Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 466
Concrete Floor Tile
Any of you ceramic tile applicators or flooring guys ever used a concrete floor tile? If so, what are your thoughts on them? What brand have you used? And, did you use in an interior or exterior application? Thanks
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Rewards Points: 96
Re: Concrete Floor Tile
I don't know about concrete floor tile but I did install a concrete 4x4 wall tile from Israel. The tile had a rough surface. It really sucked the water out of the thinset and grout quickly.
Advertisement |
Rewards Points: 466
I can see that happening. You used thinset on the walls?
Tile Contractor
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Why wouldn't you use thinset on walls?
Greg ![]() |
Rewards Points: 96
I did this job about 15 years ago. Never had another concrete tile since. It was installed as a backsplash for a pantry countertop and had no water issues. I remember the tile being quite heavy so I chose thinset to be sure it would hold/last.
The tile surface was like beach sand cast into the concrete then glazed. It tore up my grout sponges pretty good. How did you come across a concrete tile for this job? Where is it made? |
Rewards Points: 466
I don't know. I thought on the walls, mastic was to be used. I guess I am thinking of drywall surfaces. I can see using thinset on cement board or other masonry surface. And when you speak of thinset, I think of cement based product.
Tile Contractor
Rewards Points: 886
You wouldn't want to use mastic in a wet location, no matter what the substrate. You also don't want to use mastic on anything larger than an 8x8 tile, though I think some mastics supposedly allow for a 12x12.
Greg ![]() |
Trade: DIYer apparently
Rewards Points: 1,000
MASTIC>>>>>>>>>>>>> urgh thats a bad choice very bad.. thinset is cheaper and better in the long run period
Rewards Points: 466
Wow. Not being a tile man myself, I had no idea mastic had such a bad reputation. I do know around here, at least in the residential areas, almost all these guys use mastic on the walls, wet (showers & tubs) or not, and thinset on the floors.
The origin of my op was interest in feedback on concrete tile use. I have looked at a couple of sites that make the stuff: http://granadatile.com/ http://www.sonomatilemakers.com/ I was actually thinking about making some myself. |
use laticrete MVS thinset with that stuff
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Concrete Company delivered junk concrete. How best to pursue? | marcomjl | Concrete & Paving | 47 | 06-03-2014 10:17 PM |
Cement backer board over concrete slab | gtimk4 | Flooring | 14 | 12-21-2010 08:46 AM |
Concrete slab prep, level and tile | Tkelly | Tiling | 2 | 11-20-2010 11:27 PM |
Concrete with Fly Ash vs. Concrete without? | cdkyle | Concrete & Paving | 19 | 07-28-2010 09:57 PM |
4x4 posts in concrete vs. saddles | Strongarm | Decks & Fencing | 20 | 08-31-2009 09:41 PM |
Go to Page... |
