Concrete Backer Over 1/2 Inch Subfloor
Does anyone know if it is possible to install 1/2 inch concrete backer board over 1/2 inch plywood subfloor or should I use another layer of 1/2 inch plywood .
Mod / ArchiBuilder
Re: Concrete Backer Over 1/2 Inch Subfloor
When it comes to underlayment for tile, you always want to go bigger.
Personally, I would go another layer of 1/2". What size joists do you have?
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens Last edited by Cole; 08-01-2007 at 10:07 PM. |
Builder/Remodeler
1/2" ply will give way too much deflection...Your assumption is right on...Add another layer of 1/2", then the cement board.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Single sheet subfloor have to be at least 5/8" thick if the joists are 16" o.c. or less. Even this is crap, but it does meet minimum standards, for those that will accept the very minimum.
Make sure you off-set the second layer of plywood from the first, and lots of 1 1/4' screws.Jaz |
Trade: Renovations
This post is meaningless, and the answers even more so, unless you provide more information.
What are you going to put down? Tile or stone? What are the joists? What are the dimensions of the joists? What is the span of the joists? What is the joist spacing? There are two issues that are critical for tile/stone: joist deflection and underlayment deflection between the joists. Without an understanding of all of the above questions you cannot decide whether or not your floor will support adequately for tile or stone. Be aware that concrete backer board adds nothing in terms of support, it is there to separate the tile from the wood with their different thermal/moisture expansions. 1/2" subfloor, I wouldn't use less than 5/8" over that, then thinset then cbu, thinset and tile. For stone you'll need more.
| Fiber Optics in concrete countertops | 6stringmason | Concrete & Paving | 17 | 03-16-2011 05:49 PM |
| Staining concrete | ryan.s | Masonry | 12 | 03-05-2009 03:54 PM |
| Concrete home | denick | Concrete & Paving | 5 | 03-06-2007 04:32 PM |
| Main beam sagging 1/2 inch? | AllGoNoShow | Construction | 10 | 10-12-2006 08:20 PM |
