Trade: Hardwood flooring contractor
Cracked Tile
So im helping my neighbor he cracked a porcelain tile. I used a grinder to cut and X in the tile..well my problem is i cut too deep and we had to remove the durarock too. Now it's just plywood. So im going to screw down a seperate piece of durarock (12 inchx 12 inch) to the plywood sub and then thinset the porcelain to the durarock.. is this acceptable. My concern is that the durarock is now independent fromt the rest of the mortar board..Am i missing any step.. I basically don't want the grout to crack. What do i know i refinish hardwood floors??
Chris Frate Pasquale Floors |
Trade: General Contractor, Remodeler
Re: Cracked Tile
Might be good to have thinset under the durock too, thats a pretty small piece of backer.... I wouldn't give your neighbor any kind of guaranty on this... Any idea why the tile cracked in the first place? Could you tell how well the durock was installed in the first place? How many fasteners did you pull? Just curious I guess...
Re: Cracked Tile
Sure... they dropped a pan on the tile. There were only 4 screws on the 12x12 tile. There also was no thinset sandwiching the plywood to the durarock.
Re: Cracked Tile
Might not have cracked if the durock was mortared down like its supposed to be... the thinset eliminates hollow spots under the backer. Sometimes the screws will actually lift the backer off the subfloor, and it'll "float". Probably best to fix it as good as possible, and hope for the best... modified grout will help some too, but it might crack later.
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Cracked Tile
Personally, I don't see the big deal here. Slap some thinset on the sub floor, slap a piece of tile underlayment down, screw it down, back butter some thinset on the tile and stick the tile in place. Grout and be done. This is really nothing to be worried about.
If this tile is going to give him problems later it would mean that the entire floor has issues because of the original installation and of course then this tile is the least of the problems. |
Re: Cracked Tile
That's what i did. And that's what i wanted to hear. Just double checkin'.
| quarry tile to quarry tile | rservices | Flooring | 8 | 01-15-2010 12:37 AM |
| Learning to install Floor and Wall Tile!! | TurnkeyConst | Flooring | 25 | 01-17-2008 08:01 PM |
| odd bullnose tile | mdshunk | Ceramic & Stone Tile | 25 | 09-18-2006 11:25 PM |
| Got some design ideas for tile wainscoting? | Mike Finley | Ceramic & Stone Tile | 2 | 05-09-2006 10:05 AM |
| Cutting Existing Tile. | kpikul | Remodeling | 16 | 02-05-2006 12:30 AM |
