Ditra Failures??
Old 01-19-2009, 08:41 AM   #21
tile mason
MattCoops's Avatar
Re: Ditra Failures??
What don't you understand? I'll clarify it for you.
MattCoops is offline
Old 01-26-2009, 01:21 AM   #22
classic muscle
rsss396375's Avatar
Trade: General Contractor Tile Contractor
[quote=PrecisionFloors;574705]The biggest reason for failure is not following directions. The thinset used to install the Dita must be modified and it must be mixed loose enough to ensure good saturation of the fleece.
Good call
This is the biggest issue for good adhesion. Mix almost a watery consistancy, not as though you are used to when setting. You should be able to see a grayish color consistant through the Ditra orange.
rsss396375 is offline
Old 01-26-2009, 11:00 AM   #23
reveivl's Avatar
Trade: Renovations
...the 2020 T&A publications...
I guess you'd want 20/20 if you had publications like this to look at...
reveivl is offline
Old 01-27-2009, 06:21 AM   #24
Jerry T's Avatar
Trade: Self employed - hard surface installer
Originally Posted by reveivl View Post
Yes, but did it work?
It's been a few years ago, but that poster left me scratching my head ....... you have to go way out of your way to put Ditra in upside down.
Jerry T is offline
Old 04-29-2009, 03:42 PM   #25
rfrymier's Avatar
Trade: I am a landscape designer, building decks & patios
Has anyone applied ditra for exterior use beneath stone tile on stairway from house to patio?
rfrymier is offline
Old 04-29-2009, 07:35 PM   #26
Tile Contractor
Bud Cline's Avatar
Why would anyone want to?
Bud Cline is offline
Old 04-29-2009, 08:40 PM   #27
Remodeling Professionals
buildenterprise's Avatar
According to Schluter you're supposed to use UN-modified mortar to install the Ditra.
Originally Posted by PrecisionFloors View Post
The biggest reason for failure is not following directions. The thinset used to install the Ditra must be modified and it must be mixed loose enough to ensure good saturation of the fleece. Then the Ditra must be embedded in the thinset with direct pressure. I use a wall paper roller, but a grout float, flat side of a trowel, drywall knife, etc. will work. The key to installing it is getting the fleece properly embedded in the thinset. Outside of that I know of no failures.
buildenterprise is offline
Old 04-29-2009, 09:04 PM   #28
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Over concrete, it's either/ or. The MUST use unmodified is for installing the tile over the Ditra.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 04-29-2009, 10:03 PM   #29
Its all ball bearings
angus242's Avatar
Trade: Tile
I'm not going to question each person's views on how they install Ditra.
However, the Ditra Installation Handbook says:
Ditra installed over wood, use modified.
Ditra installed over cement, use unmodified.
Always unmodified to set tile over Ditra.
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is online now
Old 04-30-2009, 12:45 AM   #30
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Actually you're supposed to use thinset suitable for the substrate you're setting on, which in the context of the first post of this thread, is a wood sub-floor, which would require a latex modified mortar
edit: Damn...didn't even see The Colonel's post. What he said.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 05-01-2009, 10:42 PM   #31
bathroom guru
jarvis design's Avatar
I did my front step/walkway with ditra. Installed 12x24 porcelain on top with epoxy grout.
I haven't given it a good cleaning yet from the winter, but, it looks exactly like it did when I did it last fall.
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 05-12-2009, 09:02 PM   #32
MF Custom's Avatar
The biggest reason for failure is not following directions. The thinset used to install the Dita must be modified and it must be mixed loose enough to ensure good saturation of the fleece. Then the Ditra must be embedded in the thinset with direct pressure. I use a wall paper roller, but a grout float, flat side of a trowel, drywall knife, etc. will work. The key to installing it is getting the fleece properly embedded in the thinset. Outside of that I know of no failures.
Better check into using modified thinset with Ditra, It say right on the instructions in BOLD "USE ONLY NON MODIFIED THINSET"
MF Custom is offline
Old 05-12-2009, 09:30 PM   #33
Have you read the WHOLE post.....something tells me not. Scroll up. It's right there for your very own eyes to see
Precision Flooring
(772) 237-9900
Old 05-12-2009, 09:31 PM   #34
R&D Tile's Avatar
Trade: Tile installations
For setting tile only, you need modified for installing Ditra over plywood.
R&D Tile is offline
Old 05-12-2009, 11:19 PM   #35
tile contractor
MF Custom-- Nobody's perfect-- not even me!
Old 05-13-2009, 05:19 AM   #36
Jerry T's Avatar
Me neither Bill
Jerry T is offline
Old 05-13-2009, 08:14 AM   #37
MF Custom's Avatar
I just posted what Ditras instructions say right on the label.
"USE NON MODIFIED THINSET ONLY" but I would think over plywood you are correct it should be modified thinset.
Old 05-13-2009, 09:17 AM   #38
angus242's Avatar
Trade: Tile
Actually I posted what's on the instructions...even with pictures:
http://www.contractortalk.com/f73/di...x2/#post668041
Angus
Old 01-17-2011, 07:02 AM   #39
Linear Shower Drains
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Have you men read this thread on John Bridges site?
http://www.johnbridge.com/vbulletin/...ad.php?t=83568
I have not been able to shake this new training I received at Mapei and the story of the Whistler Builder who ripped out all the Ditra from his exterior deck because he "Hates" it and does not think it is suited for exterior use in our Canadian Climate.
Only one poster touched on what I think the root problem can be and that is the little dovetails holding water and the freeze thaw cycles expanding and pulling on the Kerdi Seams.
You will notice as well that the Ditra is layed across the slope creating little dams so the water will be held up every 3 feet...
My deck is still getting soaked. I Hydro Banned it till Spring time and think I'm going to try Nobel Deck as my Primary waterproofing material...
Now to get it approved for use in Canada.
John Whipple (By Any Design Ltd.) - Member of Terrazzo Tile and Marble Association of Canada, the National Kitchen & Bath Association and the National Tile Contractors Association. Specializing in Vancouver bathroom renovations, linear shower drain installations and shower waterproofing procedures.
JohnFRWhipple is offline
Old 01-17-2011, 01:47 PM   #40
angus242's Avatar
Trade: Tile
John,
There were many installer issues with that deck. In that climate, that install was bound to fail.
Angus
rapid set with Ditra tang Ceramic & Stone Tile 4 01-06-2009 09:26 PM
Dricore and Ditra matting MAD Renovations Flooring 3 11-30-2008 01:06 PM
Red Guard vs Ditra HeritageHomes Flooring 1 09-11-2008 09:46 AM
Schluter Kerdi and Ditra Trowels jarvis design Ceramic & Stone Tile 0 09-06-2008 09:51 AM
Ditra XL now on market!! jarvis design Ceramic & Stone Tile 4 06-15-2008 02:30 PM
