Ceiling Board
Old 07-10-2017, 09:41 PM   #1
Tom M's Avatar
Rewards Points: 4,562
Ceiling Board
Whats a good board to finish/use in a shower stall ceiling that isnt getting tile?
It might get tiled down the road. I dont want a gypsum, walls may be Wedi
Tom M is online now
Old 07-11-2017, 12:56 AM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 472
Re: Ceiling Board
Denshield works good. The screws don't dimple very nice though. Can always use durock and skim coat it too.
Sent from my SM-G920V using Tapatalk
overanalyze is offline
Old 07-11-2017, 01:07 AM   #3
Hack
asevereid's Avatar
Rewards Points: 206
Re: Ceiling Board
@overanalyze... What would be the recommended product to skim Durock with?
Sent from my Gravity 5 LTE using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 07-11-2017, 02:31 AM   #4
Always Learning
Rewards Points: 472
Re: Ceiling Board
I have used durabond without any issues.
You could also use Densglass type exterior rated gypsum sheeting. We used it as the ceiling in a covered patio. We skimmed it with durabond and then painted it. Turned out good.
The Following 3 Users Say Thank You to overanalyze For This Useful Post:
asevereid (07-11-2017), blacktop (07-11-2017), charimon (07-12-2017)
Old 07-11-2017, 06:35 AM   #5
Tom M's Avatar
Re: Ceiling Board
I was wondering about skimming cement board with 20min. I rarely have durabond around.
Good call on Denshield too. I use it from time to time but never for tileless areas probably needs a skim coat to hold paint.
Thanks Andrew
Tom M is online now
overanalyze (07-11-2017)
Old 07-11-2017, 07:29 AM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,225
Re: Ceiling Board
What's the concern with gypsum? Prime/seal, done.
MarkJames is online now
Old 07-11-2017, 09:14 AM   #7
Tom M's Avatar
Re: Ceiling Board
The ceiling is a little low. And although I have a fan immediately outside of the shower I'm just a little concerned. National Gypsum bored the XP variety says it's okay and I would normally use it if I had at least eight foot ceilings but I'm below eight foot.
Tom M is online now
Old 07-11-2017, 12:24 PM   #8
MarkJames's Avatar
Re: Ceiling Board
For what it's worth...
I have basement shower enclosure, 4' wide Lowe's type, in a bath with a 6' 11" ceiling (since I raised the floor to level it). I have a handheld shower head that's 4" away from the ceiling (since I'm tall). Zero issues, going on 9 years. Dry as a bone. (And the ceiling is flat paint, if you can believe it.)
Old 07-11-2017, 01:29 PM   #9
Tom M's Avatar
Re: Ceiling Board
Wow Mark that seems unusual in your favor
Tom M is online now
Old 07-11-2017, 03:12 PM   #10
MarkJames's Avatar
Re: Ceiling Board
Yup. I now recall going back and forth on whether to paint the ceiling with some enamel (eggshell or semi), but I wanted to see what happens with flat. Then again, I'm the only one that uses that shower. If it was high use, maybe a paint with some sheen would be better.
Old 07-11-2017, 03:26 PM   #11
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 3,028
Re: Ceiling Board
A good prime over any board before color is a must . IMO .
blacktop is offline
The Following 2 Users Say Thank You to blacktop For This Useful Post:
MarkJames (07-11-2017), overanalyze (07-11-2017)
What kind of Board on a ceiling? Part Time Taper Drywall 12 04-06-2013 06:09 PM
How much weight can my ceiling hold? Jdub2083 Drywall 10 01-11-2013 06:27 PM
fine line bolt slot suspended ceiling diffuser Rich D. HVAC 4 01-03-2013 01:32 AM
Cathedral Ceiling with false ceiling stubbs187 Insulation 4 12-25-2010 05:53 PM
Plaster over Particle Board damanriq Construction 9 12-13-2010 03:51 PM
