Trade: tile setter
Dry Pack Over Finshed Radiant Heat
hi, im having trouble finding the proper solution for this install. im working with a concrete floor that has radiant heat through it, the home owner wants to raise the floor 3/4 of an inch befor tiling. should i dry pack, and if so how do i put the wire lath down/ should i modify my dry pack?
Trade: tile setter
Re: Dry Pack Over Finshed Radiant Heat
is there another method?
Tile Contractor
Your suggestion is your best-bet I think. Lay the metal flat and cover it over, it will be just fine.
Trade: tile setter
should i thinset the concrete slab as i dry pack im thinking this might give better adhesion
Professional Remodeler
Polymer bonding agent? Workes well for regular cement-besed products, I would think it would work with drypak. Might have to put a slurry coat on as you set the drypack, someone else might have an idea.
-Mike- Falcon Contracting Residential - Commercial
Trade: tile setter
hey mike, i have heard of people modifying thier dry pack before.im just not sure if this is the right circumstance. and what are your thoughts on laying wire lath befor hand, is it necesary.like i said i cant staple it down
Trade: tile and stone
just use a slurry mix to get a bond to the existing concrete, and there is no need for lath in this application.
tile mason
I would definitely use lath. You don't really need to fasten it down.
Just lay it on floor and cover with mud. You could also use an SLC over the radian heat.
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
Trade: Kitchen & Bath
Do you really want better adhesion considering the amount of movement you're going to get in the concrete substrate due to the radiant heat? I'm seriously asking, not trying to be a wiseacre.
#10 | |
tile contractor
Re: Dry Pack Over Finshed Radiant HeatQuote:
Just in case you don't know-- the slurry that kbtile's talking about is pure portland cement mixed with water. You can either throw water on the floor and then sprinkle dry cement into it and work it in with a broom. or mix it in a pail pisswater loose, and then APPLY it with a broom. Either way, you need to get dry pack on it immediately, before the slurry dries.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
| Demo a foundation under a radiant heat slab without disturbing the slab...? | wackman | Remodeling | 18 | 04-02-2007 12:38 AM |
| cherry mercier over quick track radiant heat | ApgarNJ | Flooring | 8 | 05-22-2006 04:36 PM |
| Hardwood Floors over Radiant Heat | bigtick | Flooring | 10 | 12-08-2005 03:43 PM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
