Dark Spots In Grout
Old 02-22-2012, 07:51 PM   #1
kcremodeling's Avatar
Trade: Licensed Contractor
Dark Spots In Grout
Has anybody ever noticed dark spots showing up in newly installed grout? I have seen it before on a basement floor and assumed it was absorbing some of the moisture out of the concrete. Today, I noticed a couple of spots in the shower walls. Do you guys have any ideas what could be causing this?
kcremodeling is offline
Old 02-22-2012, 07:58 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Dark Spots In Grout
...and just yet another reason to not use cementitious grout.
You didn't mention the color of the grout so I can only guess. Yes, moisture could be an issue. Poor mixing could also be a problem. Well water or water with high mineral content could also be a problem.
Try some urethane grout. No water to measure. No mineral issues. No color inconsistencies. You get the point.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
kcremodeling (02-23-2012), ROVACON (02-23-2012)
Old 02-22-2012, 08:17 PM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
My favorite cementous grout issue is the red streaks when troweling on.
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
HandyHails (02-27-2012)
Old 02-22-2012, 08:23 PM   #4
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
Mine is white spots.. But that was before I used permacolor
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 02-22-2012, 08:27 PM   #5
If you need to loose weight just ask me how....
Old 02-22-2012, 09:09 PM   #6
Orlando Car
Lolol..
( 510 ) 760 - 6810
Old 02-22-2012, 10:33 PM   #7
GO Remodeling's Avatar
Rewards Points: 96
OP, where are the spots on the wall? If it's at the bottom of the wall then maybe it's the last spot to dry. Or, have any pinholes? A little bit if water might have gotten behind the tile.
GO Remodeling is offline
Old 02-23-2012, 06:39 PM   #8
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Mapei?
CO762 is offline
Old 02-23-2012, 10:42 PM   #9
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Could be dirty bucket.....water....mix?
Groutface is offline
Old 02-24-2012, 09:18 AM   #10
Clean bucket, new bag of grout, and mixed thoroughly.
I am also reluctant to seal the grout as I worry that it could "set in" the stain.
Old 02-24-2012, 09:35 AM   #11
Holy Crap!
ROVACON's Avatar
Trade: General Contracting-Renovations-Carpentry
Rewards Points: 296
kc-
How old is the grout (before you mixed it)? The add mixture? Or did you just mix with water? Public water or well water? Was it a single batch of grout or from multiple sources?
Sorry to hear about your problem. Hopefully some one has a remedy. I am with Angus. I only use urethane based grouts. Haven't needed to use epoxy yet but I hear good things about it now.
Who is the manufacturer?
Brian
ROVACON is offline
Old 02-24-2012, 09:41 AM   #12
We used an admixture in place of water for the mix. There are only a few spots that actually look different. Hopefully sealing the grout will even out the coloring.
I am not sure who the manufacturer was as the bag was thrown away.
Old 02-24-2012, 09:53 AM   #13
mbobbish734's Avatar
Trade: Property Preservation & Remodeling
I had a problem with white grout yellowing. Turns out it got durabond dust in it. Only happened in a couple spots. Had to remove and replace.
mbobbish734 is offline
The Following User Says Thank You to mbobbish734 For This Useful Post:
ROVACON (02-24-2012)
Old 02-24-2012, 07:51 PM   #14
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
I think it is wise to run the grout through a sieve first, then break up all the crumbles left behind.
cleveman is offline
Old 02-25-2012, 09:39 AM   #15
After a bit of research I have learned that if you do not mix the entire bag at once, the color pigments can be heavier in either the upper or lower portion of the bag.
It's honestly not that noticeable but it's really bugging the HO. I am going to try and mix up some more grout to a runny consistency and then paint it over all of the grout lines.
Old 02-25-2012, 09:41 AM   #16
Originally Posted by CO762 View Post
Mapei?
Yes, that is the manufacturer that makes the grout.
Old 02-25-2012, 10:54 AM   #17
Never had good luck with the painting thing. It will usually fall off. Tear it out and redo would be better.
Old 02-25-2012, 11:08 AM   #18
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
That's a recipe for efflorescence.
Angus
angus242 is offline
Old 02-25-2012, 09:06 PM   #19
Groutface
Groutface's Avatar
Rewards Points: 524
Guaranteed ,from dark to blotchy light.R&R only way to go if grout paint fails...
Old 02-27-2012, 08:07 AM   #20
orson's Avatar
Trade: Kitchen & Bath
Rewards Points: 502
I have had that same problem with microban.
While it may have been the durabond dust, I know for sure that microban will react with some organic compound(s?)
I spilled coffee with cream on a driveway and grabbed the 5gal bucket of rinse water I was using to sluice it off the driveway. Turned neon yellow as soon as it hit the coffee, it was pretty wild.
orson is offline
grout stains unavoidable? MichaelEmerson Tiling 32 02-27-2011 06:56 AM
best stain-resistant grout for glass tile rock nohow Tiling 3 10-10-2010 05:58 PM
How to install dark color grout properly? tyler durden Tiling 6 06-27-2010 01:10 PM
white spots on dark walls. flashheatingand Drywall 5 12-21-2008 12:19 PM
A REAL riddle! AAPaint Off Topic (Non Trade) 122 09-08-2006 04:41 AM
