Trade: Home Remodeling
Ceramic Tile On Top Of Fiberglass Pan?
I have a walk in shower that has a fiberglass pan which has several cracks in it. I was considering laying down a thin layer of mortar then applying a ceramic tile floor on top of that. Is this something that can be done successfully? What do I need to do to ensure the motar will adhere to the fiberglass? My main goal is to not have to rip out the existing fiberglass pan.
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Ceramic Tile On Top Of Fiberglass Pan?
No.
Ceramic tile with grout joints is not 100% waterproof. You still have to address those cracks to assure a leak free installation. You also have to figure out the drain set-up. The existing might work, but this sounds like a risky deal, even if you can get the tile to stick to fiberglass. Regular tile mastic would probably work for that. I would clean the fiberglass thoroughly before installing tile and then let the tile sit for at least a few days before grouting....if I were to attempt this.....which I probably wouldn't. I would, however, try to sell the customer on replacing the pan with another fiberglass one (because it sounds like they dont want to spend money for a good tile shower.
Re: Ceramic Tile On Top Of Fiberglass Pan? |
Trade: Renovations
tiling once, tiling twice....
thanks for the advise guys, you're right the customer doesn't want to pay to have the old pan removed and replaced. I was trying to accomodate but if it shouldn't be done I won't do it. They'll probably find some other contractor who will though.
Chief Toilet Mover
Give em a can of bondo and some sand paper and a can of white glossy spray paint.
tile mason
give them some information
they have cracks in their fiberglass pan they have leaks if they want them fixed, this is what they have to do if they don't want to replace pan, or build a mud pan and tile then they don't want to fix the problem just explain leaks on drywall ceiling and rots in subfloor
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
#9 | |
Trade: Tile installations
Re: Ceramic Tile On Top Of Fiberglass Pan?Quote:
Doer of Many Things!!!
Trade: Paint and Floor Covering Retailer
You may want to take a look at a product called Tavy Thin Skin. We've only used it once on a Formica countertop to tile over it. The stuff is suppose to allow you to tile over almost anything, including fiberglass. I'm not sure how it would work in an extreme moisture area like a shower pan though.
#11 | |
Chief Toilet Mover
My biggest issue with the whole thing is simply the flex in all shower receptors. That flex barring all other issues is reason enough to stop right there and realize tile isn't an option.
#13 | |
Carpenter/fencing
Learning without thought is labor lost; thought without learning is perilous. |
In my experience, fiberglass stalls are barely installed. That's why they are there, cheap. I've seen them with 1,2, or 3 goobs of mortar under them, sounds like you have a one goober.
Tile? No way!
You need to tell that customer how much damage water can do getting under that pan. Replacing that pan is short money at this point. Compared to replacing sub floor or possible floor joists. Personally when it comes to a shower floor i think old school mud job is the way to go. Sames goes for hanging tile in a shower old school mud job on the walls. This way you can make them perfectly flat. But nobody really does that anymore. Except i have a friend who found old school tile guy to remodel his shower. He did old school mud job on walls then went with beautiful carrera marble on the walls. It is sharp. You have to install wire mesh on the walls to hold the mud. But like i said those walls with be TRUE BEFORE TILE.
Tavy was just a thought. We haven't used it enough to know all it can and can't do. Just what they "CLAIM" it can do.
There are much better products to use as membranes than Tavy's thin skin, his spacers are fine though.
#18 |
I went and found the box of Tavy we have at the store yesterday. Looks like construction paper to me. I had no idea it was that sort of product. I can't think what we would have used it for.
| Glue on the ceramic tile floor | Work is good | Flooring | 3 | 07-31-2007 11:40 PM |
| ceramic tile vs quarry tile labor | t336 | Flooring | 2 | 07-18-2007 08:00 PM |
| Ceramic Floor tile grouting | John Walls | Flooring | 9 | 05-18-2007 07:42 AM |
| ceramic tile | pre-reno | Flooring | 10 | 02-04-2007 04:15 PM |
| ceramic tile over tile? | Grumpy | Remodeling | 19 | 09-10-2006 07:34 AM |
