM   #1
lifestooshort81's Avatar
Trade: Home Remodeler
Rewards Points: 75
Hello All
I was on a job today and my partner for whatever reason decided we were using hardibacker to line a tub. Normally we use Durock/wonder board so I'm not too familiar with the product. He said he grabbed it because he thought it cut easier and was lighter.
All in all I found it harder to score cut and almost twice as heavy. So my question is what is the advantage to using hardibacker in a tub/shower? If there is any. what about flooring? Maybe it's more of a flooring product?
Thanks!
Al
-Al C."Jack of All Trades" Stage 1 LLC Home Remodeling.
sometimes too inquisitive for my own good...
lifestooshort81 is offline
Old 09-08-2012, 10:25 AM   #2
Gary H's Avatar
Rewards Points: 2,342
Re: Durock Vs Hardibacker
You will find more info on that in the tile section. The tile guys there have lots of good info on backing.
Gary H is offline
Old 09-08-2012, 09:29 PM   #3
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
You found hardibacker twice as heavy as durock?
Oh well, if you scored and used that on a tub surround, you might as well continue on the floors, or just go back to what you're used to using, durock. I, like you, like to use things I'm familiar with and have use a lot. Good luck.
CO762 is offline
Old 09-09-2012, 08:57 PM   #4
GO Remodeling's Avatar
Rewards Points: 96
Hardibacker sucks the water out of your mastic. (That's a joke around here.) Out of your thinset. I dislike it for that reason. I prefer cement board. On the rare occasion I will use Hardi, it's because it doesn't bend as much when fastening so it can be floated with a little more thinset to make a curvy floor flatter.
GO Remodeling is offline
Old 09-10-2012, 08:09 PM   #5
Wearer of Hats
Ethos's Avatar
Trade: Kitchen and Bath Remodel
Rewards Points: 294
It's all junk. Denshield is the way to go. Easier to install, and it's waterproof. There's not one advantage to hardibacker that I can think of. Use a urethane sealant to seal off screws and seams, like Wedi sealant or Sikaflex 221.
Ben - Ethos Kitchen and Bath
http://www.kcethos.com
Ethos is offline
Old 09-10-2012, 08:25 PM   #6
Bathroom Remodeler
srwcontracting's Avatar
Trade: Bathroom Remodeling
Rewards Points: 560
So denshield is waterproof? I finally found a place around here that I can get it. Going to try it for the first time on my current job (trying to save some $$$ on these tub surrounds. Been using Wedi)
srwcontracting is offline
Old 09-10-2012, 08:28 PM   #7
Wearer of Hats
Ethos's Avatar
Rewards Points: 294
It has a waterproof surface, cuts like drywall and installs easy. You need to screw every 6 inches, and since you seal the screwheads with a good sealant, you can use regular drywall screws. They aren't exposed to moisture or thinset.
Ethos is offline
The Following User Says Thank You to Ethos For This Useful Post:
srwcontracting (09-10-2012)
Old 09-10-2012, 08:31 PM   #8
Bathroom Remodeler
Rewards Points: 560
Just read your other post under the Wedi system. Looks lie a pretty good idea! At about $2 a sqft for Wedi panels....it certainly begins to add up!
Old 09-10-2012, 08:41 PM   #9
Wearer of Hats
Ethos's Avatar
Rewards Points: 294
Oh yeah. Denshield is half the price of Wedi in my area, and frankly, I like working with it better. Just need the first foot to make that watertight bond at the corner, and then you seal the upper seam between the two different materials with Wedi and it's done.
Ethos is offline
JHC (09-14-2012)
Old 09-10-2012, 10:22 PM   #10
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Love the denshield......don't use anything but. Water proof seams and screws......no bevelled edges like durock or permabase so you got a perfectly flat surface to tile. Comes in 32" x 62" or 48" x 96" .......can't beat it. That being said I've never tried the hardi......Probly won't....thumbsup
Groutface is offline
The Following User Says Thank You to Groutface For This Useful Post:
Ethos (09-11-2012)
Durock bradsgun Construction 1 08-07-2012 05:29 AM
Kerdi Band on Durock? tile9 Tiling 5 10-02-2010 12:00 AM
Subfloor and Durock Demo HomerJ Flooring 6 04-06-2010 10:32 PM
durock bbangalal General Discussion 16 07-28-2009 01:03 PM
SLC over Hardibacker? ridgeline_dev Tiling 13 10-27-2008 10:05 PM
