Cement Board Prep For Tile
Old 09-07-2015, 01:35 AM   #1
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 853
Does anyone have a video link or FYI list for cement board prepping for tile. I've installed the cement board on the walls and tile niches. I siliconed the joints of the cement board in the niches. So whats next. I've seen some videos but seems the steps are not similar and parts are not explained why they did certain things or not. I can't seem to find anything on the niche application and cement board.
Do I just mesh tape the joints with thin set. What do I do about the inside corners of the niche's. I use hydroban quite a bit but usually only applied on diamond board for prep before tiling.
Whats the purpose of the mesh tape. I'm curious
Why not just hydroban the joints and corners.
Do I do anything with the open faces of the tile niche edges on the 90's.
Thanks for the help
gowings is online now
Old 09-07-2015, 02:12 AM   #2
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Send a message via Yahoo to charimon
Re: Cement Board Prep For Tile
watch Sal
he has a great you tube channel, and a couple hours wathcing him will be of great help.
https://www.youtube.com/user/saldibs
I am not trying to be cheesy or corny but Sal is a fellow Tile Geek who has a gift for video.
https://www.youtube.com/watch?v=j6C1Djy0ZE8
charimon is offline
The Following 2 Users Say Thank You to charimon For This Useful Post:
Creter (09-07-2015), We Fix Houses (09-07-2015)
Old 09-07-2015, 02:30 AM   #3
gowings's Avatar
Rewards Points: 853
Thanks I've watched Sal. But no info on tile niche prep with cement board. At least I didn't see anything on the subject.
Old 09-07-2015, 08:49 AM   #4
Robinsonfam1's Avatar
Trade: Residential construction remodeling
Rewards Points: 168
i would dig out the silicone as much as you can. then mesh tape and thin set all corners inside and out. then hydro ban.
be sure to use alkalai resistant mesh tape made for concrete board, not drywall mesh.
the purpose of the mesh is to create a bond between the boards for one continuous plane. creates a stronger and more sealed enclosure.
yes i would waterproof the whole shower. water will still wick through the grout. it will be much better and longer lasting job.
ive never used hydro ban so i cant comment too much on it. i'm more mapei and red-gard user based on availability around me.
same with the diamond board you are referring to....if it is certainteed diamond back then go to their website and you will find a complete installation guide.
Robinsonfam1 is offline
The Following User Says Thank You to Robinsonfam1 For This Useful Post:
superseal (09-07-2015)
Old 09-07-2015, 09:55 AM   #5
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Long time ago I saw an article in fine home building where some chick was stuffing ice and water shield into a niche. She was working pretty hard at it, so she had great determination in protecting that niche from water penetration.
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 09-07-2015, 11:00 AM   #6
gowings's Avatar
Rewards Points: 853
[QUOTE=Robinsonfam1;3502825]i would dig out the silicone as much as you can. then mesh tape and thin set all corners inside and out. then hydro ban.
The silicone was beaded on the plywood joints before the cement board was installed over top.
Old 09-07-2015, 12:03 PM   #7
avenge's Avatar
Rewards Points: 2,610
[QUOTEThe silicone was beaded on the plywood joints before the cement board was installed over top.
Guess it doesn't hurt but you want to seal the cement board from water penetration before it can get behind it not after. And why plywood?
avenge is online now
Old 09-07-2015, 12:19 PM   #8
AGullion's Avatar
Rewards Points: 1,422
First rule on cement board is avoid it. You really can't seal the lower edges, and water will wick up into it . Topical membranes can hold water in or out , so be careful .
AGullion is offline
Old 09-07-2015, 12:28 PM   #9
AGullion's Avatar
This is not going to go over very well, but topical membranes , no matter how good they are, don't belong in a traditionally constructed shower. It's not designed for it . if you can get it , use a non porous tile board instead
AGullion is offline
Old 09-07-2015, 12:29 PM   #10
CarpenterSFO's Avatar
Rewards Points: 2,044
Tape and thinset every seam and joint, then cover with membrane - either sheet (Kerdi) or liquid (Hydroban). The purpose of the tape is to provide strength and stiffness and to make a stable scaffold to tool a surface at the joints - flat and 90s, inside and out - for adhering your membrane.
I've never heard of silicone on the CB or ply, but it shouldn't be a problem - it will be hidden behind the membrane anyway.
Why not just hydroban the corners? Hydroban is a membrane, not a gap filler, and it won't add any strength to the joints.
Mesh and thinset every seam and corner, then membrane, per manufacturer's instructions.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
charimon (09-07-2015)
Old 09-07-2015, 12:31 PM   #11
What do you mean by "topical" membrane?
- Bob
Old 09-07-2015, 12:33 PM   #12
AGullion's Avatar
Anything you put over the board , at some point has to stop. The same weep holes that let water out, let water in . it looks impressive to use those products, but water will get behind it from the pan system . it's the biggest misconception in wet area tile work today
AGullion is offline
Old 09-07-2015, 12:34 PM   #13
AGullion's Avatar
You can do it with a schluter drain, but you better not have a pin hole .
AGullion is offline
Old 09-07-2015, 12:36 PM   #14
gowings's Avatar
Rewards Points: 853
Bob
I have the alkaline tape is it hard to do the corners. I've used drywall mesh and its not the greatest for 90's for taping, So I'm sure it creates the same issues getting a good crease to apply it.
Also the silicone was applied to the plywood box corner seams. Then the cement board(pain in the ass, I've learnt my lesson on its dust and cutting negatives, it's back to wedi or diamondback) applied over top
Thanks
Old 09-07-2015, 12:50 PM   #15
Bob
Thanks
You have to be careful with the corners, no doubt. You are trying to be neat, and to apply enough thinset to do the job without making excessive buildup.
- Bob
Old 09-07-2015, 12:56 PM   #16
Yes, indeed. Now, the restriction is really that you better not have a pin hole anywhere that moisture will accumulate.
- Bob
Old 09-07-2015, 01:00 PM   #17
AGullion's Avatar
Well said
AGullion is offline
Old 09-07-2015, 01:09 PM   #18
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
I'm a fan of kerdi, the have specific pieces for corners, then a liquid membrane also.
Better do it right ONCE then to have to start over..
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 09-07-2015, 03:20 PM   #19
AGullion's Avatar
This thing of mix n match is nuts.....even some manufacturers are confused.
AGullion is offline
Old 09-07-2015, 05:55 PM   #20
charimon's Avatar
There are other methods out there besides Schluter drains on a mud bed ( which I like to use) but here is not the place to discuss them as they are hybrid systems which are not backed by any manufacturer but are in my opinion better than any single source system available.
charimon is offline
Stucco over cement board? BenchmarkB Masonry 13 05-23-2015 09:10 PM
Kerdi Board to Drywall Stunt Carpenter Kitchens & Baths 5 06-18-2013 01:11 AM
Broken Closet Flange & Lead Elbow InterCounty Plumbing 9 09-02-2012 12:06 PM
achieving a paintable fireplace surround with cement board ajmackenzie Painting & Finish Work 17 01-23-2012 03:30 PM
