Trade: Builder, Additions, large remodels...Lately also small remodels.......
Discolored Grout???
We recently did a tile job using products we always use and some areas of the grout look discolored. They almost look wet or like water got trapped inside and was sealed in.
Any idea what caused this? Could my guys have used too much water or indeed sealed too early? We waited days to seal so I wouldn't think that's the cause. I'm stumped and I need to correct it. Appreciate the help. Wack
"I only bother remembering things that I can't easily look up." Albert Einstein |
Re: Discolored Grout???
Is that grout near the tub or caulk? If it is grout I would say it was because someone used to much water. Either mixed it to wet or sponged it way to much. One other thing, if that is grout next to the tub I think you are going to have worse problems than the color issue. That should be caulked.
It is grout there. That is the grout that's discolored next to the tub. It was also along a few of the other walls but got covered by the shoe.
What's the fix? Grind out and then color matched caulk?
Chief Toilet Mover
Trade: Bathroom Remodeling
What brand is that? C-cure?
It's contaminated. I've seen it happen for many different reasons. Usually has nothing to do with the mixing of the grout, but usually has something to do with something contaminating it during installation, a sponge pulled across it that is contaminated by something adjacent to the grout, something in the grout lines before you put the grout in it... Just cut it out and replace, but clean the area around it really good before you regrout. |
#5 | |
Re: Discolored Grout???Quote:
We'll cut it out and use some color matched caulk. Thanks guys. Wack
tile contractor
It looks like one of two things to me-- either latex may have leeched from the thinset and migrated to the surface of the grout, or more likely, when your guys were grouting they may have passed the sponge on the final wipe a little too fast and left just a little bit of water sitting on the grout joint.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
Tile Guy
Trade: Tile and stone
hase anyone else been in the house? Cleaners?
#8 | |
Nope, we did the work then I came that night to inspect and right away I noticed it. Figured it'd go away as it cured but it never did.
| Any good tricks for grinding out grout? | wackman | Masonry | 5 | 01-25-2008 06:35 PM |
| Need help on grout | Red | Ceramic & Stone Tile | 10 | 01-15-2008 08:42 PM |
| Tile grout color too light | fsbr | Flooring | 18 | 11-29-2007 06:05 AM |
| Grout width query. | Nick S. | Ceramic & Stone Tile | 18 | 10-12-2006 10:22 PM |
| best way to seal grout for glass mosaics. | ApgarNJ | Masonry | 2 | 06-27-2006 06:18 AM |
