Ditra Heat Fleece
Old 08-21-2017, 11:02 PM   #1
Unger.const's Avatar
Rewards Points: 2,502
Ditra Heat Fleece
Installed about 800 sq ft of sites heat and noticed the fleece back was a little harder to get thinset (modified over plywood) to glue it down. even presoaking floor a little more didn't help. Even got it so runny I didn't like it. Even when I turned my back on the end of it. It tended to pop up were the curve of the roll had a little bit of memory. I would go back peel it up and it had plenty of coverage on fleece and floor but seemed dried up. I slopped some fresh wetter then usual thinset and pushed it back down. The bubble in the mat would seem to lay flat after that. But I kept having to re wet-thinset those ends about 10min after first install of that area.
I realized the fleece was like twice as thick as regular ditra (never had a problem with it) is there a reason for the thicker fleece? Is it just me?
P.s. I'm a super loyal schluter fan so (I like how they have ran their company and have been very very loyal to contractors directly) so it's not a matter of using some other membrane. Besides they are all following the leader anyways.
Unger.const is offline
Old 08-21-2017, 11:28 PM   #2
tjbnwi's Avatar
Rewards Points: 1,782
Re: Ditra Heat Fleece
Which Ditra Heat mat? The white fleece (Ditra Heat mat)or gray fleece (Ditra Heat Duo)?
If it is the (gray) Duo, it is a sound dampener and if used over concrete insulation. I can attest it really does work on sound.
If it's the white fleece you use the Ditra trowel with the thin set mixed slightly loose. If it is the gray fleece you need to use a 1/4x1/4" trowel with the thin set slightly loose.
Dampening the floor (as you did) is a must.
I finally got the Schluter roller, it's great.
tjbnwi is online now
Unger.const (08-22-2017)
Old 08-21-2017, 11:48 PM   #3
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Send a message via Yahoo to charimon
Did you call your rep?
If the Fleece is much thicker than normal (ditra heat) that would be my first to do.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
The Following User Says Thank You to charimon For This Useful Post:
Old 08-21-2017, 11:50 PM   #4
tjbnwi's Avatar
The Ditra Duo Heat is about 1/8" thicker than the normal Ditra Heat mat fleece.
Old 08-22-2017, 12:40 AM   #5
tjbnwi's Avatar
This is the Ditra Heat Duo mat. You can see how heavy the fleece is. It is also much more orange than the standard Ditra.
Old 08-22-2017, 09:51 AM   #6
It's the white. I didn't know about the duo.
Used the ditra trowel. And looser then I would like.
They said at one of the training courses you can put down two layers of ditra to reduce sound transmission greatly. Have not had a need for that yet.
Last week when I was installing it i thought . This would have been a great job to have the roller.........but I didn't think about it before.
I did think about inventing a serrated squeegee to speed up the gig.
Old 08-22-2017, 09:55 AM   #7
No. There is a newer guy for this area. It's been almost a year since I did tile as other projects haven't required it.
The two for this area use to be Don corliss. But he is the corporate training for the big classes now. Then it was a fella out of Washington (name escapes me at the moment) and now another dude. Have yet to meet.
Old 08-22-2017, 09:58 AM   #8
Hahaha. I was thinking how lazy you were to use a track saw instead of a knife. Then I thought no that's sorta genius!
Old 08-22-2017, 01:47 PM   #9
tjbnwi's Avatar
There are very few things I don't cut with the track saw.
Peter_C (08-22-2017)
Old 08-22-2017, 10:57 PM   #10
What are the row of holes in your track. I just got one the other day and my track doesn't have holes.
Old 08-22-2017, 11:26 PM   #11
tjbnwi's Avatar
The holes are spaced 32mm apart. There is a "tool" that attaches to a router and runs along the track. You'll notice the number has an LR 32 suffix. This allows you to drill holes for cabinet work.
You received the proper track with your new saw. The holey rails are an option, they come in 55" and 90" lengths.
If you use cement board, get the CMT PCD blade for your TS. The TS connected to a CT is the absolute best way to cut "cement" type building products. Both interior and exterior products.
Unger.const (08-23-2017)
Old 08-22-2017, 11:27 PM   #12
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 406
LR32 system "holey" rail. It's for drilling for shelf pins.
Xtrememtnbiker is online now
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Old 08-23-2017, 11:12 AM   #13
So like your sandwiches?
Old 08-23-2017, 08:16 PM   #14
tjbnwi's Avatar
Ripped and cross cut...
Old 08-23-2017, 11:33 PM   #15
Rewards Points: 406
I cut a stack of 25 sheets of paper in half with mine for the wife. It worked...
The Following 2 Users Say Thank You to Xtrememtnbiker For This Useful Post:
overanalyze (08-23-2017), Unger.const (08-24-2017)
Ditra "Heat" fourcornerhome Flooring 31 02-10-2015 03:04 PM
Heat storage, Heating system music9704 General Discussion 3 12-16-2014 07:30 AM
Compressor relay for addon heat JohnR HVAC 5 11-23-2014 07:56 AM
It's getting hot out there, people......... 480sparky Health & Safety 9 07-11-2010 08:23 PM
any triple pane windows advocates here? advanced_energy Windows, Siding and Doors 43 02-22-2009 07:47 PM
