Cutting Kerdi Shower Pan - Tiling - Contractor Talk
Old 05-21-2018, 05:41 AM   #1
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 5,284
Anyone done it? I’m doing a 36”x70” shower so I ordered the 48”x72”. Schluter reccomends cutting all four sides evenly, if you can’t you can make up the difference in lower height at back wall and front curb (in my case) with thin set. Sounds hokey. Tips?
I’ve only done old school mud bed pans but these kerdi shower pans have gotten so cheap it seems to be the way to go, I think it was $135. A mud bed would be almost that much and I’d still need to buy a sheet of kerdi.
Big Johnson is offline
Old 05-21-2018, 07:11 AM   #2
rblakes1's Avatar
Rewards Points: 2,016
Re: Cutting Kerdi Shower Pan
How offset will your drain be? I have to trim most of the pans I install a little. Will the height difference at the curb really be that noticeable? Generally it's just 1 row with the sill on top, and not really a focal point of the shower.
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
Big Johnson (05-21-2018)
Old 05-21-2018, 07:26 AM   #3
Not the curb so much as the back wall.
Drain hole is centered on the kerdi pan
Not the place I bought it but this is the model.
https://www.warmyourfloor.com/kerdi-...y-48-x-72.html
Now I’m thinking if I buy the kerdi bench I could trim equal amount all around no problem.
Old 05-21-2018, 08:41 AM   #4
tjbnwi's Avatar
Rewards Points: 5,400
Dry pack to fill the gap, not thin set. Cover with Kerdi. Other option is fit in a cut off piece(s) from the pan, again cover the seam with Kerdi.
I cut mine with a track saw.
Make the bench and curb out of 2” Kerdi board. Cover with Kerdi as needed.
Make sure you protect the pan while you are kneeling on it, cut up the box, double/triple layers for protection
tjbnwi is online now
Big Johnson (05-21-2018), overanalyze (05-21-2018)
Old 05-21-2018, 11:03 AM   #5
KAP's Avatar
Trade: Custom
Rewards Points: 29,592
KAP is offline
Old 05-21-2018, 11:09 AM   #6
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,348
Could also buy an offset drain? Then front to back setting would not be critical. Benches are nice to have though, and the shower is big enough for one.
Peter_C is online now
The Following User Says Thank You to Peter_C For This Useful Post:
Old 05-21-2018, 07:25 PM   #7
Anyone use the new hollow benches? I just ordered one from my supplier, apparently the solid ones are getting phased out.
Old 05-21-2018, 07:29 PM   #8
Going to trim it to 35” x 59. That removes 6.5” off each side and 6.5 off each end. The bench will be 11.5 so shower will be 35”x70.5 with bench.
Old 05-21-2018, 07:31 PM   #9
The new benches are pre made with the 2” board. I bought a 38” that I’ll cut down to 35”. It was $205 from a local tile supply house.
Old 05-21-2018, 09:08 PM   #10
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 1,126
Everything Tom said except we use a razor knife and straight edge to cut the trays.
Xtrememtnbiker is offline
Old 05-21-2018, 09:20 PM   #11
tjbnwi's Avatar
Hacks...
Bedfordboy116 (05-23-2018)
Old 05-21-2018, 11:18 PM   #12
rblakes1's Avatar
I didn't know they had changed them, mind posting a pic when you get it?
rblakes1 is offline
Old 05-21-2018, 11:20 PM   #13
rblakes1's Avatar
I used to free hand with a circular saw, then switched to the snap blade knife, now I use my track saw just because I have one
rblakes1 is offline
The Following 2 Users Say Thank You to rblakes1 For This Useful Post:
A&E Exteriors (05-22-2018), Bedfordboy116 (05-23-2018)
Old 05-21-2018, 11:43 PM   #14
tjbnwi's Avatar
I make mine out of 2” Kerdi board.
Cutting Kerdi Shower Pan-c31d482b-dbe6-43e3-ab17-40ba822fcd28.jpeg   Cutting Kerdi Shower Pan-97dc5847-2074-49cc-9f8a-ddf9a57e1f42.jpeg
rblakes1 (05-21-2018)
Old 05-21-2018, 11:50 PM   #15
rblakes1's Avatar
Something new to try on the next one!
rblakes1 is offline
Old 05-22-2018, 12:53 AM   #16
Will do. I pick it up Thursday after work.
Old 05-22-2018, 05:12 AM   #17
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,634
Best practice is to install the entire shower first and then add the bench inside the shower like Tom did in #14. With that in mind your pan should be 70.5 or so.
Home Designer Series Software
B.Johnson is offline
Old 05-22-2018, 06:26 AM   #18
That’s not what the Schluter videos show.
I can’t tell one way or the other from Tom’s two photos.
rblakes1 (05-22-2018)
Old 05-22-2018, 06:41 AM   #19
rblakes1's Avatar
I've never heard of anyone installing the bench over the pan. That sounds like it would be a nightmare with the different pitches of the pan
rblakes1 is offline
Old 05-22-2018, 06:53 AM   #20
tjbnwi's Avatar
The pan butts into the bench on mine in #14. Had the same issue the other Johnson is having. Direction of lap does not matter once waterproofed correctly.
Kerdi Shower Kit Drain Layout ? We Fix Houses Tiling 5 01-24-2018 12:41 AM
Weird Pressure change in shower when flushing toilet Morning Wood Plumbing 10 03-30-2016 08:16 AM
Alternative to Kerdi Shower kit AV656 Tiling 111 09-26-2012 02:14 PM
Barrier free shower Charles_cz Remodeling 62 09-18-2012 10:14 PM
Tub Shower Valve for shower only... Repairman615 Plumbing 6 05-30-2011 02:05 PM
