Trade: masonry
Ceramic Tile Floor Tile Over Control Joint ?
Hey pro tile guys,I have done a lot of tile work in the past so I'm not a greenhorn.Now I have a tech. question,I will be crossing a control joint in the concrete floor in this wine cellar.I am using 2x2 ceramic that the HO bought @ $58.00 each(ouch).I know I need to prevent the cj from moving prior to setting tile.What do you pros use?THX MM
Trade: masonry
Re: Ceramic Tile Floor Tile Over Control Joint ?
Tile Pros must be busy today
Knowledge Factory
Expansion and control joints need to be honored into the tiles. The TCA manuals cover this in depth.
#4 | |
Tile Contractor
Re: Ceramic Tile Floor Tile Over Control Joint ?Quote:
![]() HONOR THY JOINTS I know I know I know, think what you will.
Trade: masonry
Correct me if I'm wrong but I am under the assumtion that there is a product out there(some sort of tape material) that spans the sawed cj to prevent movement and thus cracked tile.Let me have it I got broad shoulders.
Trade: masonry
Bill you out there?
Tile Contractor
Bill Vincent you tile industry genius you, you are being paged, so......
C'MON DOWN!!! |
Tile Contractor
While we are waiting on Bill, let's go to a commercial.
Trade: masonry
Hey Bud what are you chopped liver?Come on let me have it.Is there or is there not a product that spans a sawed cj?
The idea of a control joint is
yo control where the cracking will occur. All you can do if you lay over it is move the crack in your tile a bit.
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
This is a confusing issue for even most pros. Some membranes help bridge while others don't.
Go to the Noble Company's site and consider CIS http://www.noblecompany.com/Products...8/Default.aspx Jaz |
#12 | |
Trade: masonry
Knowledge Factory
Read Noble's requirements...
Must honor expansion and control joints. Schluter has a metal expansion channel if you wish.
honor as in? i just read through and it looks like you just have to provide 'expansion joints' as well, maybe with color match caulk? thats the first thing that came to mind
#15 | |
Restoration Crazy
I've seen tile guys use these "tricks" in the past that allow them to go over the joint. Seems we always went back a year later to fix cracked tiles. The last few projects I ran, I was sure to not let it happen again. It just doesn't work.
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
tile contractor
Control joints can be bridged and moved to a grout joint, although it's better to try and lay the tile out to the joint if possible. It's expansion joints that must be honored thru the tile.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
tile contractor
Hey Bud-- Jealousy can be SUCH an ugly thing!!
#18 |
Tile Contractor
Yow I know!
#19 |
Tile & Marble Contractor
Trade: Tampa Tile Contractor
-Brian- Brandon Lutz Bradenton Tampa Oldsmar Westchase New Port Richey Seminole St. Pete Wesley Chapel Sarasota website: www.ceramictec.com |
| How do i shine my ceramic tile? | MIbeachbuilder | Ceramic & Stone Tile | 14 | 02-28-2008 07:23 AM |
| flooded ceramic tile floor on concrete | bmorrisey | Ceramic & Stone Tile | 2 | 12-06-2007 09:35 PM |
| ceramic tile vs quarry tile labor | t336 | Flooring | 2 | 07-18-2007 08:00 PM |
| Solution for VCT cracking @ control joint | puzzledlog | Flooring | 2 | 05-16-2007 08:48 PM |
| ceramic tile | pre-reno | Flooring | 10 | 02-04-2007 04:15 PM |
