Cutting Kerdi Shower Pan - Page 2 - Tiling - Contractor Talk
Old 05-22-2018, 07:12 AM   #21
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 5,284
Re: Cutting Kerdi Shower Pan
Originally Posted by tjbnwi View Post
The pan butts into the bench on mine in #14. Had the same issue the other Johnson is having. Direction of lap does not matter once waterproofed correctly.
Convince me to use kerdi board instead of kerdi membrane over drywall.
Big Johnson is offline
Old 05-22-2018, 07:39 AM   #22
tjbnwi's Avatar
Rewards Points: 5,402
Speed, cost, I’m old and lazy, I have carried an entire 5/8x10’ tall Kerdi board shower wall system up the outside porch of a 3 story home in one trip.
Easier to wet shim the Kerdi board than drywall.
When it comes to the bench, I have to look but I think I’m at $70. A sheet for 2x8x2 Kerdi board, I get the bench and the curb out of it normally. This cheaper than most of the benches alone. It you need to make a stem/pony wall Kerdi fix two sheets together, no studs needed. Easy to carve in a niche also.
If you’re going to use Kerdi over the drywall, spray the drywall with water from a pump sprayer. I lap the Kerdi 2” around corners, no banding needed in the corners.
Some will say that the patches and seams take to long and you have to mix mortar. There is a process to all the other systems so I consider it a wash. If you’re doing a flood test (as you should) what does it matter? It’s day lost any way you look at it.
I don’t band the pan to the walls, I cut the pan Kerdi, 4” larger each direction, fold at the 2” marks and set the liner, this takes care of the pan to wall seam. Kerdi band and corners for the rest of the install. For the washers/screws, you can run a band strip saving cutting time, the screws should be aligned on the studs (I hope...). Other option is wrap the band around your hand about 5 times, slide off have, cut at rolls that form as you flatten it, this will yield 10 pieces each time.
You’ll learn to deal with the build up, if you have to really thin the mortar for corners, do it, 2 4” taping knives are your friend, one to tuck and hold, one to strike.
tjbnwi is online now
The Following 4 Users Say Thank You to tjbnwi For This Useful Post:
Bedfordboy116 (05-23-2018), Big Johnson (05-22-2018), rblakes1 (05-22-2018), Xtrememtnbiker (05-22-2018)
Old 05-22-2018, 07:55 AM   #23
Speed, cost, Im old and lazy, I have carried an entire 5/8x10 tall Kerdi board shower wall system up the outside porch of a 3 story home in one trip.
So for new construction membrane and remodels use kerdi board.
Old 05-22-2018, 08:34 AM   #24
tjbnwi's Avatar
I dont tile new construction, as a matter of fact Im currently retired from tiling.
Kerdi board is all I would use, even new construction.
Old 05-22-2018, 08:37 AM   #25
tjbnwi's Avatar
Believe it or not, no national model code requires waterproofing shower/bathtub wall. Green board is still the only requirement in the code. (Unless youre in an area where the AHJ has amended the code)
Shower pans do require waterproofing.
Old 05-22-2018, 04:05 PM   #26
I ordered a 2x24.5x96 sheet. $65
Old 05-22-2018, 04:11 PM   #27
AustinDB's Avatar
Rewards Points: 876
I always cut the pan with the drain positioned correctly and even if the back is low by 1/4 (or more) build it up.
I only offer Kerdi-Board showers these days. Just set the walls in a large shower and the framing was poor. Shimmed the studs with strips of Ditra and theyre within a sixteenth.
For the bench, Ill build the frame out of 2x4s and cover with 1/2 KB on the face and 2 on the seat. I have built the seat up with 1/2 layers and bonded them with thinset. All depends on the situation. I dont fully build the seats out of KB because the Kerdi-Fix adhesive is ridiculously priced.
Finished the walls in this shower and 3 other showers (4x6, 3x5 and 4x5) in a day and a half including shaving and shimming studs for flat walls.
Now if we could use Kerdi-Fix at the seams of the walls and butt joints, that would be a real time saver.
AustinDB is offline
The Following User Says Thank You to AustinDB For This Useful Post:
Old 05-22-2018, 05:27 PM   #28
tjbnwi's Avatar
Originally Posted by AustinDB View Post
I always cut the pan with the drain positioned correctly and even if the back is low by 1/4” (or more) build it up.
I only offer Kerdi-Board showers these days. Just set the walls in a large shower and the framing was poor. Shimmed the studs with strips of Ditra and they’re within a sixteenth.
For the bench, I’ll build the frame out of 2x4’s and cover with 1/2” KB on the face and 2” on the seat. I have built the seat up with 1/2” layers and bonded them with thinset. All depends on the situation. I don’t fully build the seats out of KB because the Kerdi-Fix adhesive is ridiculously priced.
Try wet shimming, it is faster than drywall shims.
Just use thinset to Bond the Kerdi board together, no need for Kerdi Fix.
AustinDB (05-23-2018)
Old 05-22-2018, 08:21 PM   #29
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,222
By the time you hit all the screws and the corners you may as well have applied fabric to begin with imho. Really wanted to love Kerdiboard but I feel GoBoard is a little stiffer and easier to cut and cheaper and easier for me to get. Probably continue with my hybrid blend. I do love Schluter pans and drains.
overanalyze is offline
Old 05-23-2018, 06:05 AM   #30
Is this how you do it?
Old 05-23-2018, 06:12 AM   #31
[IMG]http://uploads.tapatalk-cdn.com/20180522/24e2e2b6d36323ed662992ee660c4687.jpg[/
[IMG]http://uploads.tapatalk-cdn.com/20180522/4e044c565ac4d8910e3fdb2328454955.jpg[
You can do that with Goboards According to their instructions.
https://hw.menardc.com/main/items/me...structions.pdf
Old 05-23-2018, 07:15 AM   #32
tjbnwi's Avatar
https://youtu.be/nebHq8N2i0Y
Where necessary. If it is just one or two studs that are bowed inward Ill use drywall shim.
Old 05-23-2018, 07:17 AM   #33
tjbnwi's Avatar
I don’t get the appeal of playing with the sealants. .
Big Johnson (05-23-2018)
Old 05-23-2018, 09:16 AM   #34
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 214
Dry pack to fill the gap, not thin set. Cover with Kerdi. Other option is fit in a cut off piece(s) from the pan, again cover the seam with Kerdi.
I cut mine with a track saw.
Make the bench and curb out of 2 Kerdi board. Cover with Kerdi as needed.
Make sure you protect the pan while you are kneeling on it, cut up the box, double/triple layers for protection
I second this.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
The Following User Says Thank You to TNTSERVICES For This Useful Post:
Old 05-30-2018, 06:56 AM   #35
Originally Posted by rblakes1 View Post
I didn't know they had changed them, mind posting a pic when you get it?
Sent from my SM-N910V using Tapatalk
Made out of 1/2. Ill leave it 38 wide and butt a 3 wide curb to the bench.
rblakes1 (05-30-2018)
Kerdi Shower Kit Drain Layout ? We Fix Houses Tiling 5 01-24-2018 12:41 AM
Weird Pressure change in shower when flushing toilet Morning Wood Plumbing 10 03-30-2016 08:16 AM
Alternative to Kerdi Shower kit AV656 Tiling 111 09-26-2012 02:14 PM
Barrier free shower Charles_cz Remodeling 62 09-18-2012 10:14 PM
Tub Shower Valve for shower only... Repairman615 Plumbing 6 05-30-2011 02:05 PM
