Cutting Tile Question
Old 10-24-2008, 09:42 PM   #1
Home Serve's Avatar
Trade: siding windows soffit fascia
I have a customer wanting about 100 sq ft of tile installed in a bathroom with a circular "garden tub" in the corner that I would have to cut around. Since using added trim is not really an option in this case how is the best way to cut to the tub in order to leave a reasonably nice grout line up next to it? The only similar cuts we usually make are up under the toilet where they will not be seen.
Thanks,
Dave C
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 10-25-2008, 10:54 AM   #2
olzo55's Avatar
Trade: flooring
Re: Cutting Tile Question
i don't know why a window/siding guy is doing tile but ok we all need the work. pattern your tile. take some felt paper and lay a tile on it and cut the tile out of the paper. if you want you, add for the grout joint in the pattern and you can but it up against the set field tiles. cut the pattern to fit your tub. there are other ways to do this as well.
olzo55 is offline
Old 10-25-2008, 11:36 AM   #3
Its all ball bearings
angus242's Avatar
Trade: Tile
Templating will work. Use a 4 1/2" grinder with the appropriate blade to cut the tile. However, I wouldn't grout the space between the tile and tub. You should caulk that joint.
angus242 is online now
Old 10-25-2008, 02:45 PM   #4
R&D Tile's Avatar
Trade: Tile installations
Is the tub in yet?
R&D Tile is offline
Old 10-25-2008, 02:55 PM   #5
Home Serve's Avatar
Originally Posted by R&D Tile View Post
Is the tub in yet?
Yes the tub is installed (10 year old home). Good ideas for using templates to mark tile. I was more wondering what kind of cutter to use to cut the tile. We've cut tile similar but not a finish joint with a regular tile saw and the nippers but it's tough to do and especially to make look good. I thought of a 4" grinder but seems like it might be hard to be accurate with.
You are right, the joint should be caulked.
Thanks,
Old 10-25-2008, 03:13 PM   #6
Patrick's Avatar
Just use a Piece of 7/8" flexible J
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 10-25-2008, 03:35 PM   #7
I like Green things
WarnerConstInc.'s Avatar
:thum bup:
WarnerConstInc. is offline
Old 10-25-2008, 03:45 PM   #8
Home Serve's Avatar
Patrick, I don't think Mrs Jones is going to like that idea very well.
Dave C
Old 10-25-2008, 04:14 PM   #9
angus242's Avatar
Trade: Tile
Take your time. You can get a pretty clean with the grinder. Just remember, the joint will be caulked so the cut doesn't have to be 100% perfect.
Old 10-25-2008, 05:17 PM   #10
R&D Tile's Avatar
Cut it to within 1/16" of the marked line with an angle grinder and diamond blade, then I shape it perfect to fit and smooth the cut with my Makita sander and polishing pads.
R&D Tile is offline
Old 10-25-2008, 10:59 PM   #11
Knowledge Factory
Floordude's Avatar
The cuts do need to be perfect as the caulk your going to used is color matched sanded caulk made buy the grout manufacturer to perfectly match their grout, so the caulk look just like the grout. Anything else is handyman hackish.
http://www.AustinFloorguy.com
Floordude is offline
Old 10-26-2008, 09:29 AM   #12
Home Serve's Avatar
Thanks for the help guys, will keep the advice for down the road. Guess won't be doing this job, customer says 450 too much to remove carpet/trim, remove toilet, install backer, supply and install transition pieces, cut/lay tile, grout, cut off two doors, set toilet. Told her "good luck" finding someone that is going to do it right for less.
Old 10-26-2008, 10:42 PM   #13
Knowledge Factory
Floordude's Avatar
Ever 450 is on the way cheap side!!!!
Dang, she wants a caddy for the price of a Yugo!
Cleanup after tile job is done bqtchef Ceramic & Stone Tile 3 10-16-2008 01:11 AM
tile subfloor question rservices Flooring 5 03-25-2008 10:11 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Tile Design Question - Borders and Multiroom Jason Ceramic & Stone Tile 3 07-24-2006 04:32 PM
Backsplash Tile Question Robie Remodeling 5 02-13-2006 09:32 AM
