Cutting Kitchen Tile - Use Angle Grinder?
Old 12-18-2017, 09:28 PM   #21
GoodLJohnny's Avatar
Trade: General Contractor / Handyman
Rewards Points: 66
Re: Cutting Kitchen Tile - Use Angle Grinder?
Originally Posted by hammer7896 View Post
I recently had to cut a tile countertop and I used the little 3 3/8 Makita 12v saw with a diamond blade and a spray bottle of water aim at the blade. Worked very well with no dust.
Mike
Wow - genius. Thanks Mike.
I wonder if I could even get a cheap mister/humidifier of some kind, so that I don't have to use my hands to spray ...
GoodLJohnny is offline
Old 12-18-2017, 09:42 PM   #22
hammer7896's Avatar
Rewards Points: 124
Makita actually makes a 12v tile saw with a water bottle attached to it.
https://www.makitatools.com/products/details/CC02R1
Mike
hammer7896 is online now
Old 12-18-2017, 09:43 PM   #23
Rewards Points: 66
Mike
Aha - great - thank you Sir.
I'm tempted to drop the $200 for the set (I have the 18 volt Makita for most of my other tools - I don't have any 12 volt ...) ...
I don't cut tile that much, so it's hard to justify the purchase ...
Old 12-18-2017, 09:48 PM   #24
hammer7896's Avatar
Rewards Points: 124
You’re very welcome.
Mike
Old 12-19-2017, 02:19 AM   #25
Unger.const's Avatar
Rewards Points: 2,412
I do alot of tile work and I wouldn't fuss with it. I would plywood (what ever thickness of the tile) the recess.
Cut and deal with tile........4 to 6 hours.
Plywood the hole.........4 to 6 minutes
Spend your time fighting the vent pipe instead
Unger.const is offline
Old 12-19-2017, 09:17 AM   #26
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 1,746
Yep, thats what I thought but OP says HO's want the micro flush with cabinets. He'll have to remove the tiles to cut them, no way they can be cut at the corners while still affixed to the wall.
The tile could still crack when removing and/or cutting them. HO should be advised of the risk. Not to mention whats behind the wall and what adhesive was used..and damages to the wall when removing the tiles. Maybe some drywall patching will be needed as well.
kirkdc is online now
The Following User Says Thank You to kirkdc For This Useful Post:
Unger.const (12-21-2017)
Old 12-19-2017, 12:55 PM   #27
avenge's Avatar
Rewards Points: 2,568
This will probably turn out like his concrete job in his other thread.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
Seven-Delta-FortyOne (12-19-2017)
Old 12-19-2017, 05:09 PM   #28
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,092
You will get zero dust if you use this grinder, hook up a vacuum to the dust port and you are good to go! I use it all the time to cut inside
Windycity is online now
Old 12-22-2017, 07:59 PM   #29
Rewards Points: 66
The project is done.
Thank you for the helpful suggestions.
It went very well. It took about 25 minutes to setup, 40 minutes to do the cutting, and 50 minutes to cleanup (I was very thorough).
I made pretty good money, and the clients were happy with the results.
I ended up undercutting the cabinets just a bit to get the last piece of tile off, and used my multi-tool to get the last pieces of wonderboard.
It did create a helluva lot of dust. I was covered. I had a valved dust mask, and suspect I breathed a lot of dust in.
There were several times I had to stop cutting because I couldn't see. I didn't have a pair of chemistry goggles - only clear glasses. (Time to buy some more goggles)
It was a great (paid) learning experience.
Thank you.
L
Cutting kitchen tile - use angle grinder?-img-6783.jpg   Cutting kitchen tile - use angle grinder?-img-6785.jpg   Cutting kitchen tile - use angle grinder?-img-6789.jpg   Cutting kitchen tile - use angle grinder?-img-6787.jpg
The Following 2 Users Say Thank You to GoodLJohnny For This Useful Post:
AustinDB (12-25-2017), Xtrememtnbiker (12-22-2017)
Roof Framer's Bible Framing A Bay Window Roof sbebuilders Framing 25 06-28-2015 09:28 PM
Setting floor and wall tile while still wet from cutting on the wet saw. lmahome Tiling 48 11-11-2013 12:45 AM
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 01:14 PM
Hardwood to Tile transition 239STAIRS Flooring 5 07-08-2012 07:16 PM
