tomcutt
Trade: renovation contractor
Cutting Porcelain Tile
Hi ,
I am doing a bath project laying some porcelain tile (brand name antica venizia ,made in italy ) nice product 12x24 etc . My problem is i have a ton of straight cuts but cannot seem to get any more than 60% of them clean . Wet saw works ok but takes to long . Man is this stuff tough ! I installed a new cutting wheel still getting very poor results . Any tips from the experts Thanks in advance Tom |
It's all about the Avatar
Trade: I have no face!
Re: Cutting Porcelain Tile
You should be able to rent a 36" tub saw, we have a number of times. or take a piece of 3/8"plywood on you sliding bed and raise the blade, so you do not cut throuhg the plywood. Adjust as required, the plywood should back the tile....the best is a bigger saw...
Old school Ranger
Trade: flooring
It sounds like your trying to cut the tile on a tile cutter instead of a wet saw. Forget it ! It may take longer on a wet saw but least it will cut it and not waste your tile and time.
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Tom,
What brand and model cutter do you have? Pass that info along, someone is likely to have some tips. Jaz |
tile mason
a wet saw with a diamond blade rated for porcelain tile will cut through like butter
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
tomcutt
thanks everyone , I ended up using the wetsaw for all cuts ,took a little longer but it worked out great
Trade: tile-- marble --pavers--bath renovations-- driveways-- walkways-- patios
in the future if you encounter this and if you have only a few cut,s you mark your tile take a wet sponge and using your makita 4 inch grinder with a tile blade put the wet sponge against the left side of the grinder and follow the line that you have drawn you will take a while but you will get a cut that resemble a wet saw cut exactly just be patient and you will see it works great on any type tile
| Porcelain Floor Tile - fixing sanded grout cracks | ETHICS05 | Flooring | 11 | 07-18-2007 07:43 AM |
| Cutting ceramic tile? | Rugger | Electrical | 12 | 02-24-2007 01:13 AM |
| Porcelain Tile | jerome8283 | Remodeling | 10 | 10-08-2006 12:08 PM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
| Cutting Existing Tile. | kpikul | Remodeling | 16 | 02-05-2006 12:30 AM |
