Dens Sheild
Old 06-28-2012, 09:28 AM   #1
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,494
Dens Sheild
I was thinking about this...dens shield looks just like dens armor but with the addition of some blue/grey water proofing stuff smeared on the back.
After I painted waterproofing on the screws, seams, niche, etc. There isn't a lot of space left un painted and I have half a bucket of red guard.
Wouldn't it have been more cost effective for me to use Dens Armour and painted the whole enchilada in liquid membrane?
Inner10 is offline
Old 06-28-2012, 03:36 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Dens Sheild
Depends on the price difference between
DensShield vs DensArmor.
Around my area, DensArmor is almost extinct. The search trying to find a stocking distributor makes it no longer a viable options for me to use.
Angus
angus242 is offline
Old 06-28-2012, 09:22 PM   #3
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Re: Dens Sheild
I think Dens Armor would suck up more waterproofing.
I used it for a 1/2 bath some time back after hearing the colonel and others talk about it. I was very satisfied with it and I think it is tougher than Densshield.
I'm not sure why it didn't catch on. There are a lot of things I don't understand.
cleveman is offline
Old 06-28-2012, 10:19 PM   #4
Inner10's Avatar
Re: Dens Sheild
There is tonnes of it here, it's used to sheath the exterior of most non combustible builds. It's about 25 bucks a sheet, dens sheild is 40 IIRC.
Inner10 is offline
Old 06-28-2012, 10:46 PM   #5
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Dens Sheild
Are you sure that's not DensGlass you're talking about?
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
Inner10 (06-28-2012)
Old 06-28-2012, 10:51 PM   #6
Inner10's Avatar
Re: Dens Sheild
That is exactly what I'm talking about...my bad.
Inner10 is offline
Old 06-29-2012, 09:14 AM   #7
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Re: Dens Sheild
This is Denshield in the picture.
JohnFRWhipple is offline
Old 06-29-2012, 10:12 PM   #8
cleveman's Avatar
Re: Dens Sheild
One of the things I like about densshield is that when you spread mortar on it, it doesn't suck all the moisture out. I did a bath floor last week on permabase or something like that, and even after I sponged it and sponged it, it still dried out the mortar very quickly.
cleveman is offline
Old 06-29-2012, 10:34 PM   #9
Bonzai's Avatar
Trade: Home Renovations & Repairs
Rewards Points: 252
Re: Dens Sheild
Just love the workability of it in general and finally I can get the 8' sheets here so less joins in a typical shower than using the wee 4' sheets.
Renovations & Repairs. Bathrooms, decks, tile, paint & much more.
North Vancouver to Whistler and between.
TOLL FREE 1-877-804-3326
http://www.adventhomesolutions.com
Bonzai is offline
Old 06-29-2012, 10:37 PM   #10
Inner10's Avatar
Re: Dens Sheild
So is it just DensGlass with waterproofing smeared on one side?
Inner10 is offline
Old 06-29-2012, 10:43 PM   #11
Bonzai's Avatar
Rewards Points: 252
Re: Dens Sheild
It also has a vapor barrier on the back (yellow side). If installing in an exterior wall with poly vapor barrier you're supposed to remove the poly so as not to get condensation issues by the way
Bonzai is offline
Old 06-29-2012, 10:56 PM   #12
Inner10's Avatar
Re: Dens Sheild
I've never seen anyone remove the vapor barrier when using dens shield, couldn't imagine that passing inspection...but it's not exactly my area of expertise by a long shot...
So like I was saying is DensShield just DensGlass with waterproofing?
Inner10 is offline
Old 06-29-2012, 11:23 PM   #13
Bonzai's Avatar
Rewards Points: 252
Re: Dens Sheild
This has more specifics on exactly what it is ... http://www.gp.com/build/documentview...elementid=4284
And about 2/3 of the way down page 6 it does state not to have a vapor barrier behind the Denshield on an exterior wall. I had an inspector ask me about this once .. I showed him what it said on the label stuck on the front of each sheet and he shrugged and said fine then. Basically it has it's own vapor barrier.
It's essentially a water resistant gypsum sandwich between 2 glass fibre sheets with other ingredients for waterproofing.
Bonzai is offline
Old 06-30-2012, 09:43 AM   #14
Inner10's Avatar
Re: Dens Sheild
So it is Dens Glass with waterproofing smeared on it?
Ontario is wacked out when it comes to vapor barrier requirements. If you spray foam exterior walls you still have to put vapor barrier on top of that, unless you foam continuously over top of the studs.
Inner10 is offline
Old 06-30-2012, 09:57 AM   #15
Re: Dens Sheild
Is that new. In BC you don't have to do this if you spray foam. ???
Homes today are built to tight - I think there is something to be said for a little air movement. I like the new rain screen details and flashing requirements, I think finally there is some sound logic there but the isolation of ever leak can not be all that good for a home.
JW
Old 06-30-2012, 10:39 AM   #16
Bonzai's Avatar
Rewards Points: 252
Re: Dens Sheild
JW
I've yet to see the 850 changes in the new BC building code which was supposedly being published June 20th according to my local building department. I know it doesn't fully come in to effect until the Fall but I believe much of it they are going to try to enforce earlier.
Bonzai is offline
Old 06-30-2012, 11:03 AM   #17
Re: Dens Sheild
It's about time. My 2006 Code binder is beat to ****. Did you order a new copy? I'm thinking about going digital this time.
I was chatting with Eric from Noble and he tells me that some of these membrane vapour barrier, vapour sandwich issues will be further outlined in the coming months. Still waiting for the final skinny.
JW
Old 06-30-2012, 12:32 PM   #18
Bonzai's Avatar
Rewards Points: 252
Re: Dens Sheild
Not ordered a copy yet ... Digital may be how I go too as 'searching' that binder can be a real pain at times. Mine never leaves the office so it's still in good condition. I wonder how much they'll be charging this time round ?!
Bonzai is offline
Old 06-30-2012, 03:16 PM   #19
Talking Head
EthanB's Avatar
Rewards Points: 78
Re: Dens Sheild
I have all the books I need on my Nook which stays in my work binder. The search feature is very helpful. At $80 I probably would have bought a Nook just for to keep the code books on but having my break time books on it is a nice perk!
I can't get DensArmor from any of my suppliers either. I think one company about 30 minutes away carries it in 5/8".
Planer.....
EthanB is offline
Old 06-30-2012, 08:03 PM   #20
Inner10's Avatar
Re: Dens Sheild
John, it's only Ontario IIRC.
Inner10 is offline
Laminating Dens Glass??? jsostar General Discussion 1 12-03-2010 03:16 PM
Torch down roofing, does dens deck replace insulation metzade Roofing 16 08-24-2010 05:36 PM
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 12:33 PM
when does densShield become overkill wopachop Tiling 11 03-18-2008 11:30 PM
