Ceramic Over Laminate - Tiling - Contractor Talk
Old 11-01-2010, 08:41 AM   #1
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
I have to put in a ceramic backsplash where there is laminate already installed. The laminate is well adheared to the wall and will be difficult to remove without destroying the wall.
Is it possible to go over the laminate with tile and what should I use for mastic?
bert0168 is offline
Old 11-01-2010, 09:02 AM   #2
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Re: Ceramic Over Laminate
There is one thin set out there that installs just about anything to anything....
Mapei's Grani Rapid.
Not sure if I understand your post but If the Laminate is sound, strong, flat, level and all those good things you might try and apply a scratch coat of Stucco mesh and Grani Rapid.
I would think this give you a good base to work off.
I might also look at Laticrete's 254 or 254R for the same purpose. Watch your tools these products dry hard and are hard to remove from your hands, clothes and tools...
Post a picture so we can see first hand - in case I'm way off base...
JW
JohnFRWhipple is offline
Old 11-01-2010, 09:25 AM   #3
Money Changer
bert0168's Avatar
Thx John, I'm on site now removing the tops. I have picts on my phone and will post when I get back into the office.
I think you undertstand it. The laminate goes up beind the uppers and behind the old tops.
I had to remove some for additional electrical and it was a bear to remove.
I would rather not have to lath it for stucco scratch, too thick and not in the budget. I'd like a product I can trowel but will bond to the lam. It is sound and flat.
bert0168 is offline
Old 11-01-2010, 10:31 AM   #4
Anti-wingnut's Avatar
Rewards Points: 3,316
Laminate is specifically made to be difficult for materials to bond to, whether it is grape juice, gravy, mastic, or thin set. A long lasting connection may be unlikely using the materials you wish
Anti-wingnut is offline
Old 11-01-2010, 10:43 AM   #5
This is a good point. I have had lots of luck with Grani sticking to anything. Perhaps you should put a cup wheel on the grinder with a metal bristles and rough up the surface some...
I like the stucco mesh (I use the plastic drywall mesh tape kind 3' roll x 100') - in a pinch we use Bug Screen mesh as a go to back up.
With a rough surface and some mesh you should have a good backer...
JW
The Following User Says Thank You to JohnFRWhipple For This Useful Post:
Frankwhoa (11-05-2010)
Old 11-01-2010, 12:58 PM   #6
Money Changer
bert0168's Avatar
JW
John, where do you get mesh this wide and how do you fasten it? I assume mechanically but what do you use that lays flat enough?
bert0168 is offline
Old 11-01-2010, 06:14 PM   #7
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Don't get all carried away. It's a backsplash.
Sander with 120 grit, quality nodified thinset like Mapei Ultraflex 2 and install.
But don't get too technical. No one walks on a backsplash, there's no wet location issues......
It's not that big of a deal.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
bert0168 (11-01-2010), PrecisionFloors (11-01-2010)
Old 11-01-2010, 06:28 PM   #8
Sander with 120 grit, quality nodified thinset like Mapei Ultraflex 2 and install. .......
There you have the answer from a Pro
Except the bugs, spiders and roaches
Old 11-01-2010, 06:31 PM   #9
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Funny guy
Angus
angus242 is offline
Old 11-01-2010, 06:48 PM   #10
Renaissance Man
superseal's Avatar
Rewards Points: 5,474
Been up this road with good success - Use a quality mod thin-set and scarify surface - sticks like molasses and no call backs.
superseal is offline
Old 11-01-2010, 07:11 PM   #11
Money Changer
bert0168's Avatar
Good to know I can go 120. I was ready to go 60.
(and I'll skip the mesh)
Good advice from all as usual
bert0168 is offline
Old 11-04-2010, 11:51 AM   #12
mr marble's Avatar
Trade: marble and granite setter
Rewards Points: 25
Staple wire mesh over it and coat it with thinset there is no promise that just mastic will adhere, it's not a floor so pressure cracking is not a issue , as for the stucco mesh not a good idea it has it's own glue on the mesh but will it stick? I don't know the answer to that and have never done it and never will, I stick to the things that apply to this applacation , so there it is sports fans !, wire all the way, lol I just wanted to sound fancy , but quarter inch drywall and screw it rite over top of laminate , it's the quickest, and you ready to go my friend, there are many ways to do it this is the cleanest and quickest and cheapest way to get tile on the wall with the proper adhesion, and a clean setting surface,it's not rocket science, just common sense, the less layers you have the better, and I know screwd drywall works !!!! You could even put some pl 2000 on there with screws just for added strength...........
mr marble is offline
Applying Poly over Laminate floor etbrown4 Flooring 15 10-28-2009 09:54 PM
Floors by Joe - Carpet, Laminate, Title, Ceramic, Vinyl, VCT FloorsbyJoe Help Wanted or Looking For Work 0 05-09-2009 05:23 AM
best blade for cutting laminate platinumLLC Flooring 12 05-07-2009 10:12 PM
What to charge to pull up 325sqf of Laminate flooring?? TileMan77 Flooring 3 07-17-2008 07:57 PM
