Chiseled Edge Grouting
Old 11-18-2012, 10:04 AM   #1
Ash@OTL's Avatar
Trade: remodeling/ home repair
Rewards Points: 160
I just laid 750 sq. ft. of limestone with a chiseled edge. I grouted yesterday. In the past Ive always grouted flush with the top of the tile and wiped slightly below tile edge. This particular customer wanted the grout recessed so thats what I did. In some places 1/8 to 3/16. Now he wants all the chisels completely grout free.
Im going tomorrow with a dremel and grout cleaning bit to clean it up. I guess my question is, is there a standard way to grout these types of tile or is it customers choice? Any constructive input is appreciated.
chiseled edge grouting-forumrunner_20121118_110321.jpg   chiseled edge grouting-forumrunner_20121118_110359.jpg
Ash@OTL is offline
Old 11-18-2012, 10:24 AM   #2
GO Remodeling's Avatar
Rewards Points: 96
Re: Chiseled Edge Grouting
That's a bite. Chisel edge I usually cut down the grout joint with the sponge so it's recessed a little. But some grout will caught up in the edge. Most of it will eventually wear off or can be scrape rather easily because the grout isn't gonna stick well to the fired tile. It just doesn't have anything to really grip to.
A paint stick, small metal or plastic putty knife would probably be enough to dig it out or even a good scrubbing with the white scrubby sponge. A light acid wash like vinegar in the water might help too.
GO Remodeling is offline
Old 11-18-2012, 11:20 AM   #3
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Sounds like a CHANGE ORDER needs to be written
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
The Following User Says Thank You to charimon For This Useful Post:
Jaws (11-18-2012)
Old 11-18-2012, 11:52 AM   #4
astor's Avatar
Trade: FI
Rewards Points: 704
I would try wire brush in a corner first-either dremel or drill or even manual brush, since the grout is still not cured hard.need to be gentle on limestone...good luck..
astor is offline
Old 11-18-2012, 01:22 PM   #5
Ash@OTL's Avatar
Rewards Points: 160
Thanks for the suggestions. Light acid wash and small wire brush will most definitely handle the job. I still have a large porch to do with the same tile. I think I will grout it with a bag and just strike the joints. Has anyone ever tried this method before?
Ash@OTL is offline
Old 11-18-2012, 01:33 PM   #6
Rewards Points: 96
Over looked the limestone. Acid and limestone don't play well together so don't use very much 1/4 cup/gallon or don't use it at all.
Old 11-18-2012, 01:36 PM   #7
Ash@OTL's Avatar
Rewards Points: 160
Thanks, Im almost positive that I can remove it with a brush and some elbow grease. Does the acid stain or discolor the limestone?
Ash@OTL is offline
Old 11-18-2012, 05:33 PM   #8
astor's Avatar
Trade: FI
Rewards Points: 704
You can use fiillable caulking tubes like these available 24 packs
astor is offline
The Following 2 Users Say Thank You to astor For This Useful Post:
Ash@OTL (11-18-2012), sycamorebob (11-18-2012)
Old 11-18-2012, 09:01 PM   #9
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,338
Well I say f' em, the floor looks rad.
Metro M & L is offline
Old 11-18-2012, 09:06 PM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,458
Damn that sucks...pics look good. I'm no pro but if someone asked me to do it without any in the groves I'd tape it off.
Inner10 is online now
Old 11-18-2012, 09:07 PM   #11
Ash@OTL's Avatar
Rewards Points: 160
Thanks . It was a fun floor to lay. The guy is happy with the floor and doesnt mind paying to have the "excess" grout removed. He is a great customer but very particular.
Ash@OTL is offline
Old 11-24-2012, 10:33 AM   #12
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
If he wants the chisels "grout free", just tell him you didn't charge him for the grout inna chisels inna first place.
Greg
HS345 is offline
Old 11-24-2012, 11:57 AM   #13
Livestock Makup Artist
RiverMan's Avatar
Trade: Putting Lipstick on pigs and fixing old places up
Rewards Points: 75
I've used a grout bag for limestone floors before and had really good luck with it. I went out looking for the caulk tubes that Astor mentioned but could not find them in town so I went for the grout bag. Helps if you have some practice with the bag but once you've got control over the tool it works like a charm.
Good luck and keep them edges clean.
RiverMan is offline
Old 11-24-2012, 12:50 PM   #14
Ash@OTL's Avatar
Rewards Points: 160
Thanks. Im definitely going to use a bag on the porch. I used a stiff bristle wire brush and a damp sponge on the chisels and they cleaned up great.
Ash@OTL is offline
Old 11-24-2012, 05:27 PM   #15
Inner10's Avatar
Grout bag is pretty hard to squeeze after a few feet, I tired to use one and ended up putting it in the garbage grout and all. Buy a bulk gun.
Old 11-25-2012, 11:25 AM   #16
astor's Avatar
Trade: FI
Rewards Points: 704
I can not handle the bag,gets my hands sore..
Tubes are available online, did not see at hardware stores around here.
"34 bucks+ shipment for 24 tubes" is not a bad deal..for continuous use usually one tube is enough..
The link is still above the pic, but here is a snap shot:
astor is offline
Old 11-25-2012, 04:15 PM   #17
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Just an FYI guys - you can make your own "fill-able" caulk tube... Just use an air compressor and some common sense A quick hit with the blower will pop the pusher cap right out of a used tube. Clean it out with the hose and re-pack it with your flavor of choice and pop the cap back in and your in business. I bet you all have at least a tube or three nearly empty tubes of alex plus in the truck right now
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following 4 Users Say Thank You to PrecisionFloors For This Useful Post:
astor (11-25-2012), sycamorebob (11-25-2012), the rock (12-10-2012)
Old 12-10-2012, 04:07 AM   #18
DO IT RIGHT
the rock's Avatar
Trade: hard surface/carpentry/plumbing/electrical
Rewards Points: 75
Mr Ash NEVER use an acid based solution on natural stone products.
the rock is offline
Old 12-10-2012, 07:54 PM   #19
Ash@OTL's Avatar
Rewards Points: 160
I didnt. I used a stiff bristle wire brush and sponge. Worked fine. I used a grout bag for the porch. Cant really tell the difference in the two but the customer is pleased.
Ash@OTL is offline
Old 12-10-2012, 07:55 PM   #20
Ash@OTL's Avatar
Rewards Points: 160
Ash@OTL is offline
Made in USA product list J.C. General Discussion 360 06-16-2018 04:52 PM
480sparky goes Over The Edge 480sparky Off Topic (Non Trade) 22 09-21-2012 07:17 AM
Brick sidewalk edge restraints red_cedar Masonry 16 07-18-2012 06:28 PM
Edge Tape KennMacMoragh Painting & Finish Work 9 04-23-2010 05:34 PM
