Trade: diy
Cleanup After Tile Job Is Done
I just finished my first tile job, and after the grout was dry (next day) I notice a shiny glaze on the tile, and grout ( did not notice this glaze when it was wet). It's not all over the tile or grout just bit's a pieces, and you can't even see this shiny glaze until you look at it just right.
I purchased Opticolor stain-free grout from one of the big box stores. I followed the instructions that came with the product, but i guess i didn't quite do good enough job. This Opticolor stuff is made of three parts a resin, liquid hardner, and a color sand stuff. Any clues on how to get rid of the shiny glaze. I was thinking about trying to scape this stuff off with a metal putty knife in the corner of the closetbut I'm afraid that might ruin the tile. |
Tile Contractor
Re: Cleanup After Tile Job Is Done
Probably going to need a stripper by now. This may not be the place to get the information. Call the manufacturer.
Trade: Home Improvement/Remodeling
This is my first post here. I just found this place tonight while looking for a new floor stapler.
bqtchef, I just finished a bathroom tile job and used that very same grout system. Exactly the same result the day after. I came back to clean up the inevitable haze and found just what you describe. I cleaned it up with a mild solution of water and white vinegar (approx. 1/4 cup to 1 gal. of water) and a plastic scrub pad with the sponge inside (I can't recall the brand, but it was specifically designed for use on porcelain or ceramic). Used light to moderate pressure in a circular scrubbing motion and it worked like a charm. I then sponged it off like a normal haze job and it looks beautiful! No scratches either.
Tile Setter
Trade: Ceramic Tile, Marble, & Stone
Your Opticolor epoxy grout is made by Mapei, yeah? They also make a product called "Epoxy Grout Haze Remover".
The following link will give you the names of other products to try also... http://www.laticrete.com/portals/0/tds/TDS198.pdf Hope this helps! - Bob
Classic Tileworks http://www.classictileworks.com Ohio Tile and Stone Installation Contractor in the Akron area serving Summit, Portage, Medina, Stark, & Cuyahoga counties in Northeast Ohio |
| Time for a new tile guy? | orson | Ceramic & Stone Tile | 20 | 12-11-2008 08:38 PM |
| information on fixing a bad tile job | bford | General Discussion | 4 | 09-30-2008 07:44 AM |
| need input on tile job | bford | Introductions | 1 | 09-24-2008 11:28 AM |
| Learning to install Floor and Wall Tile!! | TurnkeyConst | Flooring | 25 | 01-17-2008 08:01 PM |
| Cutting Existing Tile. | kpikul | Remodeling | 16 | 02-05-2006 12:30 AM |
