Choosing Trowel Size Depending On The Tile Size
Old 07-03-2011, 02:54 PM   #1
astor's Avatar
Trade: FI
Rewards Points: 704
Question
I have a upcoming project with 16*24 Turkish travertine stones for 6000 sf. floors and 18*18 same stone for shower walls.
New home, all flat and will be using Whisper Mat crack isolation membrane over subfloor. Noble TS for handicapped style showers.Tuscan leveling system w 1/8" grout lines.
I have seen discussions about trowel size and shapes (square and U-shape)
Will back butter all.
Am I safe going with 1/2*1/2*1/2 trowel size? Square or U-shape?
Thanks guys.
Sam
astor is offline
Old 07-03-2011, 07:44 PM   #2
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Choosing Trowel Size Depending On The Tile Size
Anything 18" and over we have been using 3/4" u notch on floors.
If your walls are that flat you could maybe use that 1/2".
Yes butter everything.
CrpntrFrk is offline
The Following User Says Thank You to CrpntrFrk For This Useful Post:
astor (07-04-2011)
Old 07-03-2011, 09:37 PM   #3
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Depends on how flat the substrate is, how well gauged the tile is, and how much coverage you are getting.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following User Says Thank You to PrecisionFloors For This Useful Post:
astor (07-04-2011)
Old 07-04-2011, 01:39 AM   #4
Aaron Tritt's Avatar
Trade: Tile Installation
Rewards Points: 150
I would start with the 1/2x1/2x1/2. Pick up tiles and check your coverage. Should be 80% for the dry areas and 95% for the wet.
Have fun!!
I wouldn't mind doing 6000 ft of stone...
Aaron Tritt
Custom Expressions LLC
Insured, NTCA Member, BBB accredited
Aaron Tritt is offline
The Following User Says Thank You to Aaron Tritt For This Useful Post:
astor (07-04-2011)
Old 07-04-2011, 05:26 AM   #5
bazemk1979's Avatar
Trade: pro
Rewards Points: 77
I have done 24x24 with 1/2" 1/8" grout joint,prepped the floor real good and had no problems while working with the level next to me at all times to make sure all is flat and where the concrette variates.
BUT!!!! I would of rather done the job with 3/4" trowel for sure,anything from 20x20 and up tile use 3/4" trowel!!!!!!!!!! work is much easier like that.
bazemk1979 is offline
The Following User Says Thank You to bazemk1979 For This Useful Post:
astor (07-04-2011)
Old 07-04-2011, 01:23 PM   #6
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
I'd use 3/4" x 9/16" x 3/8"
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
astor (07-04-2011)
Blasting Pool Tile sa1245 Sandblasting 5 06-29-2015 08:56 PM
Laying new tile on top of existing tile?? Bergmeister Tiling 10 05-17-2011 09:02 PM
Porcelain Tile Specifications AustinReDevelop Tiling 4 01-13-2011 10:10 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 07:01 PM
